TRD Sway bar, need parts
Discussion in 'Suspension' started by Mr Bill, Oct 28, 2020.
  1. Oct 28, 2020 at 1:30 PM
    Mr Bill
    Mr Bill [OP] New Member
    Bill
    2017 Platinum 5.7
  2. Oct 28, 2020 at 2:46 PM
    G10dra
    G10dra Not a New Member
    I don't think they're even sold separately. I am adding our Toyota Parts specialist @Roman here to see if he can suggest otherwise.
  3. Oct 28, 2020 at 3:02 PM
    Mr Bill
    Bill
    2017 Platinum 5.7
    I haven't been able to find "parts" either, but was wondering if someone wanted to sell theirs or parts of it. I've seen on the forum that some guys have been taking them off. Hoping!
  4. Oct 28, 2020 at 3:18 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    I just installed one last week. They were stamped as grade 8 bolts, nothing special. If you have a fastenal or mcmaster-carr around you, I would just take the one you still have in to them and they can get it and the sleeves for you. The bushing might be harder to find. I have had good luck contacting energy suspension with specs and getting what I needed, but I may have just got lucky with someone who wanted to help.
    Mater likes this.
  5. Oct 28, 2020 at 3:22 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    Just grab the parts you need from the side that’s still there and head to fastenal. Probably cost you $5
  6. Oct 28, 2020 at 3:31 PM
    Mr Bill
    Bill
    2017 Platinum 5.7
    Thanks, I know the bolts and washers are no problem. But the bushing will be hard to find. I'll check energy suspension. Thanks!
  7. Oct 28, 2020 at 3:37 PM
    Mr Bill
    Bill
    2017 Platinum 5.7
    Thanks!
  8. Oct 28, 2020 at 3:46 PM
    P-Factor
    P-Factor New Member
    Mr Bill Sorry for your hardship but Thank You for reminding us to check our TRD sway bar bolts for a proper security torque!
    Big sigh... Kudos. :thumbsup:
    YotaMan likes this.
  9. Oct 30, 2020 at 6:57 PM
    I didn't find them either during a search. The instructions just give some bolt specs but thats about it.
  10. Oct 30, 2020 at 7:19 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Mine came missing the sleeve washer. I couldn’t find one anywhere. I ended up using a 1/2” black pipe nipple from Home Depot. Cut with a grinder to the length of the other side. Torqued to spec, still there two years later.
  11. Oct 30, 2020 at 7:20 PM
    Mr Bill
    Bill
    2017 Platinum 5.7
    Thanks!
  12. Oct 30, 2020 at 7:21 PM
    Mr Bill
    Bill
    2017 Platinum 5.7
    thank you! was just wondering about that!
  13. Oct 30, 2020 at 7:29 PM
    BlueRibbon4x4
    Geno
    I also preassembled that side and wrapped the bolt with electrical tape to fill the void between the outside of the bolt and the inside of the pipe. The stress is on the ends of the pipe, so filling that area just centers the pipe so it doesn’t sit crooked against the washers.
  14. Nov 11, 2020 at 7:32 PM
    G10dra
  15. Nov 12, 2020 at 8:49 AM
    pickeledpigsfeet
    Kings & Icons
    G10dra[QUOTED] likes this.
