TRD Sport vs. Black OE shocks
Discussion in 'Suspension' started by SnrDisregardo, Sep 4, 2018.
  1. Sep 4, 2018 at 2:30 PM
    SnrDisregardo
    SnrDisregardo [OP] New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    This is just a FYI for those that would be interested. I changed my OE Platinum suspension over to the TRD Sport over the weekend. I do have both the front and rear TRD sway bars as well. I can say that the Sport suspension lives up to the name by firming up the ride even more. I did take a lot of the "jiggle" out from the standard black shock on everyday highway treks. It is a bit more jarring over bumps, but that was to be expected.
    Tundra1078, Pudge and easleycrawler like this.
  2. Sep 29, 2018 at 12:54 PM
    pokerag2
    pokerag2 New Member
    Thanks for the info. I just took delivery of my Platinum today. I traded in a 2007 Limited with TRD package. Really did like the ride of my TRD. I had just begun my quest of how to regain that ride in my Platinum. What all did you replace and what did you replace it with specifically? Do you know if the springs are different on a TRD vs Platinum or is it just the shocks and struts? Are the Sport shocks struts different? Thanks
  3. Sep 29, 2018 at 1:55 PM
    SnrDisregardo
    Wade
    IL
    Honestly I found a set of the TRD Sport shocks and struts. Basically, from what I understand, aside for the PRO the springs are all the same, it’s just the shocks that are different. I lucked into a set of coil overs and rear shocks from another member on here.
  4. Sep 29, 2018 at 2:42 PM
    pokerag2
    pokerag2 New Member
    Yes thats what I was trying to find out. Leaf springs are the same. Coilovers are the same? Shocks and struts definitely different. Is this the way you understand it? The ride in the Platinum is too plush for me. I like the stiffer ride.
  5. Sep 29, 2018 at 5:57 PM
    SnrDisregardo
    Wade
    IL
    Yep. Same platinum springs. I also have both front and rear sport sway bars too.
  6. Sep 30, 2018 at 4:53 PM
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    My brother in law has ‘18 sport and his sits higher than my 2016 sr5.
  7. Oct 1, 2018 at 2:22 PM
    SnrDisregardo
    Wade
    IL
    I didn't take any before/after measurements, unfortunately.
