Tread depth difference across the same axel?
Discussion in 'Wheels & Tires' started by Rmax, Sep 10, 2024.
  1. Sep 10, 2024 at 6:21 PM
    Rmax
    Rmax [OP] New Member
    Ryan
    Denver, CO
    1st Gen Tundra (2002)
    4.7L SR5 4x4 Extended Cab
    What is the acceptable difference in tread depth between two tires across an axel ?
    I have a 2002 4x4 SR5 tundra
  2. Sep 10, 2024 at 6:26 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    There is no limit for FGTs. Just be sure your tires are legal and up to par for anticipated driving conditions.
  3. Sep 10, 2024 at 6:30 PM
    Rmax
    Ryan
    Denver, CO
    Thanks for the response! What does "FGT" stand for?
  4. Sep 10, 2024 at 6:34 PM
    Rmax
    Ryan
    Denver, CO
    Divided by pi and figured it out. Ha never seen it referred to as that way.
    Is it okay to put those two tires on the drive axel or would it be better to put on the front axel?
  5. Sep 10, 2024 at 6:40 PM
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    You could limp it home with two different tire sizes, let alone tread depth. Not ideal but you have open differentials, just don’t put it in 4x4 or anything.
    FGT = First Gen Tundra
  6. Sep 10, 2024 at 6:49 PM
    Rmax
    Ryan
    Denver, CO
    So I have one tire with tread depth of 11/32 and another that is 15/32. My plan was to put these on the same axel (rear) and drive as usual (occasional 4x4 in the winter on slick roads) for the remaining life of the tire. Would that be okay or would it damage the vehicle.
    BuzzardsGottaEat likes this.
  7. Sep 10, 2024 at 7:22 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    4/32s is negligible. It’s not even enough for the ecu to think anything is different. Typically, there’s a 3% tolerance (overall rotational speed) from one side to the other before the ecu picks up speed variations.
  8. Sep 10, 2024 at 7:41 PM
    BuzzardsGottaEat
    '16 Tundra DCLB
    Round Tires
    8th is fine. Run it.
  9. Sep 10, 2024 at 9:34 PM
    Rmax
    Ryan
    Denver, CO
    Awesome, thank you all!
