Truck searching for a gear when at slower speeds
Discussion in '2.5 Gen Tundras (2014-2021)' started by rkboyer911, May 18, 2017.
  1. May 18, 2017 at 11:31 AM
    rkboyer911
    rkboyer911 [OP] New Member
    14 Platinum crewmax
    Is this common? or should I take it to dealer? its like when I yield going around a corner or in a circle it kinda goes up 1 then down a gear. 2014 with 27k on it
  2. May 20, 2017 at 6:50 PM
    RW-3
    RW-3 May the Mods be with you
    Rob
    16 Black TRD CM 4x4
    Lights: 2018 OEM Black Chrome LED’s Morimoto XB Fogs Interior LED upgrade - VLED’s LED reverse / cargo - VLED’s Footwell lights, vanity lights, break lights, rear turn signals, 3rd break light - All VLED’s 30” Rough Country light bar hidden in bumper w/ Rago Fab Brackets Matt Gecko LED bed lights (red & white) and hood lights Exterior: Truxedo Lo Pro QT WeatherTech in-channel window deflectors Interior: Husky X-Act Contour front & rear Front, back and rear windows all tinted 10% Ceramic Heat Film on Windshield 70% OCD console organizer OCD console tray TRD 4x4 inserts on Husky mats by Achuop Tacoma TRD Pro shift knob with TRD leather boot AJT Design vent ring trim - chrome delete Center console wireless charger Drivers side grab handle Performance: Dirty Deeds BA Muffler 12” Budget Standard System TRD Rear Sway Bar AFE Pro Dry S Air Filter Bilstein 6112 1.9” clip Bilstein 5100 - rear Coachbuilder +1’s Nitto Ridge Grapplers 285/70/18 Audio: Infinity dash speakers Tech12Volts custom center dash speaker Hertz Uno door speakers JL Audio RD 900/5 amp 2 JL Audio 10w-0 v3 10” subs in custom Tech12Volts box Protection: McGuard Tailgate Anti theft lock OEM tailgate lock w/ Dynamat TRD Pro skid plate SNS ARB sensor guards Misc: TRD key fob case AJT Designs Rear diff breather mod Fortin remote start with Car Link CL6 TRD battery bracket by Coupe TRD valve stem caps TRD interior handle inserts by abomb60 (Adam)
    Not sure if this is what you are referring to or not, but here's what mine does. If I slow down to about 5 mph (and even if I coast for a while at that speed) the truck can't decide if it should be in first or second gear when I hit the accelerator. It drops into first then immediately switches to second and the truck kicks... making me look like a dumbass in traffic, I'm sure. Thought my transmission was slipping with only 1,000 miles on it. I asked the mechanic @LOTSOFTOYS and he said this was normal because it's an electronically controlled transmission and it's working as fast as it can to determine the proper gear. I've also noticed that even at higher speeds if I let off the gas, when I get back into it the rpm's jump a little and then level off. I'm assuming this is the same issue and it doesn't kick because I'm going faster. I'm in stop and go traffic every day in the 5 o'clock 500 so this is very noticeable to me. Kinda sucks but what can you do. Sorry for the novel, but hope this helps.
  3. May 20, 2017 at 7:00 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've always considered this characteristic of electronically controlled transmissions. My Tundra does it, our 07 Sienna does it and the commercial trucks with automatics that I've driven have all done it. It's like the shift logic is anticipating that the operator is going to hammer the throttle after being off throttle so it selects the lower gear for that hard acceleration. I find that a very gentle throttle application will smooth out the occurrence.
  4. May 20, 2017 at 7:04 PM
    Midnighttaco08
    Midnighttaco08 High Quality H2O Inspector
    Sam
    Gilbert, AZ
    2017 Quicksand TRD OR 4x4 2008 Indigo Ink Tacoma TRDOR
    None yet!
    Electronically controlled trans most likely. My 08 Tacoma does it and I've noticed it with the tundra in traffic as well.
    I'm just used to it I suppose.
  5. May 20, 2017 at 7:08 PM
    RW-3
    Rob
    16 Black TRD CM 4x4
    I'm able to smooth it out about 1 out of 10 times. Have to push in the accelerator like I'm 100 and my ankle is broken to not get the kick at low speeds or the rev'ing of rpm's at higher speeds. Haha. Feel like I'm holding up the people behind me.
    RussellVaughan likes this.
  6. May 20, 2017 at 7:18 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    None yet!
    That's what I do naturally and am used to it lol
    NewImprovedRon and RW-3[QUOTED] like this.
  7. May 22, 2017 at 12:42 PM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    my truck does this. so glad i read this, because it drives me crazy. i notice it most when i do rolling stops. engine revs if i don't consciously and slowly accelerate. ive also noticed response is terrible at high speeds. just feels like very slow shifting. what's the point of all the power if tranny can't handle it?
    edit: i talked to my dealer about it. service manager drives a tundra himself, and explained its inherent to the truck. i was skeptical, but now i'm more inclined to believe him after reading this thread.
    RW-3 likes this.
  8. May 22, 2017 at 3:18 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    No "Shifting Issues" with my 2010 DC. Making use of the Sequential Shifter and choosing the gear that I know is correct, solved my issues, BEFORE they started!:notsure:
  9. May 22, 2017 at 5:00 PM
    15whtrd
    15whtrd Mr. Blonde
    I think what you're feeling at the end there is the torque converter unlocking and then locking back up again.
    RW-3[QUOTED] likes this.
  10. May 22, 2017 at 6:54 PM
    Ericsopa
    Ericsopa Old man and the sea
    Exactly.....this is what's occuring at the higher speeds. Most all autos do that (they all have lock-up converters now).
    15whtrd[QUOTED] likes this.
  11. May 23, 2017 at 12:29 AM
    CMB
    CMB New Member
    Cecil County MD.
    Choosing a gear that's low enough to prevent the heat caused by un-locking/locking Torque Converter is part of the solution.
  12. May 23, 2017 at 11:39 PM
    Bluering808
    Bluering808 Upper Left
    Keahi
    Pacific Northwest
    2017 SuperWhite DC Trd off-road
    Icon stage 3 lift Icon tubular UCAs 18x9 SCS Ray10 wheels
    Same thing pretty much happens with my 2017 as well but I usually shift through the gears manually
  13. Jun 2, 2017 at 3:20 PM
    rkboyer911
    14 Platinum crewmax
    Well as long as it doing the same to everyone i won't worry about it...lol THANKS
    RW-3 likes this.
