Tried to put in LED exterior lights, had to put bulbs back in now it won't start
Discussion in '2nd Gen Tundras (2007-2013)' started by Austringer, Dec 3, 2021.
  1. Dec 3, 2021 at 7:36 PM
    Austringer
    Austringer [OP] New Member
    2007 Double cab 4WD,78" bed, silver,5.7 liter
    K&N air filter. Clean mass air flow sensor. Put on a set of Michelin Defender LTX-MS tires. put Snake Oil in engine. All trying to get better gas mileage. Put Plano box in bed behind cab and bolted it to the bed
    I ordered some LED lights and tried to put them in front park and turn signal dual bulb. I put one in and turn signal worked, put second on in blows fuses. they said I need another flasher. I put the bulbs back in, now it won't start. Turns over. I have checked every iIGN related fuse and all are good. Still won''t star even with a jump. The starter runs after I turn the key off, a few seconds.
  2. Dec 3, 2021 at 7:47 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    LED's do some funky stuff to our trucks sometimes, have you tried disconnecting the Battery ground cable for a few minutes and trying again?
