TRD sway bar quick disconnect
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by DBL TAP, Mar 30, 2016.
  1. Mar 30, 2016 at 8:15 PM
    DBL TAP
    DBL TAP [OP] Light 'em up
    USA
    I recently installed a TRD rear sway bar, and I'm now thinking of designing a quick disconnect at the link(s) for off road use. The Powerwagon has a slick electric d/c for the front sway bar, so my idea will be more like the Fred Flintstone model, but it will work. Stay tuned. What do you think? Would you use a d/c if available?
  2. Mar 30, 2016 at 8:25 PM
    reywcms, MannyFresh and DBL TAP[OP] like this.
  3. Mar 30, 2016 at 8:46 PM
    Remember the JKUs have the sway bar disconnects as well, if you are looking for parts ;)
    DBL TAP[OP] likes this.
  4. Mar 30, 2016 at 11:05 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    I'd use it if it was available (at the links). It'd also be great if someone found a way to relocate the rear sway bar so it doesn't drop below the axle. :D
  5. Mar 31, 2016 at 1:39 AM
  6. Mar 31, 2016 at 4:34 AM
    AMRE2ME2
    AMRE2ME2 New Member
    2016 DC 4x4 Limited TRD
    I've never looked into a QD for a sway bar but would definitely be interested. I tow 5 different trailers up to 10,000 lbs + and run off-road as much as I do on the Hwy so this would be something very useful to me. I've got Firestone airbags that work great for me because I keep them empty until I need them for towing.
  7. Mar 31, 2016 at 9:43 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Is the quick disconnect really worth how much articulation/travel you can get?
    Assuming It will only be so much depending the travel of the shocks. Just wondering don't take it the wrong way.
    Pulling off my front sway off my Tacoma bc bushings are worn and see what kind of difference I will see when I take it out wheeling.
    ColoradoTJ likes this.
  8. Mar 31, 2016 at 11:54 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I like facts/numbers. Would be good to see what the numbers are droop and compression before and after.
  9. Mar 31, 2016 at 1:24 PM
    DBL TAP
    USA
    I looked at rotating mine but the axle housing has two flat sides, and the u-bolt is squared off too...can't it rotate up.
    The new Nissan Titan XD has the rear sway bar rotated from the factory for clearance. Someone at Nissan was thinking outside the fortune cookie!
  10. Mar 31, 2016 at 1:29 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    :rolleyes:
  11. Mar 31, 2016 at 1:36 PM
    DBL TAP
    USA
    Looks good, and who said "it couldn't be done?" Hot damn!
  12. Mar 31, 2016 at 1:43 PM
    This is what one Jeep guy found out from the stiffest setting to nothing installed. Not really a big deal.
    Despite the added control, the Antirock does allow a surprising amount of articulation. In one rockcrawler.com article the author quantifies the difference between fully disconnecting the swaybar and running the Anti-rock:
    • 33.25" fully disconnected (20* RTI = 1050)
    • 32.00" loosest Anti-rock setting (20* RTI = 1011)
    • 31.25" firmest Anti-rock setting (20* RTI = 987)
  13. Mar 31, 2016 at 9:45 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Great info.
    Question would be once disconnected end link can be prone to getting snagged causing damage?
    Rear I don't think much would, but as far as a front disconnect I would worry about cv damage or anything else/ especially moving parts.
  14. Apr 1, 2016 at 3:25 AM
    Good question. In this image, the chrome studs are what the disconnect rests on and pinned (if some assclown doesn't steal them).
    This is how they look when off-road:
    dannysmith604 likes this.
  15. Apr 1, 2016 at 11:33 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Hmm That's a nice setup. lol very vulnerable to theft for sure. haha.
  16. Apr 1, 2016 at 1:35 PM
    I bet they are, much like anything else.
    Not sure I would take a bat to the knees or a .45 ACP for those though. Never mind, there are dumbasses everywhere.
  17. Jul 10, 2019 at 9:44 AM
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    I know this is an old thread, but will those JKUs work with our tundras front sway bar? Strength and fitment wise. 3rd gen. I like having my swaybar on while on road and would like to have it off while wheeling. I never leave the truck unattended where I don’t have an eye on it somehow. Or is there a company who finally made some for our trucks since it’s been 3 years?
    dannysmith604 and careyrob like this.
  18. Apr 6, 2020 at 10:04 PM
    1794-BlackTundra
    1794-BlackTundra New Member
    Sergio
    2019 Black Tundra 1794 Edition CM
    Rhino Linings, Smittybilt 11500 Winch (Internal), BAKflip MX4, RotopaX, MaxTrax, ARB Simpson III tent, Old Man Emu suspension, TRD rims, Pioneer Platform with Rhino-Rack Backbone System
    I guess not... :facepalm:
  19. Sep 10, 2022 at 9:08 PM
    Hotwire
    Hotwire New Member
    Montana
    2008 Tundra SR5 double cab
    What about now?
  20. Mar 20, 2023 at 10:33 AM
    Andhon
    Andhon 2014 Platinum MGM CM
    Andy
    2014 Tundra Platinum MGM CM
    how about now? lol
    Saltyhero13 likes this.
