Truck at stealership need help!
Discussion in '2nd Gen Tundras (2007-2013)' started by scrapper01, Mar 30, 2024.
  1. Mar 30, 2024 at 1:39 PM
    scrapper01
    scrapper01 [OP] New Member
    2010 Tundra, original owner.
    tranny was throwing a P0894, dealership determined I need a new tranny. No big deal, truck had a lifetime power trane warranty when I bought it. So I battled gladiator style with the warranty company to cover the replacement.
    Now the new tranny is in and the tech is saying it shifts hard into drive and the want to replace the ECM, ECM is not covered under the power trane warranty. $1300. I am pushing back because that is not a symptom the truck ever before. They are claiming the tranny damaged the Ecm.
    any help, is appreciated before I wage a holy war.
  2. Mar 30, 2024 at 3:08 PM
    2mchfun
    Been down this road. Throw in a used ECM and roll on.
    1lowlife likes this.
  3. Mar 30, 2024 at 4:25 PM
    scrapper01
    Interesting, if you care to share more info please feel free. Is the Ecm behind the glove box?
  4. Mar 30, 2024 at 8:06 PM
    2mchfun
    In my case it was a Ford transmission about 18 yrs old. Popped in a used ECM for like $75 and it was GTG.
  5. Mar 30, 2024 at 8:31 PM
    Txexplorer23
    Txexplorer23 New Member
    2020 Tundra Crewmax Platinum 4x4
    Just ask them to explain how/why the ecm would be causing it to shift into gear hard.
  6. Mar 30, 2024 at 8:57 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Is there not an ECM reset / relearn procedure to follow (with Techstream) when these transmissions are replaced? I honestly am not sure as I haven’t had to go there on my Tundra, but there certainly was on the electronically controlled transmissions I’ve replaced.
    Those were Allison 3000 series and larger, so a bit different, but not really other than size. The ECM learns and adapts to clutch pack wear (which equals slower to shift) minor internal leakage, etc. Drop a fresh reman in without telling the ECM, and they’d shift very harshly for quite a while as the ECM slowly adapted.
    Lifer and Toyotoholic like this.
  7. Mar 30, 2024 at 9:48 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I would go for a test drive with the tech and confirm what they are saying. Second, as @landphil said, the ECM will want to learn a new component as it has not been aquatinted with it. Driving it should acclimate the two and smooth things out. BUT! I don't buy the tranny killed the ECM BS. It would be the TCM for the tranny not so much the ECM. The ECM is for the control of the motor and TCM is for the transmission. Just smells off to me, idk I could be wrong.
  8. Mar 30, 2024 at 10:06 PM
    wauto
    wauto New Member
    mike
    Need Techstream or the like.
    Powertrain / Engine and ECT / Utility / Learning Value Reset,
    Powertrain / Engine and ECT / Utility / Fuel Density Learning Value Reset ?
    Or just drive it. Should figure stuff out on it's own.
    Mdl and landphil like this.
  9. Mar 31, 2024 at 10:26 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    When I replaced my ab60e trans I had no issues. Didn't do a relearn just disconnected battery for 30 min. It will relearn the shifting values over time. Dealer should have done a learning value reset as previously stated.
  10. Apr 12, 2024 at 5:26 AM
    scrapper01
    OK, guys. I have an update and a BIG question. The truck is still at the dealership, and they still can't figure out the issue. This morning, as I was still lying in bed and pondering life, I remembered that when I did the lift/wheels/tires, I had to install a separate box (Hypertech 730103) to calibrate the speed-o. Could that cause problems for the dealership when they try to flash the ECM?
    Now, the question is, do I tell them about it? I am kind of nervous about it because they have spent tons of hours troubleshooting this thing, and I think the service advisor told me the hourly labor rate is $200, which is totally outrageous. I need to get this figured out and come up with a plan of attack.
  11. Apr 12, 2024 at 7:19 AM
    Rakso
    Rakso Tundra + Tacoma=Winner
    Oskar
    18 CM Super White 4X4
    TRD sway bar, TRD filter
    Classic.
    Go to war.
  12. Apr 12, 2024 at 7:31 AM
    This could be the issue.
