Truck cranks and immediately shuts off
Discussion in 'Electrical' started by Nikostas, Aug 7, 2022.
  1. Aug 7, 2022 at 10:54 AM
    Nikostas
    Nikostas [OP] New Member
    Nick
    Toyota Tundra
    2 inch Wheel spacers, leveling kit
    2016 SR5 5.7L V8 got home the other day from grocery store unloaded the truck and decided I was going to reposition truck.. hopped in truck starts and immediately shuts off.. after checking the battery, and crossing it off I have been left stumped.. I had just filled up on gas before heading home so we caught a sample and gas looks fine, another forum I had read mentioned removing the MAF sensor to see if it would start and still no luck.. I’m beginning to think it is an electrical or computer or theft mode issue? Truck will crank and then immediately shut off.. any help would be greatly appreciated
  2. Aug 7, 2022 at 11:29 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Crank and start and shut off or crank and then the starter falls off?
  3. Aug 7, 2022 at 11:43 AM
    Nikostas
    Nick
    Toyota Tundra
    Crank an start and shut off.. rpm’s get up to 2k and come right back down
  4. Aug 7, 2022 at 11:46 AM
    ScenicRoute
    How did you check the fuel quality?
  5. Aug 7, 2022 at 11:50 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Did you check the battery voltage while it's cranking? I've had this happen when the battery is marginal.
    Can you stop it from stalling if you press the accelerator?
  6. Aug 7, 2022 at 12:15 PM
    Nikostas
    Nick
    Toyota Tundra
    I did check the voltage while cranking, seems a bit low to me at a 12.5.. I removed battery and brought to autozone was gonna just replaced it but their tester showed good battery.. so I brought home and charged for 30min on 12v 6amp charger still having same issue.. if it was the battery though, wouldn’t the truck not crank at all? After the crank the power should be distributed from alternator correct?
  7. Aug 7, 2022 at 12:19 PM
    BozickA88
    BozickA88 New Member
    2022 Tundra
    Fuel pump controller is bad. It’s above the left rear wheel you can see the 1 12mm nut holding it to the frame from the outside.
    texasrho83 likes this.
  8. Aug 7, 2022 at 12:20 PM
    blenton
    blenton New Member
    12.5 while cranking is fine. In fact, if you let the vehicle sit a few hours and go crank it, it can dip down to 11 while cranking and still be fine. Nominal voltage after resting is 12v.
    Sounds like a fuel pump or fuel related to me. Is your truck a flex fuel, by chance?
    EmergencyMaximum likes this.
  9. Aug 7, 2022 at 12:31 PM
    Nikostas
    Nick
    Toyota Tundra
    I don’t think it is.. I considered that as well
  10. Aug 7, 2022 at 12:43 PM
    Nikostas
    Nick
    Toyota Tundra
    Just went and tried to crank for the first time today and truck won’t fully crank now? Where as for the passed two days it has cranked and shutoff
  11. Aug 7, 2022 at 12:52 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I'm not a mechanic but as others have suggested it certainly seems like a fuel delivery issue.
    You were getting minimal fuel that turned over the engine, now you aren't getting any.....
    Back in the good old days, we could drip a little gas into the carburetor..:D
    Welcome to the forum..:thumbsup:
  12. Aug 7, 2022 at 1:04 PM
    Nikostas
    Nick
    Toyota Tundra
    Appreciate the responses
  13. Aug 7, 2022 at 1:54 PM
    MogwaiBoogie
    MogwaiBoogie New Member
    Justin
    TEXAS
    2020 Tundra Platinum
    Did you happen to be using remote start prior to this happening?
  14. Aug 7, 2022 at 2:18 PM
    Nikostas
    Nick
    Toyota Tundra
    No I don’t have one
  15. Aug 7, 2022 at 5:17 PM
    MogwaiBoogie
    Justin
    TEXAS
    well then I got nothing! Sorry brother, good luck
  16. Aug 7, 2022 at 6:08 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Even if you told me the battery is 6 months old I wouls still replace it and wholly eliminate that "easy fix" first. Then move to the fuel system.
  17. Aug 7, 2022 at 6:18 PM
    IgotSR5onit
    IgotSR5onit New Member
    Havent had any fuel pump issues with my toyotas so I can speak on them, but when testing my chevys fuel delivery one thing I would do is just unhook the fuel filter and see if its pumping.
  18. Aug 8, 2022 at 3:14 PM
    Nikostas
    Nick
    Toyota Tundra
    So after towing to the dealership.. they run a diagnostic to find that the immobilizer ECM is causing an error.. they want to do a full replacement on that ECM for 2k.. talked to the tech about trying to reset or reprogram that ecm.. they did so and still no luck.. has anyone ever had issues with their keys possibly causing this issue? Like a theft mode issue? When I went to re position the truck the day that is happened I grabbed my wife’s set of keys (which I don’t normally do).. I know that the keys sent out a specific code set.. I’m just trying to weigh out options other than replacing the ecm right away.. does anyone think that wiping the keys would be a valueable option? And if it was they keys would their be a diagnostic code that the tech would see, or does the truck not provide that?
  19. Aug 8, 2022 at 3:23 PM
    blenton
    blenton New Member
    Man, that sucks. I've heard of that happening on other vehicles and had the suggestion running in the back of my head, bu every other time I suggested the immobilizer as being problematic, it turned out to be a fuel pump. Go figure.
    I've seen it happen on a vehicle that was locked with one key, then unlocked with a different key, but it was resolved by locking and unlocking with the original key a few times. Or maybe locking with the offending key, unlocking with the original key, turning the key in the ignition while rubbing the dash and whispering sweet nothings into the air vents while thinking positive thoughts of a raucous cacophony of V8 rumble... or some sort of witchery. I don't remember exactly, but something worked out.
    Perhaps try programming a new key to the current ECM? It would be cheaper than an ECM replacement.
  20. Nov 2, 2022 at 6:32 PM
    PonyMan
    PonyMan Old Man
    Central, Louisiana
    2021 Tundra CrewMax 4WD Limited Nightshade Special Edition MGM
    Any update on where this ended up? Hopefully wasn't too bad.
