Truck not moving in drive
Discussion in '2nd Gen Tundras (2007-2013)' started by mike11895, Apr 21, 2020.
  1. Apr 21, 2020 at 7:50 PM
    mike11895
    mike11895 [OP] New Member
    2010 tundra doublecab long bed
    So this always happens at the Wendy's drive through but also elsewhere. Level ground. I pull up to order. In drive, foot on brake for 10-30 seconds. Wanted to go around corner to drive up window on trucks own power, foot off brake, truck doesn't move, have to give it has to go. Is there something wrong with my transmission?
    2010 tundra ext cab long bed
    I thought all vehicles ALWAYS move on their own when in drive especially on flat ground, right?
  2. Apr 21, 2020 at 10:33 PM
    TTund16
    TTund16 New Member
    maybe that is not a general rule but as you said, all my auto trans cars move when in D and on flats. I don't recall one that didn't .
    couple of ideas ...
    What's the rpm when in gear and your foot on the brake? Is the car idling ok?
    also could be that your parking brake or brakes are sticking a little. How's your mpg?
    Filthyphil likes this.
  3. Apr 22, 2020 at 12:59 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You may very well have a sticking caliper or pads that are sticking to the bracket.
    Filthyphil and Zebruaj like this.
  4. Apr 22, 2020 at 4:27 AM
    mike11895
    I believe it is idling normal, usually at 700rpms. Yes definitely might be the brakes. For mpg usually 13 town And 17 if highway, interstate driving. Sometimes I've gotten alot worse though, I'll have to start keeping track of that. I think you guys are right about it being the brakes
  5. Apr 22, 2020 at 7:01 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Simple solution: Stop going to Wendys!
    lol
  6. Apr 22, 2020 at 8:38 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I agree with the brake theory, either a parking brake cable or a sticking caliper / slide pin / pad. If it’s not that, and your Tundra is 4wd make sure it’s actually in 2wd. Try spinning the front driveshaft by hand when in 2wd.
  7. May 24, 2020 at 6:51 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Hows your trans fluid? Is it at the propper level? An does it smell normal like dead dinosaurs or burnt ?
  8. May 24, 2020 at 6:57 PM
    mike11895
    It needs to be replaced. Took some of it out but need to flush it all out and replace for sure. After replacing some of it that actually helped it seems
  9. May 24, 2020 at 7:08 PM
    NueveTundra
    Planet Earth
    Make sure to note any shiny metal flacks some is normal but alot can mean excessive wear an can be a filter or pathway clogger
    mike11895[OP] likes this.
