Truck Freakout
Discussion in 'General Tundra Discussion' started by zcarpenter92, Feb 19, 2016.
  1. Feb 19, 2016 at 11:09 AM
    zcarpenter92
    zcarpenter92 [OP] Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Got in my pickup this morning, and I've got VSC Off and 4LO flashing. I've also got a check engine light and traction control off. It all was just like this when I started 'er up, and none of these lights were on last night.
    Any mechanics out there got an idea?
  2. Feb 19, 2016 at 12:10 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
  3. Feb 19, 2016 at 12:19 PM
    Was the recent update recall for the air pump done?
    zcarpenter92[OP] likes this.
  4. Feb 19, 2016 at 12:45 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Yeah, sounds like the air pump issue. I'm dealing with that right now.
  5. Feb 19, 2016 at 1:11 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    ^ Agree
  6. Feb 19, 2016 at 1:48 PM
    Go get the code read
  7. Feb 19, 2016 at 3:32 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    You guys are all right. I didn't know anything about that recall, turns out the secondary air pump went out.
    Black Wolf likes this.
  8. Feb 19, 2016 at 6:23 PM
    Nor7
    How many miles are on your Tundra? I'm sure you've read up on it but in case you didn't it's still covered up to 10 yrs / 150 k miles.... except of course for the 2011 year models (like mine).
  9. Feb 19, 2016 at 6:26 PM
    Maybe the 2011's and up have a better AIP setup? Just curious. @LOTSOFTOYS should know if there is a difference. Definitely would be nice to know even though i own an 07.
  10. Feb 19, 2016 at 6:30 PM
    Nor7
    No, there's a TSB (attached) that identify the issue up to 2011 and lists the part numbers, which are identical. The recall is also attached.
  11. Feb 19, 2016 at 7:01 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Mine has 78,500.
  12. Feb 19, 2016 at 7:18 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    You guys are most likely correct a out the air pumps. Op needs the codes checked
  13. Feb 23, 2016 at 2:33 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    The write up from my dealer
