The S.S. TRDFerguson: Captain’s Log
Discussion in '2.5 Gen Builds (2014-2021)' started by TRDFerguson, Mar 25, 2021.
  1. May 24, 2021 at 5:26 PM
    #61
    TRDFerguson
    TRDFerguson [OP] SSEM #99/RGBA #8-ish?/It’s a funny name.
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Thanks!
  2. May 24, 2021 at 9:25 PM
    #62
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    How did you separate the lenses? Any tricks?
  3. May 24, 2021 at 9:29 PM
    #63
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    A dremel cutting wheel and huge balls… lol. The only way to open the tails is to cut them. And there isn’t really a good way to go about it. But sticking close to the gray interior plastic and far away from the lens is the main trick to keeping them looking ok when finished.
  4. May 26, 2021 at 11:19 AM
    #64
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    BiggHertz likes this.
  5. May 26, 2021 at 5:58 PM
    #65
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Welp, I’m an idiot. I apparently pressed the front bushings out when I did this work, since I couldn’t quite tell which end was which.
    The risk I took was calculated, but boy am I bad at math…
    I didn’t figure it out until I had the passenger side leaf pack out and was comparing with the new set. On the plus side, I found out there are already poly bushings in the rear eyelets. New OEM front bushings should be here tomorrow and I’ll give it another shot.
  6. May 26, 2021 at 7:25 PM
    #66
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Just went through the thread. Great work. It was nice meeting you and I'm glad you are happy!
  7. May 26, 2021 at 7:32 PM
    #67
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It’s the perfect amount of bass for what I was wanting. Thanks again!
    e30cabrio[QUOTED] likes this.
  8. May 26, 2021 at 7:39 PM
    #68
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    measure once..cut twice? Lol, happens to the best of us!
  9. May 26, 2021 at 7:42 PM
    #69
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Definitely cutting twice this time. But at least I have a trial run of leaf spring removal out of the way!
  10. May 27, 2021 at 8:21 AM
    #70
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    I'm going to learn from the mistakes you made, so I will measure twice, cut once. :rofl:
  11. May 27, 2021 at 9:17 AM
    #71
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    I mean, consider it a trial run!
  12. May 27, 2021 at 9:20 AM
    #72
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    If I included all the mistakes I made along the way with this truck, this would be a much longer thread…
    The Dude likes this.
  13. May 27, 2021 at 9:41 AM
    #73
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Magic tap oil on your bits, difficult upside down, just oil with a drop frequently.
  14. May 27, 2021 at 9:47 AM
    #74
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yeah, oiled the bit. Just think it was the wrong bits and wrong drill.
    2mchfun[QUOTED] likes this.
  15. May 27, 2021 at 9:52 AM
    #75
    dittothat
    dittothat New Member
    Nick
    SD
    2016 MGM Platinum
    Beautiful rig @TRDFerguson. Glad to see you got your WNOR sliders on. Mine are still sitting in the garage, some day they’ll go on. :tumbleweed: Life’s just been too crazy with the little ones.
    how hard was the install? I’m thinking about renting a magdrill (I think it’ll have enough clearance) to do all the work for me. That and a whole bunch of fresh bits..
    TRDFerguson[OP] likes this.
  16. May 27, 2021 at 10:01 AM
    #76
    2mchfun
    Use only magic tap oil and drill with smaller like a 5/16 bit first and then drill bits will last much longer. Smaller bits are cheaper to throw away.
  17. May 27, 2021 at 10:05 AM
    #77
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Install wasn't terrible, except for the half inch holes into the bottom of the frame. They include some backing plates with a nut and guide wire welded together for the bolts by the gas tank, which helps but is still a pain to line them up blind. Having a second set of eyes and a flashlight holder is helpful for those. And when you take out the splash guard plastic at the front of the frame, make sure you leave the bolts in the second position out so you can put them back in... ask me how I know...
