Truck died
Discussion in '2.5 Gen Tundras (2014-2021)' started by Fishin1981, Jul 1, 2020.
  1. Jul 1, 2020 at 2:29 PM
    Fishin1981
    Fishin1981 [OP] New Member
    2015 tundra limited crewmax
    Pop and lock, esp storage, access lorado, front tints
    As I was stopped at a red light everything in truck died except for engine. I shut off and restarted the truck, engine started but all dummy lights on and I am unable to shift into drive unless pressing the over ride. Any ideas what this could be? I disconnected battery and reconnected and nothing happened
  2. Jul 1, 2020 at 2:39 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Any fuses tripped? We're Were you towing? Does your truck have parking sensors?
  3. Jul 1, 2020 at 2:43 PM
    Elduder
    Elduder New Member
    Toyota will be able to run any logged errors at shutdown if you take it in.
    NewImprovedRon likes this.
  4. Jul 1, 2020 at 4:28 PM
    rcjh0891
    rcjh0891 New Member
    Joel
    DFW
    2018 Tundra Platinum Crewmax 4x4 MGM
    Bad battery? Posts of weird stuff happening even if no obvious signs of battery totally bad.
  5. Jul 1, 2020 at 4:57 PM
    Fishin1981
    New battery. It’s a 2015 limited crewmax. Someone told me maybe alternator. Maybe truck shut down all non essential electronics to get me where I had to go and save battery. Voltage dropped stayed around 11.6
  6. Jul 1, 2020 at 5:33 PM
    Elduder
    Elduder New Member
    11.6v is way too low. Is this measured at the battery terminal?
    AZBoatHauler likes this.
  7. Jul 1, 2020 at 6:13 PM
    shakezoola
    shakezoola Not a new member
    Kansas City
    2019 Tundra TRD Sport MGM
    N-Fab MRDS Bfront Bumper w/ Rigid Industries Radiance PODS and Curved LED Light Bar TRD Skid plate Victory 4x4 Roof rack and hood mounts with Rigid industries Midnight PODS Alpine Halo9 ILX-F309TND Alpine PDR-V75 5-Channel amp powering 4x Image Dynamics component speakers Alpine S-A60M powering 1x 12" sub Fortin Remote Start with MyCar App Switch Pros SP-9100 Pop-and-Lock tailgate lock vLeds front turn signals w/switchback Center Console Safe Pedal Commander Diamond Back HD bed cover Swing Cases Driver/Passenger Katzkin Leather seats w/ heated front seats Bilstein B8 5100's Front and rear AMP Research PowerSteps Toyota TSS wheels w/ DuraTracs Toyota bed mat Bed light (LEDs) Blacked out badges Sport Antenna
    I had something similar happen to my Land Rover. The bolt on the tensioner pulley snapped. Engine still ran, but then started to over-heat, no power-steering, power-brakes, AC, etc. How does your belt look?
  8. Jul 1, 2020 at 6:16 PM
    AZBoatHauler
    So.Arizona
    Agreed. Sounds like alternator isn’t working.
    Burdturger likes this.
  9. Jul 1, 2020 at 6:24 PM
    Elduder
    Elduder New Member
    Yes possibly. Normal voltage should be >12.4ish volts when off, closer to +14v with alternator working with the battery.
  10. Jul 2, 2020 at 9:12 AM
    blueshound
    blueshound New Member
    2015 Red Tundra Platinum
    I had this happen in my Mercedes E350. Ended up a bunch of wires were chewed on by a mouse or rat in my garage. It would start and drive but my instrument panel was lit up like a Christmas tree. Took it in they replaced the $250 worth of wiring for $3000. Luckily it was covered by insurance and my deductible was $200. Moral of the story don't store deer feeder corn in your garage.
    Black Wolf and jewsNbrews like this.
  11. Jul 2, 2020 at 10:18 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Eliminate the battery as a problem first. If the battery will not charge to 12.6+ V and stay charged (disconnected from the truck), then your battery is bad even it it is new. New batteries seem to fail by dead cells and that can happen instantly. There haven't been any reports of a dead cell failure while the engine is running, but they've probably happened. Owners were likely preoccupied with trying to diagnose the chaos that happens when the engine shuts down unexpectedly.
    DR132, rcjh0891 and Buildn like this.
  12. Jul 2, 2020 at 10:43 AM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    I also have a 2017 with the original battery and the Sunday on Memorial Day weekend I drove up to the local hardware store and when I went to start it notta.
    I just had my battery checked at the dealer a week before and it was good! So I called roadside assistance out and when he tested it it said it was charged?! But wouldn’t turn over only when he put the cables on the posts. It was a bad cell, I went to Autozone and purchased a Duralast Gold and it’s been working ever since. Everything else checked out ok.
    jewsNbrews likes this.
