The S.S. TRDFerguson: Captain’s Log
Discussion in '2.5 Gen Builds (2014-2021)' started by TRDFerguson, Mar 25, 2021.
  1. Jun 6, 2021 at 11:47 AM
    #91
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Your truck is looking great Jake. How did you secure the unistrut to the side of your bed? Did you have to tap the holes you drilled, or is there something else you used on the backside? I’ve been thinking of doing this myself but not really sure how to go about it.
  2. Jun 6, 2021 at 11:50 AM
    #92
    Bob_Wiley
    Eric
    AZ
    Noob question, but what’s the benefit of the carrier bearing spacers? You and I are on a similar lift so I’m just curious if this is something I should do, or what the point is.
  3. Jun 6, 2021 at 12:20 PM
    #93
    TRDFerguson
    TRDFerguson [OP] SSEM #99/RGBA #8-ish?/It’s a funny name.
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    There are threaded holes already there - the spray-in bedliner just covers them up. I used a small screwdriver to locate and poke holes and then a utility knife to cut out the bedliner. Not sure if all are done this way, but there was tape or something over the holes so I didn’t have to worry about them needing to be chased with a tap or anything.
    I had a very mild shudder when accelerating from a stop after I lifted the rear. The spacers help put the drive shaft back in a straight alignment, and theoretically helps with that, if present. I don’t know if I had it or not, truthfully, but in my mind it’s gone after installing the spacers, lol.
    Bob_Wiley[QUOTED] likes this.
  4. Jun 7, 2021 at 8:22 AM
    #94
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    You would think that manufacturing would be more precise when our trucks are being built. With that said, sounds like your build is coming along just fine though. Lessons learned and shared are key with our community. :thumbsup:
  5. Jun 7, 2021 at 9:30 AM
    #95
    2mchfun
    It about driveshaft and pinion angle, don't want to eat u joints constantly.
  6. Jun 7, 2021 at 9:33 AM
    #96
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Hey Eric, if you want to experiment for the price of free, I have a set of carrier bearing spacers (0-2" of rear lift) you're more than welcome to!
    -JS
  7. Jun 7, 2021 at 9:40 AM
    #97
    Bob_Wiley
    Eric
    AZ
    Yeah, that would be great! Appreciate it!
  8. Jun 7, 2021 at 9:47 AM
    #98
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    not to cloud the build thread any longer, sorry @TRDFerguson!
    I've sent you a PM.
    -JS
  9. Jun 7, 2021 at 10:20 AM
    #99
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    No worries at all. I only have this thread going in hopes that it helps out others in some way/shape/form, so mission accomplished! lol
    Bob_Wiley and BiggHertz[QUOTED] like this.
  10. Jun 7, 2021 at 2:14 PM
    #100
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    ABS guards just showed up. Should be some cheap insurance against blowing up an ABS sensor. I know these aren’t as fancy as the Jomax ones, but I’m a cheap ass, so…
  11. Jun 7, 2021 at 3:25 PM
    #101
    AT x AT
    Jimmy
    Mods, what mods?
    Nothing wrong with being a cheapskate... Truck parts don't' pay for themselves.
  12. Jun 7, 2021 at 3:38 PM
    #102
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    At least these things don’t feel cheap. I’m happy with the amount of protection I’ll get from them:
  13. Jun 7, 2021 at 6:07 PM
    #103
    AT x AT
    Jimmy
    Mods, what mods?
    Did you put blue Loctite on them? I haven't installed the used SDHQ ones I bought a couple weeks ago, but I have read somewhere on this site that they can rotate when hit with a rock/object.
  14. Jun 7, 2021 at 6:22 PM
    #104
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’ve heard of that too, but I don’t know if loctite will do anything more than having them torqued down. And I’d be afraid of snapping the bolts if I tried to remove them with the loctite in place. I think I’ll just make it part of my regular maintenance to check their position. Plus I’d rather have them rotate from a rock hit than a direct hit to the sensor.
  15. Jun 7, 2021 at 6:55 PM
    #105
    AT x AT
    Jimmy
    Mods, what mods?
    You have a point there...
  16. Jun 7, 2021 at 7:21 PM
    #106
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    Where did you order them from?
  17. Jun 7, 2021 at 7:24 PM
    #107
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Shot you a PM
    jhardy1979[QUOTED] likes this.
  18. Jun 14, 2021 at 5:39 PM
    #108
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Rigged up some drop mounts for my bed rails to hold a shovel or whatever I need. Now I need to figure out what else I can mount back there.
  19. Jun 14, 2021 at 9:19 PM
    #109
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Makes me wonder if the Rago fab accu mounts would work with your unistrut mounts.
  20. Jun 14, 2021 at 9:35 PM
    #110
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Those should definitely work. Added to the list, lol.
  21. Jun 14, 2021 at 9:43 PM
    #111
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    nothing better than helping fellow members spend their money :)
  22. Jun 15, 2021 at 7:36 AM
    #112
    AT x AT
    Jimmy
    Mods, what mods?
    You need an offroad jack. Hi-lift comes to mind. Harbor Freight has a similar style jack that's considerably cheaper.
  23. Jun 15, 2021 at 7:38 AM
    #113
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    No way lol. I’ve heard way too many horror stories about that style of jack. I do want to build a mini chase rack or something similar to mount my floor jack though.
    Mater likes this.
  24. Jun 15, 2021 at 7:40 AM
    #114
    AT x AT
    Jimmy
    Mods, what mods?
    You can't use a floor jack....if you are stuck in a dry creek. To quote someone "it's so soft and giving...it's like cat litter" :rofl:
  25. Jun 15, 2021 at 7:42 AM
    #115
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Just get a bottle jack and traction boards as a footing. Best advantage of a bottle jack over all other jacks is you can drive off them once you’re up
  26. Jun 15, 2021 at 7:46 AM
    #116
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I do need to get a set of traction boards. They’ll be handy for some of the terrain around here. I’ve had this jack on my list for a while and might be easier to transport than a full size jack
    Powerbuilt 620471 Unijack - 6000 lb. Capacity https://smile.amazon.com/dp/B00GJJZ..._glt_fabc_M1BAFFRQ5ESJQKF2YPA6?_encoding=UTF8
    Mater[QUOTED] likes this.
  27. Jun 15, 2021 at 7:46 AM
    #117
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That’s why I had a 2x6 with me too lol
  28. Jun 15, 2021 at 7:51 AM
    #118
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Same. I keep a pad and a bottle jack. I've seen way too many horrible injuries or damage to vehicles from farm jacks. Super useful but equally dangerous.
  29. Jun 15, 2021 at 7:56 AM
    #119
    Cthulhu
    Jake has proven that even with MGM, you can indeed “throw lipstick on a pig.” :rofl:
    Seriously though @TRDFerguson, love your truck and mods.
    TRDFerguson[OP] likes this.
  30. Jun 15, 2021 at 9:45 AM
    #120
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Nicest backhanded compliment I think I've ever gotten :rofl::fistbump:
