Trouble maintaining highway speeds...
Discussion in '1st Gen Tundras (2000-2006)' started by Backcountry_explorer, Aug 19, 2020.
  1. Aug 19, 2020 at 1:05 PM
    Backcountry_explorer [OP] New Member
    2006 White Tundra TRD
    2.5” lift w/33’s
    Hello all, new to the forum and Tundra ownership. Hoping some of you can shed some light on an issue I have had with my new to me Tundra. Mainly, it’s just a lack of all around power available. It is somewhat apparent at city speeds, but more pronounced when I get her on the highway. She seems to be turning about 2300 rpm at 70, and at almost any rise in the roadway surface she has to downshift just to keep at speed. I went the first gen tundra route because of the v8 so I could still pull my Polaris ranger, but I don’t think she could handle getting it down the highway as is. My question, is this normal behavior? If not, where should I be looking to solve the issue? Are the over sized tires the problem? When I let off the gas it feels like I am driving in sand and she starts pulling me slower and slower, there is no coasting. Any help would be appreciated.
  2. Aug 19, 2020 at 1:34 PM
    Professional Hand Model
    Hand Protectors
    Do a shake down check of fluids levels in transmission and rear diff. Check rear brake shoes possibly sticking.
    revtune likes this.
  3. Aug 19, 2020 at 1:36 PM
    2.5” lift w/33’s
    First thing I did was completely rebuild the drums. Nothing changed, but it does stop great now. I will do a fluids check on those next.
  4. Aug 19, 2020 at 1:37 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My grandfather had a similar issue on his GMT-400. I think his resolution was to replace the fan clutch but I'm not sure how he determined that was the problem or if Tundras tend to have those go as they age.
    revtune likes this.
  5. Aug 19, 2020 at 1:43 PM
    2.5” lift w/33’s
    Funny you say that. I have noticed the fan spooling up constantly and sapping 75% of engine power regularly. I haven’t thought much of it considering it’s been 100+ F the last few weeks. It has made me want to ditch the mechanical fan altogether and retrofit for electrical.
  6. Aug 19, 2020 at 2:58 PM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    Possibility of the catalytic converter plugging up comes to my mind. Had a car in HS with that problem, but it had a noticeable power drop at all times - not just at hwy speeds.
  7. Aug 19, 2020 at 3:15 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm along the same lines of dragging brakes or clogged cats. Do you have any kind of IR scanner or temp gun? It can check both brakes and cats.
    revtune likes this.
  8. Aug 19, 2020 at 3:18 PM
    2.5” lift w/33’s
    I have an ir camera. I’ll check the cats. Pretty much positive it’s not brakes. I haven’t smelled them at all and have taken it on a 1100 mile road trip. what am I looking for when I inspect for clogged cats?
  9. Aug 19, 2020 at 3:20 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    There'll be a temp difference somewhere. I don't remember off hand what it is, but I think the cats will be hotter than they should. Also, my rear brakes were dragging bad, and I never smelt them. They got pretty damn hot though.
  10. Aug 19, 2020 at 3:22 PM
    2.5” lift w/33’s
    I’ll look in on them to be safer than sorry. Any idea what temp range the cats should be in normally? I’m coming from a diesel which run really high egt’s
  11. Aug 19, 2020 at 3:26 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I think you check before and after the cat.
    Same = bad
    Plus temp on exit = good.
  12. Aug 19, 2020 at 4:43 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    This got my attention, I think this same issue is happening on one of my tundras. Is your truck all stock? No lift, big tires etc?
  13. Aug 19, 2020 at 4:48 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Hmm interesting, during 100 degree weather, if my truck idles, say in a drive through, I get a pretty audible fan roar and loss of power until I get the truck moving again at good speed. I thought about replacing the fan clutch and possibly the radiator. Does your truck do anything like I’ve described?
  14. Aug 19, 2020 at 5:11 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Normal, that's how it should work. Clutch locks up when it heats up and unlocks when the temp drops.
