TRD Wheels on a 2011 Tundra Grade
Discussion in 'Wheels & Tires' started by shanemorton, Jun 23, 2019.
  1. Jun 23, 2019 at 8:38 AM
    shanemorton
    shanemorton [OP] New Member
    2011 Pyrite Mica V8 5.7L Grade
    None at the moment.
    I have a 2011 Tundra Grade with the stock steel rims (255/70/18 tires) without the tire sensors, just how they came when I bought the truck used. Well I had bought four of the TRD Wheels off of a guy, he took them off of his 2014 Tundra Limited/TRD when he upgraded his rims. The new rims also have the same size tires (255/70/18) and he had guessing took off his tire sensors. I just didn't get the time to get the TRD rims installed on my truck, but yesterday I had a major tire rip apart and had to switch to the spare tire. It looks like I ran over a nail or something, and since I didn't notice anything until it was too late.
    My question comes to a confusing about what new size tires should I be getting, the new rims looks just like these
    I am sure they will fit on my 2011 Tundra Grade, but I am getting conflicted two sizes.
    I not sure if 275/65/18 with tire sensors will fit on these rims and my truck because why did they installed 255/70/18 on the new rims since they are the same size as my steel wheel tires.
    Does anyone know what tire size should I need in order to use these rims with tire sensors for my truck?
  2. Jun 23, 2019 at 9:03 AM
    gjcarving
    gjcarving New Member
    275 65 18 or if you want taller 275 70 18 will fit fine. My tundra came with the 275 65 and I went to 70. I'm sure others will chime in.
  3. Jun 23, 2019 at 11:38 AM
    Deepdodo246
    Deepdodo246 New Member
    20190402_162106.jpg 20190402_162106.jpg I would like some wider tires, what do you think? Plus O lile chrome better than grey.
  4. Jun 26, 2019 at 4:32 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    OP those two sizes are both stock sizes that come on the tundra. I believe they are both the same height, but the 275's are a little bit wider. If you stay with a "stock size", I would definitely go with the 275/65/18. You could also run a 275/70/18, which is taller and would fit without lifting/leveling.
    Bottom line, it's your preference to go between 255/70 and 275/65 as they will both work fine.
