Trouble Finding Seals
Discussion in '1st Gen Tundras (2000-2006)' started by zcr, Mar 16, 2019.
  1. Mar 16, 2019 at 1:52 PM
    zcr
    zcr [OP] New Member
    Zach
    04 Blue DC Tundra SR5
    Under mounted 3 gal air tank, compressor and helper springs, flush mount auxiliary reverse lights, 41" light bar in front bumper, stereo system with 2 8" subs, LED headlights and interior light, yellow fog lights, and blue dash lights.
    Hey guys, my name is Zach, this is my first post on this forum. I drive a 2004 Tundra DC. I was looking into getting the window seals that go on the outside of the window at the bottom because mine are all worn out, and when I called Toyota their pricing was outrageous (Almost $150 a piece). And my local parts stores don't have them. Does anyone know what those seals are called and where I can get them cheaper?
    Also, the seals that run along the roof on each side (no sunroof) are popping up, does anyone know where to find those?
    And final question: is there some sort of master seal kit you can buy for this stuff?
    Thanks for the help
  2. May 4, 2019 at 10:25 AM
    MSbowhunter48
    MSbowhunter48 New Member
    2011 White Tundra Rock Warrior Edition
    Fat Bob’s 3/1 Leveling kit Rock Warrior Wheels 317/70R17 Cooper AT3 XLT
    Bump cause I’m looking for the same answer.
  3. May 4, 2019 at 8:06 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If you need help with parts @Roman .
    Roman likes this.
  4. May 4, 2019 at 8:08 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    Find part number then call junkyards.
  5. May 5, 2019 at 12:29 PM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Belt Weather-Strip - Toyota (68160-0C010) for the window glass.
    I think this is the part you want. Price I saw at an OEM online Toyota dealer was about $48.00 each and the roof drip molding part, if that's what you want
    Drip Molding - Toyota (75551-0C010) is about $90.00 each. Not cheap, but OEM parts are usually much better quality and fit that aftermarket replacements. Use these and you won't ever have to replace again. Cheers.
  6. May 5, 2019 at 4:23 PM
    MSbowhunter48
  7. May 5, 2019 at 7:08 PM
    MSbowhunter48
    Oh hell I just realized you’re looking for an 04 model. My apologies, the link I sent was for 07+ models.
  8. May 6, 2019 at 8:49 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
