Truck moved with feet on brakes
Discussion in 'New Member Introductions' started by 17TUNDC, Jul 17, 2021.
  1. Jul 17, 2021 at 4:53 AM
    17TUNDC
    17TUNDC [OP] New Member
    A new member from south PA. At a stop light with 5 people in the cab to witness it. Truck started to move and with both feet on brake, it bumped truck in front. I have imprint if his trailer hitch in the plastic cover. Has anyone dealt with something like this.
    This is the first issue I've had with it 21kmiles.
    YardBird likes this.
  2. Jul 17, 2021 at 5:09 AM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    How many miles on the vehicle?
    Do you know the condition of the pads and rotors?
    Have you checked the level of brake fluid in the master cylinder?
    Did the brake pedal feel different from normal when this happened?
    Did the pedal go all the way to the floor or maybe feel like the ABS was activated?
    Barrett50 likes this.
  3. Jul 17, 2021 at 5:14 AM
    17TUNDC
    21k pads and rotors just inspected in June. Just finished 450 mile trip. Yes it went to floor abs felt like it might have been active. Used both feet but truck went forward anyway.
  4. Jul 17, 2021 at 5:28 AM
    17TUNDC
    Thanks for link. Will try this when I get Tuesday.
  5. Jul 17, 2021 at 5:57 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  6. Jul 17, 2021 at 5:58 AM
    17TUNDC
    Thanks
  7. Jul 17, 2021 at 6:29 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Check for leaks, especially around the hard lines at the caliper.
  8. Jul 17, 2021 at 6:58 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Sorry to hear about this, but welcome to the forum from LA (Lower Alabama)!
  9. Jul 17, 2021 at 7:12 AM
    17TUNDC
    Thanks Danman. Bakershack love the people from LA.
    Bakershack likes this.
  10. Jul 17, 2021 at 7:37 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Welcome from Norcal
    Thought Toyota's updated software would prevent most of this due to engine power being cut when the brake was applied?? Atleast that's what the recall I received stated like a decade ago, for unintended acceleration... eitherway I'd check your calipers.. A cracked rotor mangled my caliper and when the brake was applied it kept going with the brake pedal to the floor
  11. Jul 17, 2021 at 8:04 AM
    17TUNDC
    Thanks Blackdemon and toofun.
  12. Jul 17, 2021 at 8:06 AM
    17TUNDC
    I didn't mention because Idk this was In a line at Fast food drive in. Under heavy AC use. Any thoughts?
  13. Jul 17, 2021 at 8:08 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Did u over heat your breaks
  14. Jul 17, 2021 at 8:09 AM
    17TUNDC
    They are not warped, stopping normal right after.
  15. Jul 17, 2021 at 8:10 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I think u overheated ur break pad
  16. Jul 17, 2021 at 8:10 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    When it cool back down, it stop normal again
  17. Jul 17, 2021 at 8:11 AM
    17TUNDC
    Good point, lots of use stop n go
  18. Jul 17, 2021 at 8:11 AM
    17TUNDC
    Yes no problem. No shake at all
  19. Jul 17, 2021 at 8:12 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Get some better brake pad with higher temperature
  20. Jul 17, 2021 at 8:15 AM
    17TUNDC
    The calipers use to freeze in the 90s. I've had several toys that 90 truck did rt front once.
  21. Jul 17, 2021 at 8:15 AM
    Geezer
    Geezer New Member
    2019 Tundra Limited
    Possibly air in the master cylinder or even a speck of dirt in there. A good bleeding may help.
  22. Jul 17, 2021 at 8:16 AM
    17TUNDC
    These r original pads with 21k, May be ill check them out.
  23. Jul 17, 2021 at 8:33 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Organic brake pad don’t take that much before brake fade, maybe metallic or ceramic pad
  24. Jul 17, 2021 at 10:30 AM
    blackdemon_tt
    AC ain't got nothing to do with it... it's like saying you slipped because your fan was on... just a comparison.. I would agree with most if it's master cylinder issue if you don't find a leak elsewhere.. I'd look at all 4 corners or take it somewhere to be checked....
  25. Jul 17, 2021 at 12:27 PM
    17TUNDC
    Thanks
