Truck maintenance
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1794., Jan 12, 2025.
  1. Jan 12, 2025 at 5:37 PM
    1794. [OP] New Member
    Gregg
    2016 1794 Crewmax
    Rear bumper.
    My truck is close to hit 100k , and I was wondering what you guys recommend on maintenance at 100k
  2. Jan 12, 2025 at 7:49 PM
    Whatever ur owner manual states- presuming no after market
    Cpl_Punishment likes this.
  3. Jan 12, 2025 at 8:59 PM
    blenton
    blenton New Member
    Yes. Like @T-Rex266 said, check the manual but a few things I would recommend if you haven’t serviced them before or recently:
    Differentials and transfer case
    Air and cabin filters
    Coolant exchange (use genuine Toyota coolant not a universal coolant)
    Power steering fluid (don’t have to do a complete drain and fill, just turkey Baste the reservoir and refill)
    Transmission drain and fill (I don’t like flushes just drain and fill)
    Brake fluid flush
    PCV valve
    Grease driveshaft zerk fittings if your truck has them (they deleted them on later years)
    Check and possibly replace:
    spark plugs
    Serpentine belt and tensioners
    Blinker fluid (there’s a great write up posted recently here on the site)
    Muffler bearings
    I’m sure I missed a few things.
    Tundra family likes this.
  4. Jan 17, 2025 at 5:38 AM
    Desron23
    Desron23 New Member
    2021 Red Crewmax
    Not quite the same mileage, but I'm taking mine on a 2,200 mile round trip here next week.
    I'm in a 2021 with about 47,000 miles. I got the differential fluids changed about 35k and I'm planning on swapping oil (currently at about 3k), new cabin and intake filters before the trip.
    I'll have brand new tires for it. I may/will probably do a coolant flush. I'm going to check the pads but they were at about half life at diff fluid change.
    Is there anything I'm missing?
  5. Jan 17, 2025 at 7:21 AM
    seydou
    seydou Distinguished Member
    Check your spare tire. How old is your battery? Do you have a jump box? Take a spare jug of ww fluid.
    Desron23[QUOTED] likes this.
  6. Jan 17, 2025 at 7:35 AM
    Desron23
    Desron23 New Member
    2021 Red Crewmax
    Thanks - I'm still on the OG battery, and it stays in a somewhat heated garage. The battery died for the first time last month after I accidentally drained it in accessory power mode. I jumped it and voltage has been normal since, I don't drive many trips under 10 minutes so it stays charged fine. I have a nice jump box just in case. I'll double check the spare while I'm under it for the oil. I'm headed to BFE Kansas so battery could be a good idea since there isn't much between here and there.
