Truck dies and restarts while driving
Discussion in '2.5 Gen Tundras (2014-2021)' started by Elfine, Dec 21, 2020.
  1. Dec 21, 2020 at 5:46 PM
    Elfine
    Elfine [OP] Doing my best to break this beast
    Pensacola, FL
    2017 Quicksand Tundra TRD
    Datin Metal Fab 18" Bed Rack, ARB Diff Breather, SDHQ ABS Guards, RCI Engine/Transmission/Fuel Skid, ICON Stage 5, Rago Bed Stiffener/Ditch light brackets, ARB twin air compressor, 295/70R18 Cooper Evolution M/T, Spydertrax 1.25" spacers
    Good evening. This issue started yesterday where the dash and radio would die and instantly restart when my traction control engaged, I was off roading. Today, I was driving down the street and the whole truck started turning off and restarting (instantly) about every second for 10 seconds while accelerating before stabilizing and not doing it anymore. When I finally got home and turned off the truck it was dead again until I removed and reinserted the key. Battery still shows full charge. I am by no means good with electrical so any help on where to start would be appreciated. Thank you!
  2. Dec 21, 2020 at 5:50 PM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    First thing I would do is bring it to Advance Autoparts and have them test the battery with their computer. Its tells alot about the battery and charging system
  3. Dec 21, 2020 at 5:58 PM
    Krackerjack
    Krackerjack New Member
    2020 Tundra TRD Sport Metallic Grey
    I had this a while back. I took it to Toyota and they finally after 3 weeks diagnosed it as a fuel pump and replaced it. Good ever since.
  4. Dec 21, 2020 at 6:12 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    It appears to be a battery issue in my opinion.. A fuel pump would have nothing to do with the radio... I've stalled out completely in drive with Toyota's batteries.. Low charged batteries tent to give weird electrical symptoms and issues..
    TheBeast likes this.
  5. Dec 21, 2020 at 6:14 PM
    Blueknights75
    Ron
    Clayton, NC
    Maybe a broken or faulty ABS sensor from off-roading??
  6. Dec 21, 2020 at 7:29 PM
    Elfine
    Pensacola, FL
    I will have it tested but I recently swapped out the battery, about 5k miles ago.
    blackdemon_tt[QUOTED] likes this.
  7. Dec 21, 2020 at 7:32 PM
    blackdemon_tt
    I probably went through 3 batteries within 5k miles, the Toyota type....
  8. Dec 21, 2020 at 7:44 PM
    zeekevin
    zeekevin New Member
    Check your battery terminals Incase they are loose
    HulkSmurf14 likes this.
  9. Dec 21, 2020 at 7:56 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Sounds like battery terminals or maybe just a loose ground...
    blackdemon_tt likes this.
  10. Dec 22, 2020 at 5:45 AM
    blanchard7684
    blanchard7684 New Member
    The connection from battery to alternator sounds like its loose, rodent chewed, or corroded.
  11. Dec 22, 2020 at 5:52 AM
    DCLarston13
    DCLarston13 New Member
    2020 Tundra Magnetic Gray TSS
    A loose battery terminal will do what you described. Check that first, it just happened to a family member and it was a loose battery terminal. You just swapped out the battery so that is the most likely cause.
  12. Dec 22, 2020 at 7:47 PM
    Elfine
    Pensacola, FL
    Right on. Apparently the nut worked itself loose and disappeared. Thank you everyone for the assistance, I feel like a moron.
  13. Dec 23, 2020 at 12:48 PM
    StoneyWV
    StoneyWV New Member
    Calvin
    Rough Country Level,
    It's really the new auto shutoff feature to conserve fuel;)
    JimboSlice413 and Cpl_Punishment like this.
  14. Dec 23, 2020 at 4:12 PM
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    This is exactly why I follow these threads...so when issues pop up I have a quick starting point to go with. Great to see that it was a simple battery connection issue.
    Brownsfanhere and HulkSmurf14 like this.
  15. Dec 25, 2020 at 12:54 AM
    PinnacleX
    PinnacleX New Member
    Bart
    2020 TRD Off Road
    Alternator battery first thing that comes to mind.
