Trd swaybar
Discussion in 'Suspension' started by Joeshaker, Nov 7, 2016.
  1. Nov 7, 2016 at 9:09 AM
    Joeshaker
    Joeshaker [OP] New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    Wondering if a trd sway bar work with a 1.5 inch shackle lift? Found one for a good price. The guy is selling because it won't work with the lift he's putiing on his truck.
  2. Nov 7, 2016 at 9:20 AM
    Should be fine.
  3. Nov 7, 2016 at 9:51 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Go for it!
  4. Nov 7, 2016 at 10:10 AM
    I found sway bar used online works with mine I have a 4.5" lift
  5. Nov 7, 2016 at 10:27 AM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Cool, thanks guys. I thought it would fit.
  6. Nov 7, 2016 at 10:36 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I have a 7" lift and I still run the TRD sway bar. I had a welder cut the two end links and extend them with a longer and bigger tube to keep it at the stock angle. It works great and it's a simple fix. You would have to have the ends repainted or repowder coated after this is done.
  7. Nov 7, 2016 at 10:58 AM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    $150.00 is a pretty good price isn't it? He said it's brand new, just got his truck and the dealer put it on by mistake.
  8. Nov 7, 2016 at 11:00 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Yep you'll be golden
    NewImprovedRon likes this.
  9. Nov 7, 2016 at 11:12 AM
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    at $150 I would be all over that!
  10. Nov 7, 2016 at 11:20 AM
    1UPPER
    TEXAS
    Flux capacitor!
    The TRD sway bar usually goes for $220 plus. So I would snag it up if I were you.
  11. Nov 7, 2016 at 11:53 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    yep, good deal...
  12. Nov 7, 2016 at 2:50 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    That's what I thought. I'm going to meet the guy tomorrow and get it.
  13. Nov 9, 2016 at 9:59 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Picked up the swaybar. Can't wait to get it on the truck. I'm thinking it should help with tire wear as well as handling.
  14. Nov 10, 2016 at 2:18 AM
    chphilo
    chphilo Tundra addict
    Western PA
    It will definitely help with handling. I am not sure about tire wear though.
  15. Nov 10, 2016 at 4:49 AM
    15whtrd
    15whtrd Mr. Blonde
    It helped mine with the wear on the outside edges of the front tires. Less body roll in the corners.
  16. Nov 10, 2016 at 5:14 AM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    That's exactly what I thought, less roll should reduce the wear on the outside edge on the front. Someone over at 8th says that it can increase rear tire wear if you drive hard. What's he doing? Putting it in tow/haulass mode and flooring it coming out of corners and spinning the tires?
    15whtrd likes this.
  17. Nov 10, 2016 at 5:55 AM
    jburson250
    jburson250 Pensioner
    Newmarket, NH
    14 Limited TRD Crew Max
    TRD Pro Suspension, Custom Audio System.
    Nannies-off driftin'.
    Eats M/T's for lunch. ;)
  18. Nov 10, 2016 at 7:24 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Yessir, that's the way to do it. Just got it installed and took it out for a hot lap. Wow, it corners like it's on rails. Guess I could wipe out the tires, if I drove like that all the time. Hmmm, speaking of, maybe the sequioa front bar should be on my list of future mods.
    AxelsHumanDad likes this.
