Truck runs rough once warmed up.
Discussion in '1st Gen Tundras (2000-2006)' started by Pucks18, May 3, 2020.
  1. May 3, 2020 at 10:03 AM
    Pucks18
    Pucks18 [OP] Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Im getting a p0300, 301,303 304, 305. The truck runs fine in the morning when everything is cold and not warmed up. Then after 5 or 10 mins of driving it starts to idle very rough and sputter. My check engine light blinks too. Ive already swapped the coils around to see if the code follows and all of that. Does anyone have any idea why a truck will run fine at first and then once warmed up it will run rough? Im really worried since its not the ignition coils causing the misfires
  2. May 3, 2020 at 10:14 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    When's the last time spark plugs, injectors have been changed?
  3. May 3, 2020 at 10:16 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    If the valves are getting tight that can happen. They lengthen when they heat up and if they aren't sealing it's most prominent at idle.
    Another possibility is an exhaust leak drawing in outside air and throwing off an A/F sensor, making it add too much fuel because the extra o2 will falsely tell the computer that it's running lean. That kind of leak is usually noisy though.
    Tundyfundy and TokerJoker like this.
  4. May 3, 2020 at 11:11 AM
    Pucks18
    TokerJoker likes this.
  5. May 3, 2020 at 11:12 AM
    Pucks18
    @endagon i do have the notoripus header leak
    Tundyfundy likes this.
  6. May 4, 2020 at 6:40 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    I had the exact opposite thing happen to me, turned out to be a bad coil pack. Did you pull your plugs and see how they look? Possible vacuum leak? Good luck and hope it's not too serious of a problem.
  7. May 4, 2020 at 6:49 PM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    Those are various cylinder misfires, so many that I would not expect it to be coil packs/plugs. I would look for vacuum leaks or maybe O2 sensors that are leaning it out too much when hot.
    Lovetrucks likes this.
  8. May 5, 2020 at 6:23 AM
    Pucks18
    Well guys, it looks like i used to much anti seize on my spark plugs, so thats what is causing it to misfire. Lol.
  9. May 5, 2020 at 6:37 AM
    Professional Hand Model
    Hand Protectors
    Dude bro. We’ve commented here about how most plugs (especially quality ones like NGK) already have/come with an anti-seize coating. No need to add it as it causes flares/hot spots on/around the plug.
    I never knew this until I became an internet expert.
    bmf4069 and N84434 like this.
  10. May 5, 2020 at 6:46 AM
    Pucks18
  11. May 5, 2020 at 6:46 AM
    Pucks18
  12. May 6, 2020 at 2:53 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    How much anti-seize did you put on the plugs?
  13. May 6, 2020 at 7:25 PM
    Pucks18
    @tvpierce not a shit ton but more than recommended without a doubt
  14. May 6, 2020 at 7:31 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    another thing to know is a blinking CEL is the ECU begging you to let off the throttle. Way too much unburned fuel is making it to the cats, too much of that causes damage to those expensive items.....
  15. May 7, 2020 at 4:42 AM
    tvpierce
    Maine
    How did you arrive at that diagnosis? Unless you packed the electrode area full of anti-seize, I don't understand how it could possibly cause a misfire. :confused:
    Darkness likes this.
  16. May 7, 2020 at 4:52 AM
    Hand Protectors
    Internet spark plug expert chiming in here. :D (Better than a viral expert:D).
    Anti seize heats up hotter than the plug spark, thus sets off the ignition pre-spark before the spark plug is timed to ignite.
    Picture a hot molten goo around the threads (not timed to spark, but always hot enough to ignite fuel).
    Sundown5oh and TX-TRD1stGEN like this.
  17. May 7, 2020 at 5:11 AM
    tvpierce
    Maine
    Could be. I had to Google "anti-seize cause misfire". I'd never heard of this before... it seems neither had the original tech in the video. The engineer offers a really good explanation of what happened. (Play it at double speed... it's long.)
    I learned something new today. I'm exhausted... I'm taking the rest of the day off!
    bmf4069 and Darkness like this.
  18. May 7, 2020 at 5:31 AM
    Pucks18
    @tvpierce I understand your speculation. The mechanic said thats what it was, he cleaned the plugs and now my truck runs good again, so i am certain thats what it was, at least 99 percent certain ;)
    tvpierce likes this.
  19. May 7, 2020 at 5:42 AM
    tvpierce
    Maine
    @Pucks18 I was skeptical until I saw the video I posted above. The anti-seize isn't directly causing the misfire. Over time it leads to fouling that in turn leads to the misfire. Good catch on the part of your mechanic. :thumbsup:
  20. May 7, 2020 at 4:01 PM
    Hand Protectors
    This guy has good philosophy.
  21. May 15, 2020 at 10:30 AM
    Pucks18
    Well fuck! Its starting to slowly run rough again! Better clean the plugs again or i might just replace them all as there may be residual anti seize still
  22. May 15, 2020 at 12:12 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I know that when plugs are worn it causes excessive wear on the coils. I wonder if the opposite is true. Meaning, I wonder if your ignition coils need to be replaced. Are they original?
    edit- Just read your original post where you seem to think they are fine.. :monocle:
  23. May 15, 2020 at 12:32 PM
    Pucks18
    My coils are fine. Truck was running like crap cause of me using anti seize on plugs.. my mechanic cleaned them and for a month it ran great now its getting rough again, gonna just replace the plugs with ngk v power part #7990 plugs then call it a day.
  24. May 16, 2020 at 2:39 PM
    Pucks18
    Jesus christ never use anti seize ever. I put my new plugs in and took one out right away and the brand new plugs already got a bunch of left over anti seize on them. Its all pooled up on the bottom of the spark plug tubes right before the threads start. Dont know how the hell I'm gonna clean that shit up. The truck def is running slightly rough at times and i know its from the anti seize. I might just take a shop towel and roll it up and stick it in there. But i will be risking knocking anti seize into the combustion chamber
  25. May 17, 2020 at 5:07 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  26. May 17, 2020 at 5:54 AM
    Pucks18
  27. May 17, 2020 at 10:25 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Oh I'm sorry, I thought you wanted to clean the shit up but I digress, I suppose you simply wanta half ass do it !
  28. May 17, 2020 at 2:06 PM
    Pucks18
    Dont understand how taking my valve colver off is going to help me at all buddy.. the spark plug tubes are still there at the same height......thanks tho...
  29. May 17, 2020 at 4:18 PM
    Hand Protectors
    I’ve never removed the head but I guess thats the only way to get at a true clean up job. I remember seeing this kit designed to clean up spark tube threads where one sticks an umbrella thingy down into the piston chamber and opened it. Then a brush and vacuum cleaned up the threads without removing the heads.
  30. May 17, 2020 at 5:20 PM
    Pucks18
    Dumbass
