TRD sway bars and 6-7 inch lift
Discussion in '2.5 Gen Tundras (2014-2021)' started by Hammerdog, Apr 29, 2019.
  1. Apr 29, 2019 at 5:31 PM
    Hammerdog
    Hammerdog [OP] YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Can I still use the TRD swaybars when I lift my truck 6-7 inch lift? I’d hate to lose that pretty undercarriage jewelry!
    Coachbuilder1 likes this.
  2. Apr 29, 2019 at 6:11 PM
    Blueknights75
    Ron
    Clayton, NC
    Sway bars defeat the whole purpose of the lift.... but I do think you will need longer control arms, the vertical pieces of the sway bar... (I believe that’s the correct verbiage
  3. Apr 29, 2019 at 6:13 PM
    Yes but you may want to get longer linkage bars.
    Blueknights75 likes this.
  4. Apr 29, 2019 at 6:24 PM
    Do a search over in TT. Someone over there makes them.
    Prostar 190 likes this.
  5. Apr 29, 2019 at 7:27 PM
    airosey
    airosey 2009 CrewMax Limited 4x4
    East TN
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    The front sway bar will be fine. You’ll need to have the rear end links extended by Ekstrom, or rotate the sway bar mounts on the rear axle 90 degrees to the rear. This will raise the end links high enough to work. I did this to mine and works great.
  6. Apr 29, 2019 at 7:32 PM
    Hellwig makes adjustable links for lifted trucks.
  7. Apr 30, 2019 at 8:36 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    This. I have the hellwig unit. Had mine powdered red before install.
  8. Apr 30, 2019 at 9:28 AM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    We can help, In order for your sway bars to work correctly and to sit in a neutral position your end links need to be lengthened the same amount you've added in lift. Feel free to PM
    Hammerdog[QUOTED][OP] likes this.
  9. Apr 30, 2019 at 10:12 AM
    Hammerdog
    Robbie
    Louisa VA
    Awesome thank you!
  10. May 1, 2019 at 4:36 PM
    Gary86
    Gary86 New Member
    Gary
    2024 SR5 TRD Off-Road
    6" Readylift|Hostile Rage 20x10|Toyo OC R/T 35s|TRD Sway Bars| 2019 PRO Headlights w/ @iHacker harness|Morimoto Foglights|5% Tint
    I thought only the rear links needed to be extended?
  11. May 1, 2019 at 5:37 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
  12. May 1, 2019 at 5:48 PM
    6" kit here, have sway bar, works great
