Tree sap removal
Discussion in 'Detailing' started by Joeshaker, Mar 4, 2017.
  1. Mar 4, 2017 at 10:08 PM
    Joeshaker
    Joeshaker [OP] New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    Suggestions for getting sap off without scratching the paint. Bug and tar remover? I use butter to get it off my hands, works great. It probably won't hurt the paint, but then you have to get the butter off. We have some big trees that drip sap on everything, so I need something that can be used on a regular basis that's not to expensive or time consuming. Tree sap's bad for the paint, especially black.
  2. Mar 4, 2017 at 11:01 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I've got sap on black too, sucks. I tried Goo Gone. I got some of the smaller spots off but the big ones are still there.
  3. Mar 4, 2017 at 11:03 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    The goo gone didn't damage the paint?
  4. Mar 4, 2017 at 11:08 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    No, no damage.
  5. Mar 4, 2017 at 11:09 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I think I have some, will give it a try tomorrow.
  6. Mar 4, 2017 at 11:13 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    It didn't work very well. I felt like it took some rubbing, and that made me worry about scratching. I haven't found anything better yet. I was hoping someone else had a better idea.
  7. Mar 4, 2017 at 11:14 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    BTW, years of construction have taught me that mayonnaise removes sap from your hands very well. I don't know what mayo would do to paint though.
  8. Mar 4, 2017 at 11:16 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I'm going to try butter, but on our 99 es300 first. It's black to and the paint was already in bad shape when we got it. I'll let you know how it works out.
  9. Mar 4, 2017 at 11:17 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks.
  10. Mar 4, 2017 at 11:17 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Real mayo has egg in it, egg is bad for paint.
    Darth Tundra and 831Tun like this.
  11. Mar 5, 2017 at 6:00 AM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    If you used it to get the sap off and then immediately washed the truck where you put the egg on it it would be fine though. Just don't leave it for days or whatever to eat at the paint.
  12. Mar 5, 2017 at 6:09 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Not all sap is the same. I deal with pine pitch and mesquite drips.
    Try WD-40. Won't damage the paint, but leaves a film you can wash off with soap and water.
    Law323, landphil and 831Tun like this.
  13. Mar 5, 2017 at 7:05 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Were I live we have these trees that when the leaves bud in the spring, but husks are really sticky and very difficult to remove. I found that Isopropyl Alcohol work really well. The caveat is that it takes the wax with it and the truck needs to be waxed after using it.
    NewImprovedRon likes this.
  14. Mar 5, 2017 at 8:09 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks RowdyRon and WarEagleSteve. While camping I got a couple dime sized drops of pine sap that I haven't been able to remove. They're dried up now but still well adhered. I'll try the tarminator. Thanks again!
  15. Mar 5, 2017 at 8:19 AM
    Dgoll75
    Dgoll75 New Member
    Goo gone and plastic razor blades. Plastic blades will not scratch paint/clearcoat. I own a detailing company and that's what I use regularly.
    Wynnded and 831Tun like this.
  16. Mar 5, 2017 at 8:30 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    And vinegar.
  17. Mar 5, 2017 at 9:36 AM
    TheBeast The Beach
    Isopropyl Alcohol . the one you can wash your hands with.
    831Tun likes this.
  18. Mar 5, 2017 at 10:11 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    goo gone
    831Tun likes this.
  19. Mar 5, 2017 at 10:16 AM
    Mothers clay bar?
  20. Mar 5, 2017 at 11:23 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Or drink if your name is Kitty Dukakis.
    TheBeast[QUOTED] likes this.
  21. Mar 5, 2017 at 11:34 AM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    As a body shop owner I use one of 2 things, HOT water as hot as you can get it. Put a wash cloth soaked w water in the microwave let it get good and hot grab it w some pliers lay it on the sap spots and let it sit for a bit that usually works
    My best go to stuff and yes some of you will cringe at this but in 11 years in the body business I've never had an issue with this method. Take a soft cloth and pour some lacquer thinner yes that's what I said lol and GENTLY rub the spots back and forth no circles !! it will remove it trust me if you paint is factory paint older than 60 days you will be fine. Just don't let your rag lay on the paint once the spot is gone just throw a coat of wax on it and your good to go I've done this on black and you'll never be able to tell where the spot was
    Don't be afraid it takes about 15-
    20 min if you took a wet lacquer soaked rag Laying in one spot to really do damage to the paint surface
    When we do a detail the car gets washed dried and then wiped down with a lacquer rag then waxed. You would be surprised how much yuck stays on the car even after it's waxed
    Hope that helps
  22. Mar 5, 2017 at 11:40 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Lacquer is an interesting idea. I get to (have to) play with a lot of different adhesives and finishes and am not too surprised that the lacquer thinner won't hurt the finish. Still, the thought does create a little pucker factor. lol Thanks Tim.
  23. Mar 5, 2017 at 12:25 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Going to have to try one of these methods myself. Park under a tree at work every day.
  24. Mar 5, 2017 at 12:34 PM
    TheBeast The Beach
    I used lacquer thinner on my other car bumper to remove white paint when my wife hit the garage door..wax/buffed and it cleaned up really well with no issues.
  25. Mar 5, 2017 at 12:55 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I just tried unsalted butter on our 99 Lexus. Scraped off the big chunk with a credit card first. Butter took the rest right off, but after washing there is still an oily film. I am going to try laquer thinner to get the residue off next time. My truck has to sit under a big ads blue spruce most of the time..so the sap is a major issue for me, big nasty globs of it.
  26. Mar 5, 2017 at 1:26 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I've also used WD-40 with good results, for both sap and decal adhesive, then car wash soap and water for the film left behind.
    I'm not a detailer by any stretch of the imagination though, so copy at your own risk. :boom:
  27. Mar 5, 2017 at 1:53 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've tried this. Takes F O R E V E R, and can damage the surrounding paint that gets unneeded claying.
  28. Mar 9, 2017 at 3:36 PM
    briarpatch
    briarpatch New Member
    unscented hand sanitizer
    TheBeast likes this.
  29. Mar 9, 2017 at 6:53 PM
    PB Blaster
  30. Mar 10, 2017 at 6:42 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