  13. Jul 2, 2020 at 10:49 AM
    kevine0001
    kevine0001 New Member
    Kevin
    I have a 2017. A few months ago, whirring noise. Bad alternator and warranty covered it. Not sure if you have extended warranty on CPO. Either way, alternator was my problem but I caught it a little earlier than you, assuming that's your issue.
  14. Jul 2, 2020 at 10:51 AM
    Fishin1981
    Dealership called me this afternoon and told me all the computers seemed to be fried. Asked if I was in an accident recently or if truck was struck by lightening.saidnit wasn’t the alternator but the voltage was def not getting stronger with truck running.
    Buildn and jewsNbrews like this.
  15. Jul 2, 2020 at 1:27 PM
    JohnLakeman
    Before authorizing a big repair of replacing "all the computers", I would put a charger on the battery and try charging it. If/When the battery is charged to 12.6+V, I would let it set overnight disconnected. Check it in the morning. If the battery has not maintained full charge, replace the battery. It'll be worth the trouble to save thousands.
    rodm1 and Buildn like this.
  16. Jul 2, 2020 at 1:36 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    I'd take it to an independent shop for a second opinion, find someone who works on imports. I'd also make them explain to me how they got to that answer
    ekinnee likes this.
  17. Jul 2, 2020 at 1:41 PM
    Fishin1981
    Luckily for me it bought the extended warranty which is good through next year.
  18. Jul 2, 2020 at 2:37 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Oh in that case, absolutely let them fix...keep it as their problem.
    If “someone else” (other than Toyota) touches it at this point, Toyota will claim someone else has mucked with it and wont honor the warranty claim.
    You bet against Toyota with the warranty and they lost the bet.
    I do however, agree with swapping out the battery just to see what happens...electrical gremlins can do weird shit.
    Besides, if the computers were fried it would not start/run at all. So right there, the tech’s analysis isn’t making sense.
    kevine0001 likes this.
  19. Jul 2, 2020 at 3:40 PM
    Fishin1981
    So they called me back and said that whoever installed the aftermarket remote starter hooked it up to the wrong spot. Cost me $290 to disconnect starter and rewrite whatever was messed up. ? This sound legit?
  20. Jul 2, 2020 at 4:22 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    I might have missed it, but did you pay to have an aftermarket electric start installed?
    If it was hooked up wrong, this problem would have presented it self the first time you turned power on after the install???
  21. Jul 2, 2020 at 5:17 PM
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    Posts like these I follow daily, it's always good info to absorb in the event that something similar happens to mine. It's amazing how often the Achilles heel of these trucks seems to be the batteries and aftermarket electrical work.
    texasrho83 and Elduder like this.
  22. Jul 2, 2020 at 5:39 PM
    Elduder
    Elduder New Member
    Yes, it is possible. I personally would ask though for the tech that figured it out to detail it for me. Just because I have some difficulty trusting other mechanics.
    $290 is steep though, especially if it was harnessed remote start and was plug and play.
    rockmup likes this.
  23. Jul 3, 2020 at 9:36 AM
    Fishin1981
    Final update: picked up truck today and dealership told me whoever installed remote start pulled on a wire uber fuse box while making his connections. It disconnected over time because it was loose. Reconnected wire and everything was fine. $315 for labor, $0 for parts.
    Haggis777, jewsNbrews and kevine0001 like this.
  24. Jul 3, 2020 at 9:46 AM
    kevine0001
    Kevin
    Like others, I'd have some questions, but glad to hear it didn't hurt that much to get it fixed...and it wasn't the actual truck!
  25. Jul 3, 2020 at 2:28 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Went from all the computers fired to the car starter? :monocle:
    JohnLakeman likes this.
  26. Jul 3, 2020 at 3:03 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    when they found out it was under warranty they realized the game was up and they would actually have to diag it. They were hoping he was just going to pay out of pocket. No way the warranty rep isnt going to ask questions about all the ecus being replaced.
  27. Jul 3, 2020 at 3:46 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    He should tell us what stealership that was so everyone can avoid it.
  28. Jul 3, 2020 at 3:49 PM
    Crunch527
    Iowa
    Yep...warranty ups the ante and one thing about electrical problems, they can give so many spurious indications one cant get pulled into the weeds trying to chase the book answer...you have to resort to some real troubleshooting.
    Glad they figured it out...
  29. Jul 3, 2020 at 4:42 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    That sounds like a crooked maintenance department in the dealership. Please post the dealer name so others can avoid it.
  30. Jul 3, 2020 at 6:24 PM
    LSUTundra
    LSUTundra New Member
    Same thing happen to me, no indications of the battery going bad. Just jumped in the truck to go and nothing. I didn't realize they could die so suddenly. I picked up a Gold as well.
    Buildn[QUOTED] and jewsNbrews like this.
