TRS lights- 2016 Tacoma issue?
Discussion in 'Lighting' started by T-Rex266, Sep 14, 2016.
  1. Sep 14, 2016 at 4:50 PM
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Before anyone retrofits their lights- at least on a Tacoma, I highly suggest you read this thread.
    TL;DR version:
    -OP had his truck on a beach. He power washed it after.
    -Truck threw codes went into limp mode.
    -Techs scratched their head and finally determined it was a bit of sand that got into fuel tank.
    -$14k insurance claim later- "fixed"
    -OP power washed the truck again- same issues.
    -Tech said its his retrofitted lights.
    -OP went back to stock lights.
    -OP power washed - zero issues.
    MotoTundra likes this.
  2. Sep 14, 2016 at 5:04 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    That's a good suggestion and heads up Sean, I did mine and went back with new butyl sealant, then back over with marine rtv. I will definitely let the pro's do my next one. :cool:
    T-Rex266[OP] likes this.
  3. Sep 14, 2016 at 6:35 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Well I didn't plan on spending an hour looking into this but I have a Morimoto setup from TRS so off I went.
    After being an internet warrior and reading some things, it seems like the mounting location of ballasts could be important. From what I've read, there could be interference from the ballast if it's placed very close to an ECM, on metal like AC lines, and probably groups of wires.
    I don't know if that played a role in TW OP's case, but definitely something to keep in mind. I would imagine salt water could promote that interference. Salt and salt water are just plain bad news for vehicles.
    Aside from OP having a Tacoma, even the HID setup is different from what our Tundra's would take.
    On a side note, when I did my retrofit I removed the metal mounting frames from my XB35 ballasts and velcro'd the ballasts directly to the back of my headlight housing (plastic). No issues yet, hopefully none ever.
    Thanks for sharing the thread @Sean266
    HBdirtbag and T-Rex266[OP] like this.
  4. Sep 14, 2016 at 7:31 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    By no means should that reflect on TRS products. I won't even get started on this topic. I've said what I needed
  5. Sep 14, 2016 at 9:16 PM
    I think it's the Toyota design on the Tacomas...
    Apparently someone had a similar issue on their F150.
    I'm not educated enough to know how everything works though.
  6. Sep 14, 2016 at 11:24 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    But... By posting on this topic doesn't that mean you made a start? :laugh:
  7. Sep 15, 2016 at 6:20 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    NO comments
    TruckyTruck[QUOTED] likes this.
  8. Sep 15, 2016 at 7:48 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Haha
  9. Oct 2, 2016 at 6:31 PM
    And another one....bummer. Good looking product too.
