Trim detail and conditioning tool?
Discussion in 'Detailing' started by frichco228, Feb 29, 2020.
  1. Feb 29, 2020 at 7:00 PM
    frichco228
    frichco228 [OP] Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Do you use anything special when applying plastic conditioners to keep products off paint?
    I am careful, using microfiber cloths but still get some on paint edges close by.
    What is a better application method?
    dspilot likes this.
  2. Mar 2, 2020 at 10:35 AM
    DRP82
    DRP82 New Member
    Austin, TX
    2015 MGM CrewMax
    I use a foam applicator to apply product to my plastics trim pieces
    BobaChris likes this.
  3. Mar 2, 2020 at 11:33 AM
    BobaChris
    BobaChris New Member
    2017 Cement Grey Tundra TRD Pro
    I do the same as DRP82. Picked up a set of different sized foam brushes at Michael's for $8.99.
    I picked them up for a different project, but have worked great when applying rubber/plastic conditioner on my exterior trim.
  4. Mar 2, 2020 at 12:28 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I use a foam applicator or a MF towel, then I just buff the areas where it got on the paint. Then always buff again about an hour later so you don't get run off from the rain
