Truck bed shaking
Discussion in '3rd Gen Tundras (2022+)' started by Mattster74, Mar 17, 2022.
  1. Mar 17, 2022 at 6:27 PM
    Mattster74
    Mattster74 [OP] New Member
    2022 Tundra TRD OR
    Hi there, I just purchased my 2022 Tundra TRD Off Road about 7 weeks ago, although I've been driving Toyota trucks for 31 years. I love everything about this truck except the bed shaking extremely bad and acting like it's going to fall off. Has anyone had any issues when driving down a bumpy road the bed shakes and makes a horrible sound? I can actually see it moving. Thank you
  2. Mar 17, 2022 at 6:29 PM
    Taco-Spike
    Two Trucks
    Wuuut?
    like it’s not bolted on all the way?
    boostedtrdpro likes this.
  3. Mar 17, 2022 at 6:33 PM
    Mattster74
    2022 Tundra TRD OR
    EXACTLY, but the dealer checked the bolts and everything checked out fine. This acts like it's going to fly off and earn its wings when I'm going down a bumpy road.
  4. Mar 17, 2022 at 6:52 PM
    CamaroSsToTundra
    CamaroSsToTundra New Member
    Ohio
    2018 Tundra
  5. Mar 17, 2022 at 6:54 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
  6. Mar 17, 2022 at 8:55 PM
    trevorstuart24
    trevorstuart24 New Member
    Check the bed bolts yourself. Mine were loose at one point. I think they got stripped
    Mattster74[OP] likes this.
  7. Mar 17, 2022 at 9:09 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I wouldn't be shocked if the dealer didn't even check them. They pulled it around back and brought it back...yup, everything is good. I haven't gone off-roading, but I have not noticed any movement or vibration on normal road bumps, speed bumps, etc.
    gman54313 and Mattster74[OP] like this.
  8. Mar 17, 2022 at 9:10 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Can you by chance get your hands on a GoPro or something and upload a video? Cause I’ve seen bed bounce, but you’re making this seem awfully dramatic. Not trying to discount what you’re saying, just really interested in just how bad it is…for science :D
  9. Mar 18, 2022 at 12:09 AM
    Tundra@Guam
    Tundra@Guam New Member
    2022 SR5 Tundra CrewMax
    Yes, I have experienced that same issue. It is very annoying. I checked the spare thinking maybe it's loose, but it's okay. Thinking maybe it's due to the new suspension design. This is really bad as the truck gets older, the sound will get worse and bed may eventually fall off.
  10. Mar 18, 2022 at 1:24 AM
    Troyboy84
    Troyboy84 New Member
    BC Canada
    2022 SR5 TRD Offroad
    I’ve noticed a lot of noise when the crew max rear cab window is down. I can’t say for certain that the bed is loose or shaking but it sure sounds like it, or at least something isn’t secure in the rear of the truck.
    Mattster74[OP] and Rwaters like this.
  11. Mar 18, 2022 at 2:03 AM
    TTund16
    TTund16 New Member
    Didn't the older models (21 and older) have the bed bounce? I've seen those videos but people are driving too fast over the bumps.
    Didn't Toyota change the triple tech frame design to something new for '22? Shouldn't that get rid of the bed bounce?
  12. Mar 18, 2022 at 5:24 AM
    Kung
    KG, VA
    The old Tundra does 'bounce' more; and yes, the new frame should get rid of the bed bounce - to some degree.
    I live down a gravel road and can tell you that there's no such thing as a truck that won't bounce under the right conditions (though I'm sure you know this, LOL). My Tundra bounces a tad more on our gravel road; but my F150 bounced like *crazy* on expansion joints on the interstate.
    Additionally, it's been my experience that quad cabs/CrewMax trucks are less bouncy than extended cabs/double cabs. Has to do, I'm told, with the length/type of the drive shaft, length of the bed, etc. I know it's been absolutely true in my case - the 3 previous extended cab trucks bounced like crazy whereas my CrewMax is smooth as can be.
