Trouble with 4 wheel drive
Discussion in '2.5 Gen Tundras (2014-2021)' started by Striperfishing, Mar 24, 2025.
  1. Mar 24, 2025 at 6:01 PM
    Striperfishing
    Striperfishing [OP] New Member
    I noticed after purchasing the truck and trying to go into 4wd it would not go in after leaving it on the 4hi selector and turning the vehicle on and off it would go in fine, same thing to get it back into 2wd. When the key is in the on position but vehicle is not running it will go in and out fine. Any ideas what this might be?
  2. Mar 24, 2025 at 6:05 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Was it flashing? Sometimes you just need to move forward a little or backup a little, slowly. Occasionally turning the wheels helps too (slightly not hard).
    Tundra Texan likes this.
  3. Mar 24, 2025 at 6:07 PM
    Striperfishing
    Yes light flashes, I have tried park, neutral, drive, and driving at a slow speed. I’ve left it for a few mins flashing waiting to see if it would switch over and still nothing.
  4. Mar 24, 2025 at 6:08 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Got it, hmm that does indicate an issue then, may be a sensor or the actual actuator has an issue, others will know more.
  5. Mar 24, 2025 at 6:31 PM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum Tundra
    When it's in 4 Hi, with the truck running and stopped, if you shift to neutral and put it in 4 Lo, then shift to drive and start moving forward, does it shift into 4 Lo?
  6. Mar 24, 2025 at 6:33 PM
    koditten
    Kirk
    Midland of the Mitten
    Any issue with speed sensors?
    Does the cruise control work?
  7. Mar 24, 2025 at 6:34 PM
    Striperfishing
    Haven’t tried the 4lo will try that tomorrow. And speed sensors seem to be spot on no issue with cruise control.
    koditten likes this.
  8. Mar 30, 2025 at 10:28 AM
    2020_Tundra
