Trim Restorer?
Discussion in 'Detailing' started by Rocko9999, Oct 26, 2021.
  1. Oct 26, 2021 at 10:02 AM
    Rocko9999
    Rocko9999 [OP] New Member
    What is everyone's go to trim restorer? Most that I have tried only last a month-6 weeks.
  2. Oct 26, 2021 at 10:06 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  3. Oct 26, 2021 at 1:44 PM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    I'm sure you'll get better advice than this but here goes:
    I used "clutch" from Shine Supply after using their cleaner to deep clean the plastic first.
    I left clutch on and did not wipe off. This also works wonders on the spray coat on the bed (linex).
    However, you have to clean the plastic off first. I have plastics i cleaned and treated that still outshine stuff from 2 years ago. the spots i didn't deep clean first the stuff wiped off pretty quick.
    good luck
  4. Oct 26, 2021 at 1:50 PM
    2mchfun
    Frequent application of Mcguires ultimate black here on some things others get Starbrite marine protectant. Some get both.
    Rocko9999[OP] likes this.
  5. Oct 27, 2021 at 5:20 AM
    briarpatch
    briarpatch New Member
    Cerakote or Cquartz Dlux
  6. Oct 27, 2021 at 6:22 AM
    frichco228
    I use this stuff on tires, works great, sticks thru some rain storms but eventually rinses away.....but always Cerokote on plastic trim because it lasts so long. Treated several areas on the truck with it a year ago and they still look freshly done.
    TRDFerguson likes this.
  7. Oct 27, 2021 at 7:12 AM
    justcuz
    justcuz 2.5 Gen Member
    I use this
  8. Oct 27, 2021 at 10:07 AM
    Rocko9999
    I was worried the wipes won't get into the areas on the rail/bumper plastic with the raised texture of the plastic.
  9. Oct 27, 2021 at 10:07 AM
    Rocko9999
    I have this and unfortunately it doesn't last more than a month or so.
    RitcheyRch and Rodtheviking like this.
  10. Oct 27, 2021 at 10:12 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Take your time. Be methodical about complete/even coverage the first time. If you’re a half asser find someone who’s a little ocd. The wipes are very wet so soaking into texture isn’t a problem.
    frichco228 likes this.
  11. Oct 27, 2021 at 10:12 AM
    2mchfun
    Lucky you, seems like I am doin good if I get 10 days out of it. I would be ecstatic to see a month! Not a big deal since I try to clean the truck weekly. Between it and my 4Runner, I get some exercise in!
  12. Oct 27, 2021 at 10:18 AM
    Rocko9999
    Ok, thanks.
  13. Oct 28, 2021 at 4:48 AM
    War Machine
    War Machine SSEM # 5 3MW
    Restore - Solution Finish
    Protect - Cerakote
    Best all around at both - Shine Supply Trim Shield. (Doesn’t restore as well as Solution Finish, or protect as long as Cerakote, but is better than both in the areas they’re weak in. )
  14. Nov 11, 2021 at 9:44 AM
    Rocko9999
    Got some of this and tried it out on our Corolla cowling. Followed instructions, cleaned, let dry, etc. Definitely made it very dark-problem is it's streaky. Maybe it does better on textured plastics?
  15. Dec 23, 2021 at 11:38 AM
    thumper_racer
    thumper_racer Not a New Member
    TN
    2012 MGM Rock Warrior
    I have tried many different kinds and found Black WOW Trim Restorer to work pretty good. The key is multiple coats and a little goes a long way. Got some Wolfgang trim sealant that I tried on my wife's car and it worked well. I haven't found any that last unless you put a topcoat of protectant on them.
  16. Dec 28, 2021 at 12:22 PM
    Rocko9999
    Yeah, short of painting, I don't think any of these restorers last more than a few months.
    RitcheyRch likes this.
  17. Jan 5, 2022 at 6:53 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I'm old school . . . still using 303 protectant.
  18. Jan 5, 2022 at 6:54 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    X2 x3 x4
    War Machine[QUOTED] likes this.
  19. Jan 9, 2022 at 4:43 PM
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Solution Finish by a million. Follow with a ceramic of your choosing to lock it in even longer (Cerakote, Undrdog Pro, etc).
  20. Jan 9, 2022 at 5:03 PM
    Borador
    Borador New Member
    Olive Branch, MS
    2016 Crewmax 4x4 w/1794 Interior upgrade
    I'm also a fan of the Shine Supply products!