    But I think the magdrill should help a lot. And someone recommended a set of Milwaukee bits for the bottom frame holes, but I'd have to look to see which ones specifically.
    I also was trying to get my 5 year old to help out a little, but he lost interest pretty quick, lol.
    2mchfun and dittothat[QUOTED] like this.
  18. May 27, 2021 at 7:46 PM
    #78
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Well I was able to get new front bushings for the leaf packs from a local dealership parts guy, so that was awesome. Installing them was way easier than pressing them out.
    Then I also cleaned up the stock shackles I picked up from a member on here. They had some surface rust, so I hit them with a wire brush and soaked them in vinegar for a couple hours. Seemed to take care of the bulk of the rust, so then I wiped them down really well with alcohol and hit them with primer. Should be good enough for the elements here.
  19. May 27, 2021 at 7:52 PM
    #79
    2mchfun
    Just curious, why not go to a greasable shackle like the iron man version? Seems to me like a better ride. Just curious.
  20. May 27, 2021 at 7:56 PM
    #80
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’m just going for a marginal upgrade over the lifting shackles that I’m taking off in place of the new leaf packs. I’ll eventually go to better shackles, but for now I have no complaints about ride quality. Not sure if my bar is that low, or if the TRD Pro shocks just help out that much back there.
  21. May 28, 2021 at 8:20 PM
    #81
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Leafs are installed and I’m really happy with the lift and ride. I feel like bumps are much smoother vs the shackles I had, but the poly bushings might help with that too.
    Also picked up a couple more feet of fuel line and a breather filter to redo my rear diff breather relocation. I’ve read conflicting things on using a 2-way filter/breather, but I think it’ll be fine for what I’m doing.
    The Dude and BiggHertz like this.
  22. May 28, 2021 at 8:25 PM
    #82
    2mchfun
    Fun lifting those around, however I bumped up to Dobinson's HDs, so it made those stock packs feel light. Definitely glad I won't be doing it again anytime soon. Glad you are making progress and doing really good with it.
  23. May 28, 2021 at 8:27 PM
    #83
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It was definitely a wrestling match.
  24. Jun 4, 2021 at 7:38 PM
    #84
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Cut, primed and painted some unistrut for DIY bed rails. Just doing the sides for now since Home Depot seems to be out of half the shit I need anymore… should be a quick install tomorrow after they cure a little more overnight.
  25. Jun 5, 2021 at 8:46 PM
    #85
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Bed rails installed, but not without a fight. @BiggHertz and @AT x AT can give me more shit about my measuring abilities. The unistrut slots didn’t line up, so had to drill 3 holes… but they were about 1/8 of an inch off. :frusty:
    Then I chipped off some paint and snapped the rear bolt on the passenger side… Probably should have just bought OEM I guess. But they’re in!
    The Dude, Bob_Wiley and AZTundra like this.
  26. Jun 5, 2021 at 8:52 PM
    #86
    2mchfun
    Not sure about oem, they seem a little bit on the weak side to me. Just my opinion.
  27. Jun 5, 2021 at 8:55 PM
    #87
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’ve never really looked at the OEM rails I guess, but this superstrut is beefy.
    AZTundra and 2mchfun[QUOTED] like this.
  28. Jun 5, 2021 at 9:01 PM
    #88
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    :rofl::rofl::rofl:
  29. Jun 5, 2021 at 9:33 PM
    #89
    AT x AT
    Jimmy
    Mods, what mods?
    Hahahahahaha hahahahahahahahahaha hahahahahahahahahaha
    Glad to see that you aren't a fast learner. :anonymous:
    That's ok, takes me a couple of tries too.
  30. Jun 6, 2021 at 11:02 AM
    #90
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It’s less of a learning disability and more of a laziness issue lol. The driver side was the first and measured off a weld bead instead of the inside of the bed I guess was just enough to make that side a problem. The passenger side was measured perfect, then ran into an issue where I didn’t take quite enough of the bedliner off around the mount, then broke off the bolt when it bound up.
