Truck lasted 3 weeks
Discussion in '2nd Gen Tundras (2007-2013)' started by Thesandaddict, Apr 22, 2019.
  1. Apr 22, 2019 at 6:21 PM
    Thesandaddict
    Thesandaddict [OP] The dude
    Harley
    2010 DC
    Bilsteins, methods
    Now that I have your attention.
    So heres the story.
    Picked up a 2010 tundra 5.7 with 61k on it on March 29th. Awesome truck. Have loved every minute. Until today. I have yet to do research as I have a few mixed symptoms and dont know what to investigate.
    Was driving home, guy was doing 55mph in the fast lane so I attempted to pass him in the #2 lane. Got up to 75 or so, and went to hit the brakes. Unresponsive. Realizing my distance between the car ahead of me was closing, I attempted to accelerate further and make another lane change and exit the freeway and slow down via lower gears and e'brake. No throttle response. Truck was dead at 75mph.
    Flashers on, manually hitting the brakes and I muscled it off the fwy onto the shoulder. Tried to restart the truck and was met with a lovely clack clack clack. I've windowed one block before on a 22re and it sounded identical. Called AAA and said screw it. Tried to restart just so I could try and hear it better, truck would crank and stutter as it attempted to fire, but seemed everytime it got into stride, it would clack clack clack again. I stopped. I couldnt safely get out and check much, but from what I could tell, no oil on the ground or pan, block was intact. Just dead.
    I did notice the a/t oil pressure and check engine light on as i pulled over.
    So where should I start. Its sitting at Longo Toyota for a diagnosis later but i want to be prepared for reality.
  2. Apr 22, 2019 at 6:24 PM
    TheBeast The Beach
    limp mode ? how many lights you got on the dashboard ?
    Thesandaddict[OP] likes this.
  3. Apr 22, 2019 at 6:25 PM
    Thesandaddict
    Harley
    2010 DC
    Bilsteins, methods
    No limp mode , truck completely shut off and wouldnt restart.
    Just the check engine and a/t. I couldnt turn it on and check oil pressure or anything. And I didnt get a chance to check to see if it even had oil before it was taken to the dealership (that's my fault, hindsight is 20/20) but it hasnt leaked a drop since I've had it
  4. Apr 22, 2019 at 6:27 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Replace the battery.
    Aerindel and Thesandaddict[OP] like this.
  5. Apr 22, 2019 at 6:29 PM
    Thesandaddict
    Harley
    2010 DC
    Bilsteins, methods
    Cant tell if serious or one of us is just.....:der:
    Motor sounds like it spun a rod bearing....replace battery?
    GNTundra and T-Rex266 like this.
  6. Apr 22, 2019 at 6:43 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Broken timing belt? Do the pistons hit valves on these engines when that happens? Might explain the clacking sounds.
  7. Apr 22, 2019 at 6:48 PM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    Happen to check the carfax before you bought that car?
  8. Apr 22, 2019 at 6:50 PM
    Ironjaw
    Ironjaw Taxation is theft
    Kurtis
    Pendleton IN
    '19 Quicksand Tundra TRD
    My brother is a mechanic. He's been seeing a lot of these 7-10 yr old tundras coming in with similar miles, same symptoms, and its been a broken timing belt everytime. 5 different trucks in last 6mos.
  9. Apr 22, 2019 at 6:53 PM
    Thesandaddict
    Harley
    2010 DC
    Bilsteins, methods
    Yes it's at home (somewhere)
  10. Apr 22, 2019 at 7:00 PM
    Trpl7
    Trpl7 My best friend Tate
    Rob
    Washington
    Super White 07
    Partial level kit, Total chaos UCA, coach builder shackles, magnaflow ex. Tuner, SABM, complete poly bushing suspension.
    What engine you have? 5.7 has a timing chain.
  11. Apr 22, 2019 at 7:00 PM
    Thesandaddict
    Harley
    2010 DC
    Bilsteins, methods
    Yes 5.7
  12. Apr 22, 2019 at 7:00 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I’m sorry, I’m no help and don’t know what it could be but am curious to know once you find out. The lack of brakes sounds scary.
  13. Apr 22, 2019 at 7:01 PM
    Thesandaddict
    Harley
    2010 DC
    Bilsteins, methods
    It was lack of everything. Brakes, power steering, it was all bad for about 30 sec. I was afraid of the wheel locking out but luckily it wont do that with the keys in
    equin[QUOTED] likes this.
  14. Apr 22, 2019 at 7:02 PM
    15whtrd
    15whtrd Mr. Blonde
    For starters, what engine do you have?
  15. Apr 22, 2019 at 7:03 PM
    Thesandaddict
    Harley
    2010 DC
    Bilsteins, methods
    ^^^^ as stated above, 5.7. I'll add it to the original post
    15whtrd[QUOTED] likes this.
  16. Apr 22, 2019 at 7:04 PM
    15whtrd
    15whtrd Mr. Blonde
    It’s possible the timing chain tensioner shit the bed and then the chain skipped a tooth or 2.
