Truck No Work Good
Discussion in '1st Gen Tundras (2000-2006)' started by Walker-Wheels, Jun 28, 2021.
  1. Jun 28, 2021 at 10:31 PM
    Walker-Wheels
    Walker-Wheels [OP] New Member
    Bryce
    2006 Silver DC Tundra TRD off-road 4x4
    Okay I think I have another issue, Slammed on the breaks about an hour ago to avoid a kid on a skateboard in the dark, Calipers kinda locked up (used to it on this truck) went back to the gas pedal and pressed down, but the truck did not move. Rpms briefly did not move either, then the truck almost just like snapped out of it and accelerated again unsticking the calipers. About a mile down the road the transmission has not shifted gears and I'm doing 4k rpms at 50 mph I let off the throttle and after a second it shifts. Now as I am pulling into my street about another mile down, the throttle becomes unresponsive. I would apply the throttle nothing, nothing, nothing... wham there's the gas. I don't even know where to begin looking for a diagnosis on this fiasco, Anyone have any suggestions or should this just be a trip to the Toyota dealership?
  2. Jun 29, 2021 at 4:36 AM
    Any codes? Sounds like TPS. Other things can cause a limp mode, like SAIS issues too.
  3. Jun 29, 2021 at 5:48 AM
    Legender
    Legender New Member
    Carlton
    DFW
    2006 Tundra DC Limited 2WD
    None yet.
    The first easy thing I'd try is to disconnect the battery for about 30 minutes and let everything reset. What is your fluid like in your brake reservoir? Clean/dirty. So the ABS did not kick in? That's kinda strange.
  4. Jun 29, 2021 at 10:28 AM
    Walker-Wheels
    Bryce
    No abs kick, I'm gonna scan for codes and then disconnect the battery.
  5. Jun 29, 2021 at 10:31 AM
    Walker-Wheels
    Bryce
    I had the P1445 code 6 months ago so there is one of those small divergent chips plugged into the MAF, I do know those can trigger limp mode if it gets below freezing. Maybe that somehow got wiggled loose? Ill report back in a few.
  6. Jun 29, 2021 at 10:45 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Bingo
    "P1445: Secondary Air Injection System Switching Valve No.2 Bank2 Stuck Closed"
    According to what condition your truck is in under hood(we've seen some doozies), the hard breaking action could have joggled something loose !
  7. Jun 29, 2021 at 11:04 AM
    Walker-Wheels
    Bryce
    Okay guys we've got a few... From the engine and ect: P0505, P2714 From the abs we have C0200 and C0210.
  8. Jun 29, 2021 at 11:05 AM
    Walker-Wheels
    Bryce
    I Just joggled with the chip for a minutes under the hood currently have the battery disconnected now Ill be looking into these codes and then going for a test drive within the next 30 minutes.
    BubbaW[QUOTED] likes this.
  9. Aug 27, 2023 at 7:31 PM
    joefred9
    joefred9 New Member
    06 Tundra AC
    Did this fix your problem?
  10. Aug 27, 2023 at 7:35 PM
    shifty` Animals and insects don't do drugs
    Member hasn't been here in months.
