truck locks up in reverse
Discussion in '1st Gen Tundras (2000-2006)' started by sbrittany009, May 5, 2018.
  1. May 5, 2018 at 7:52 PM
    sbrittany009
    sbrittany009 [OP] New Member
    Brittany
    2003 Toyota Tundra 4.7l
    so i experienced something the other day that i have no idea about i was backing up and and my truck locked up almost felt like the back end was locked up when ever i hit the gas my truck wouldn’t go anywhere but shift to the side so i drive forward and tried again but had the same issue does anyone know what’s going on or has anyone has the same issue i thought it was really odd but i don’t think it’s the tranny because my truck seems to be driving and shifting fine in drive, please help.
  2. May 5, 2018 at 7:57 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Something definitely sounds busted in the rear end :(
    mudslinger79 likes this.
  3. May 5, 2018 at 7:58 PM
    sbrittany009
    Brittany
    if i take the diff cover should i be able to tell if i need new gears.
    GNTundra likes this.
  4. May 5, 2018 at 8:03 PM
    sbrittany009
    Brittany
    how long do you think it should take to replace it and is it easy to do or would it be something i should take to a mechanic?
  5. May 5, 2018 at 8:07 PM
    sbrittany009
    Brittany
    i figured luckily i have a mechanic that lives across the street so i can just take it to him and ask him to fix it thank you for the advice.
    NewImprovedRon likes this.
  6. May 5, 2018 at 8:20 PM
    sbrittany009
    Brittany
    okay thank you
  7. May 5, 2018 at 8:24 PM
    sbrittany009
    Brittany
    lol thank you i’ve seen it before just looking up stuff about my truck and thought i’d join it
  8. May 5, 2018 at 8:31 PM
    sbrittany009
    Brittany
  9. May 5, 2018 at 8:33 PM
    sbrittany009
    Brittany
  10. May 5, 2018 at 8:33 PM
    sbrittany009
    Brittany
    working on getting a paint job and more stuff done with it but that’s in hold until i get the reverse situation figured out
    boostedtrdpro and GNTundra like this.
  11. May 5, 2018 at 8:37 PM
    sbrittany009
    Brittany
    i don’t do much off roading i live down a dirt road but it’s not terrible
  12. May 5, 2018 at 8:41 PM
    sbrittany009
    Brittany
    me too hopefully and i will for sure thank you for helping.
  13. May 5, 2018 at 8:54 PM
    Welcome to the forum.
    Couple things I would look at:
    -brake assembly. Sometimes the springs get weak over time or just really dirty inside. In reverse the shoes can catch. I’ve had this happen on trailers. Sometime we get in some really muddy or dirt roads towing to our destination. I pull my drum brake assemblies at least every other year unless we get into these situations a couple times per year. Your drum brakes are auto adjusting as well, so this can be a compounding problem.
    - Check the parking brake cable to ensure nothing got up there and has tension on it.
    Lastly, you have no rear differential cover. Toyota uses a 3rd member design and it is quite involved to “check” your gears.
    I’ll bet you twelve one packs of beer the brakes are the culprit.
  14. May 6, 2018 at 8:02 AM
    sbrittany009
    Brittany
    my dad pulled my truck back in neutral and it went fine but when i put it in reverse it still locks up. going to start with replacing the tranny filter and seeing if that helps if not i guess it’ll be time to drop a tranny.
    ColoradoTJ and GNTundra like this.
  15. May 6, 2018 at 8:34 AM
    boostedtrdpro
    Jeremy
    This happened to one of my trucks about 6 years ago. Snap ring in the OD assembly sheared and the truck wouldn't move in reverse. The dead give away was the big chunks of snap ring in the tranny pan.
  16. May 6, 2018 at 8:49 AM
    sbrittany009
    Brittany
    is it a hard replacement or should a mechanic to do it?
  17. May 6, 2018 at 8:52 AM
    boostedtrdpro
    Jeremy
    It's pretty tough if you don't have all the tools. I completely rebuilt the tranny to the heavier duty specs. I had access to a lift, and a hydraulic shop press and I have a ton of tools. If you find large pieces of metal in the pan, if you can pull the tranny and take it to someone to be rebuilt, that'll save some coin.
  18. May 6, 2018 at 8:53 AM
    sbrittany009
    Brittany
    would i be better off buying a new tranny or just rebuilding it at that point?
  19. May 6, 2018 at 4:11 PM
    Well that’s a pretty good process of elimination. I sure hope this doesn’t get spendy.
  20. May 6, 2018 at 4:13 PM
    sbrittany009
    Brittany
    so found out the transmission has to be rebuilt
  21. May 6, 2018 at 4:13 PM
    boostedtrdpro
    Jeremy
    Bummer. What did you find?
  22. May 6, 2018 at 4:16 PM
    sbrittany009
    Brittany
    pretty sure reverse is just gone i found a good amount of metal shavings in the tranny fluid
  23. May 6, 2018 at 4:17 PM
    boostedtrdpro
    Jeremy
    That sucks. Not much else to say. Hope you have another form of transportation. :(
  24. May 6, 2018 at 6:23 PM
    Total bummer. I was hoping you had something easy and cheap like the rear brakes.
    I owe you twelve one packs if your ever in CO.
    15whtrd and boostedtrdpro like this.
  25. May 8, 2018 at 7:27 AM
    sbrittany009
    Brittany
    it’ll be back on the road by thursday or friday got a used transmission with 109 miles on it shipped over night nothing wrong with the tranny they parted out the truck because it got hit so it’ll be on the way to the shop tomorrow morning :)
  26. May 8, 2018 at 7:36 AM
    sbrittany009
    Brittany
    thank you i’m happy i found one
  27. May 9, 2018 at 6:09 AM
    sbrittany009
    Brittany
    i actually called lkq i live in florida and they have them down here but a salvage yard would be your best bet because technically lkq is a salvage yard
  28. May 11, 2018 at 8:00 AM
    sbrittany009
    Brittany
  29. May 11, 2018 at 8:00 AM
    sbrittany009
    Brittany
    she’s back on the road
  30. May 15, 2018 at 5:08 AM
    Mike Tread lightly.
    south carolina
    I'm always late to the party always over worked...
    ColoradoTJ likes this.