    JohnLakeman and equin like this.
  17. Apr 22, 2019 at 7:05 PM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    Agree w trpl7 5.7 is chain driven. Never heard of a chain going bad but n e thought is possible I guess
    Black Wolf likes this.
  18. Apr 22, 2019 at 7:06 PM
    Thesandaddict
    Harley
    2010 DC
    Bilsteins, methods
    That would mean that the oil is trash. I have all 19 services recorded on the carfax at a dealership. Truck had 61k when I bought it
  19. Apr 22, 2019 at 7:10 PM
    equin
    Ed
    DFW, TX
    I had a ‘93 fullsize Bronco shut down on me on the highway, and that was scary. But it still had brakes and power steering. Problem with mine was that a wire harness got loose and wrapped itself around the driveshaft, pretty much killing power to the fuel pump. Yours sounds like something much different, though. Please let us know the diagnosis when you find out.
  20. Apr 22, 2019 at 7:11 PM
    equin
    Ed
    DFW, TX
    I can see that stopping the engine, but would it also kill the brakes and power steering?
    Aerindel likes this.
  21. Apr 22, 2019 at 7:14 PM
    Thesandaddict
    Harley
    2010 DC
    Bilsteins, methods
    Engines off, all components attached to it too. Ps pump and brake booster are electrically controlled as far as I know
  22. Apr 22, 2019 at 7:14 PM
    A 2010 5.7L .has a timing chain
    15whtrd likes this.
  23. Apr 22, 2019 at 7:15 PM
    15whtrd
    15whtrd Mr. Blonde
    Maybe the engine completely died?
  24. Apr 22, 2019 at 7:15 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Yes, no engine running-no power. Power steering pump runs off belt from engine, brakes are power assist, needs engine vacuum.
    They’ll still work, just have to muscle it.
  25. Apr 22, 2019 at 7:21 PM
    shakezoola
    shakezoola Not a new member
    Kansas City
    2019 Tundra TRD Sport MGM
    N-Fab MRDS Bfront Bumper w/ Rigid Industries Radiance PODS and Curved LED Light Bar TRD Skid plate Victory 4x4 Roof rack and hood mounts with Rigid industries Midnight PODS Alpine Halo9 ILX-F309TND Alpine PDR-V75 5-Channel amp powering 4x Image Dynamics component speakers Alpine S-A60M powering 1x 12" sub Fortin Remote Start with MyCar App Switch Pros SP-9100 Pop-and-Lock tailgate lock vLeds front turn signals w/switchback Center Console Safe Pedal Commander Diamond Back HD bed cover Swing Cases Driver/Passenger Katzkin Leather seats w/ heated front seats Bilstein B8 5100's Front and rear AMP Research PowerSteps Toyota TSS wheels w/ DuraTracs Toyota bed mat Bed light (LEDs) Blacked out badges Sport Antenna
    Many years ago, I drove a Land Rover. I was at a stop light, when it turned green I pressed the accelerator. About 5 seconds later I hear a "clank". Soon after, the dashboard lights up. I go to pull into the nearest parking lot, and had no power steering, and no power brakes. Temperature light, battery light, check engine light are on. I popped the hood, and I see the serpentine belt was loose. Turned out the bolt holding the tensioner pulley had snapped. I happened to pull into an Ace hardware parking lot. I bought a $3 bolt to replace it. Fixed everything.
    I hope you end up with a similar solution.
    TheBeast, Trooper2 and equin like this.
  26. Apr 22, 2019 at 7:22 PM
    equin
    Ed
    DFW, TX
    Gotcha. That makes sense.
  27. Apr 22, 2019 at 7:23 PM
    Trpl7
    Rob
    Washington
    Super White 07
    You probably had brakes but with the loss of power and the fact that you were doing 70 plus they usually don’t work the same so you didn’t notice and I would think that I wouldn't notice either because I would’ve shit myself.
    It’s a good thing though that you got it slowed down and stopped without hurting yourself or anybody else.
    Stormtrooper81 and TheBeast like this.
  28. Apr 22, 2019 at 7:28 PM
    Thesandaddict
    Harley
    2010 DC
    Bilsteins, methods
    Unfortunately I don't t see this ther case as there wasnt one clank (pulley snapping) it was very much clacking. YouTube rod bearing knock. Its exactly that noise (unfortunately)
  29. Apr 22, 2019 at 7:31 PM
    Thesandaddict
    Harley
    2010 DC
    Bilsteins, methods
    I had brakes. Just no power brakes. Just like the good ol days. A simple stomp like you're trying to not put a 5000lb truck into the back of a Corolla and a downshift to 4th gear and it was manageable
  30. Apr 22, 2019 at 7:34 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Yep, I was going duck hunting one morning approaching a curve towing boat and dog stuck her nose down and turned my key off. Fortunately I realized real quick what happened because steering was locked. I know the feeling.
