TRD Tail Pipes
Discussion in 'Performance and Tuning' started by Rustyscrew, Nov 27, 2018.
  1. Nov 27, 2018 at 4:17 AM
    Rustyscrew
    Rustyscrew [OP] New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    I was curious if the TRD tail pipes rear half will bolt onto the stock catback? Or does it create exhaust leak or just not fit at all. I can't afford the whole thing now but would like to do one half and then the other.
  2. Nov 27, 2018 at 4:32 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    You might be able to just mount the passenger side tailpipe only, i just dont remember if the mufflers are the same length. I would wait and just bolt the whole system in when u get it. It is worth the wait.