  13. Mar 18, 2022 at 5:29 AM
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    I’ll second that statement
  14. Mar 18, 2022 at 5:51 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    The noise when y’all’s rear window is down is the window’s cable banging around inside the rear panel of the cab. Lots of trucks do it. Maybe you can get Toyota to fix it for you, but the manual says don’t drive with it down, so good luck.
    You can fix it yourself: you just need to remove the rear seats and add some foam or felt on the inside of that panel where the cable rattles around in there.
    My 2nd gen has a *bit* of bed bounce when empty on concrete seamed highways. What you guys are describing sounds like something else entirely. Get a ratchet and a T55 bit and check ‘em yourself. I just don’t trust any dealer to tell me things that are actually true.
    Kung likes this.
  15. Mar 18, 2022 at 6:00 AM
    Rwaters
    Rwaters New Member
    I’ll take a bouncy cable over a bed any day
    Terndrerrr[QUOTED] likes this.
  16. Mar 18, 2022 at 6:15 AM
    Mattster74
    2022 Tundra TRD OR
  17. Mar 18, 2022 at 6:18 AM
    Mattster74
    2022 Tundra TRD OR
    It was around 81° yesterday and going down the road that bed still shook and sounded horrible. I'm going to put my kid in the back seat and get him to video it.
  18. Mar 18, 2022 at 7:23 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Yup, my 2020 with a bit over 8k miles ( and from the beginning) bounces and shakes like crazy on potholes and stutter bumps. I thought my spare tire was loose at first, but after doing research it was a pretty common thing.
  19. Mar 18, 2022 at 7:27 AM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    I always noticed the bed "bounce" quite a bit on my '18. I haven't had my new Tundra on a rough road yet, so can't speak to that. I think some of the noise is from the rear window in the down position. I am really disappointed with that. The rear window on my '18 didn't have any rattle in it when it was in the down position.
  20. Mar 18, 2022 at 7:38 AM
    Mattster74
    2022 Tundra TRD OR
  21. Mar 18, 2022 at 7:38 AM
    Mattster74
    2022 Tundra TRD OR
    Thank you
  22. Mar 18, 2022 at 11:05 AM
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    I've noticed there is significantly more bed bounce going over large bumps comparing to my TRD Pro 4 Runner. Certainly size of wheel base and actual body a factor. I also think its a rear shock issue. I have a TRD OR Tundra and am on the fence thinking I will upgrade the rear shocks that should take care of additional noted bounce.
  23. Mar 18, 2022 at 11:07 AM
    Mattster74
    2022 Tundra TRD OR
  24. Mar 18, 2022 at 11:09 AM
    Mattster74
    2022 Tundra TRD OR
    I've had people telling me that they'll do a shock upgrade. I'll possibly do that. 31 years driving Toyota trucks and this is the first
  25. Mar 18, 2022 at 11:15 AM
    Terndrerrr
    Music City
    6UR-FE
    Read all the threads on the 2nd gen bed bounce. There's really nothing you can do to totally eliminate it. For me, the TRD Pro suspension kit helped. So does a few hundred pounds riding in the bed. I only experience it on seamed concrete highways.
    Might be different for y'all 3rd gen'ers. But it seems that heavy front + our wheelbase + lightweight rear = some degree of bed bounce.
  26. Mar 18, 2022 at 11:36 AM
    Mattster74
    2022 Tundra TRD OR
  27. Mar 18, 2022 at 11:39 AM
    Mattster74
    2022 Tundra TRD OR
    Ok, I'm already in the market for a leveling kit just a 1.75 up front.and I'm thinking about a spray on bed liner and bed cover. So maybe that will help.
  28. Mar 18, 2022 at 12:08 PM
    Hadelson
    Hadelson New Member
    Sitting back and waiting for available options to open up. Hopefully soon.
  29. Mar 18, 2022 at 12:10 PM
    Hadelson
    Hadelson New Member
    On the fence with this as well. Did a one inch on the 4Runner and made significant improvement.
  30. Mar 19, 2022 at 6:24 PM
    Summit72
    Summit72 New Member
    Summit
    2018 Tacoma TRD OR LB
    I have a Rc level kit that I’ll sell for cheap. If interested, will ship went with wescott.
