Truck dies with low idle
Discussion in '1st Gen Tundras (2000-2006)' started by sbrittany009, Jun 30, 2018.
  1. Jun 30, 2018 at 7:08 PM
    sbrittany009
    sbrittany009 [OP] New Member
    Brittany
    2003 Toyota Tundra 4.7l
    has anyone had the issue of when stopping at a stop light and your truck starts to idle low and then just completely cuts power and the check engine light and battery light comes on? i have a first gen (2003). i have to put my truck in park then turn it off and back on and it still continues to idle at like 250 rpm then it’ll jump up to 1 grand rpm.
    Sip69 likes this.
  2. Jun 30, 2018 at 7:35 PM
    Casper421
    In the woods
    06 DC
    Sounds like a bad alternator. Similar symptoms on my old v8 4Runner when the alternator shit the bed.
  3. Jul 1, 2018 at 6:45 AM
    sbrittany009
    Brittany
    lthsnk you i really had no idea what if could have been so i wanted to ask it happens atleast once a day.
  4. Jul 1, 2018 at 6:51 AM
    Professional Hand Model
    Hand Protectors
    Maybe clean your throttle body valve and your MAF sensor if those haven’t been done recently. Throttle body takes about 1/2 hour to partially remove and spray with cleaner. MAF is a 5 minute job. Youtube is your friend. Cheap easy place to start then move to alternator.
  5. Jul 1, 2018 at 7:31 AM
    Nick T
    Nick T New Member
    Nick
    What is your check engine code(s). What volts do you get with the truck running from the alternator (I doubt it is the alternator but check to rule it out) ? Mileage and previous maintenance ?
    Start with the easy stuff like cleaning your MAF and throttle body as suggested, how long since tune up? New plugs, air filter, gas filter etc. Does the CEL code say it is a misfire, running lean/rich ?
  6. Jul 1, 2018 at 11:26 AM
    sbrittany009
    Brittany
    the check engine light isn’t on when it’s running it only turns on along with the battery light when my truck dies
  7. Jul 1, 2018 at 11:50 AM
    Grumpy Uncle
    Pat
    CO
    Do you know if your truck is throwing codes? It sounds to me almost like M.A.F sensor is going flakey.
  8. Jul 1, 2018 at 1:22 PM
    sbrittany009
    Brittany
    no it’s not literally itll just die off but act like it’s in ac mode it’s really weird
  9. Jul 1, 2018 at 2:43 PM
    Nick T
    Nick T New Member
    Nick
    Do your basic tune-up, plugs, air filter, fuel filter, clean MAF. If high mileage and truck still idles low after the tune-up change your ignition coils.
    GeezePlease likes this.
  10. Aug 10, 2020 at 8:14 PM
    NoviceTruckOwner
    NoviceTruckOwner New Member
    2000 Tundra 4wd
    I had the same problem on mine. I cleaned the throttle body with some tb cleaner and I opened the flange held in by two screws right above and behind the tb and cleaned inside that with a wire brush and tb cleaner. My truck went from less than 500 and dying at stops to revving about 700-1000 rpms.
  11. Aug 10, 2020 at 8:19 PM
    Don't forget the vacuum hoses. Notorious culprit for idle issues.
    Tundra2 likes this.
  12. Aug 11, 2020 at 3:08 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Just to be clear, the Check Engine light and battery light coming on are not an indication of any problem. They're coming on because the key is in the on position and the engine isn't running. That's normal behavior -- it happens every time just before the engine is started.
    I doubt your alternator is bad. If it was, the starter would crank really slowly and after a couple of times, you wouldn't be able to re-start the engine.
    As others have said, dirty MAF sensor and TB are likely suspects. Personally, I'd want to know which one was causing it... so I'd do the MAF sensor first (cause it's easiest) then run the truck and see what happens. Even if that does fix it, I'd still clean the TB as preventive maintenance.
    270Fan and Tundra2 like this.
  13. Aug 11, 2020 at 3:18 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Ding! Ding! Ding!​
    X2 for vacuum hoses​
    After I installed my new ones I cautiously played around with unhooking hoses to see what they did, and how the engine reacted. I have a rough log stored in my brain case now for future reference.
    I ordered this kit, and loved it. We do have different engines though. Not sure how much you will need vs. How much I needed.
    Heres a link to a general post I made about them.
    Voss likes this.
  14. Aug 11, 2020 at 11:21 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  15. Aug 11, 2020 at 1:54 PM
    Hand Protectors
    bmf4069 likes this.
  16. Apr 9, 2021 at 12:31 PM
    Sip69
    Sip69 New Member
    James
    2004 Toyota Tundra
    I had this same problem. Brake booster had a vacuum leak.
    Voss likes this.
