TRD rear sway bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by rbros, Dec 25, 2020.
  1. Dec 25, 2020 at 6:24 PM
    rbros
    rbros [OP] New Member
    2021 White Limited TRD
    Are the TRD rear sway bars worth it for handling? Will most likely be installing air bags for when the boat is hooked up, but have been considering adding the rear sway bar also.
  2. Dec 25, 2020 at 6:28 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    It's noticeably better in turns by reducing body roll.
  3. Dec 25, 2020 at 11:23 PM
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    2019 Tundra CM Super White
    wheels/tires suspension protection
    Yes if you're on stock suspension.
  4. Dec 26, 2020 at 2:58 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    I concur. It reduces body roll. I like it.
  5. Dec 26, 2020 at 3:56 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Sway bar is worth it!
  6. Dec 26, 2020 at 4:01 AM
    Zero One Actual
    I have firestone airbags and the sway bar and it is totally worth it. I do not tow a boat but I have a decked two drawer system and a Leitner designs cargo system. Often I will have a lot of weight in my bed and on the rack. I have 35 inch tires and a three inch lift. The sway bar is very very helpful in all situations.
  7. Dec 26, 2020 at 4:51 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Worth it
    Tundra14Platinum and DaddyPete like this.
  8. Dec 26, 2020 at 5:23 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Best bang for buck you can do besides a supercharger.
  9. Dec 26, 2020 at 5:40 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    One of the first things I added to my crewmax and there has been no regrets.
  10. Dec 26, 2020 at 6:17 AM
    Saltyhero13
    Good points about the suspension. I wouldn't run the sway bar if you have an off road suspension set up.
  11. Dec 26, 2020 at 6:25 AM
    Yes it's a great addition I also have air bags. I went with the Hellwig sway bar.PXL_20201014_221941856.MP~2.jpg
  12. Dec 26, 2020 at 6:32 AM
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    only worth it if you're a pavement princess
  13. Dec 26, 2020 at 6:34 AM
    shayned97
    shayned97 New Member
    Shayne
    2016 Blazin Blue Tundra TRD Offroad
    100% yes
  14. Dec 26, 2020 at 7:18 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Yes..
    I had a Hellwig on my 2005 and now have a TRD on my 2014.
    F131B29B-396F-45F9-B6DE-5F1AF30227A4_zps_36f845a147edaa965cbc43eb515da58791b86e32.jpg
  15. Dec 26, 2020 at 7:22 AM
    coTony
    Tony
    Montrose, CO
    LOVE the Hellwig but I have to sell mine. Being able to adjust it to the way I drive is priceless plus they are a heavier bar than the TRD sway bar
  16. Dec 26, 2020 at 7:26 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  17. Dec 26, 2020 at 7:42 AM
    rbros
    Thanks guys. The truck does has a 3/1 suspension kit going in today but I still will get one. My off-roading is limited to forest roads during hunting season.
  18. Dec 26, 2020 at 7:44 AM
    coTony
    Tony
    Montrose, CO
    Buy Hellwig, you can adjust it and set it up for how you drive. If you lived closer I could sell you mine
    Rex Kramer and Saltyhero13 like this.
  19. Dec 26, 2020 at 7:57 AM
    rbros
    Pm me with a price. I could pay the shipping. I’m seeing the standard size is more expensive than the 2” lift model for some reason
  20. Dec 26, 2020 at 9:41 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I have a Hellwig on my 2002, and my 2007 has a TRD bar as well as bags.
    Handling is greatly improved.
    Dgjman and BravoDeltaRomeo like this.
  21. Dec 26, 2020 at 11:54 AM
    Toolaholic
    Toolaholic New Member
    David
    2021 black tundra SR5 SX 4x4
    TRD rear sway bar
    I installed a TRD sway bar one week after buying my 2021 tundra SR5 SX end of of November . Made a huge difference on windy back roads. Hardly any lean on clover leafs . Even seems to stay in lane better on highway. ( doesn’t wander tracks straight). Made a huge difference. I almost bought a Tacoma instead for the better handling. But got the tundra cause I love a v8. Without rear sway bar the tundra leaned and had sloppy handling . The trd bar is huge bang for buck
    szabo101, Dgjman, BGoodiE and 5 others like this.
  22. Dec 26, 2020 at 12:03 PM
    Toolaholic
    David
    TRD rear sway bar
  23. Dec 26, 2020 at 12:04 PM
    Toolaholic
    David
    TRD rear sway bar
  24. Dec 26, 2020 at 12:08 PM
    CincYOTA
    CincYOTA New Number
    2012 Tundra SR5 DC 5.7 4x4
    Yes. Installed on my 2012 earlier this year. Back end feels more planted.20200223_123252.jpg
    Saltyhero13 likes this.
  25. Dec 26, 2020 at 1:03 PM
    Zero One Actual
    You do know how long it takes to remove it for when you are running the rubicon right? But how do you get to Moab? Oh pavement.
    Matala, BGoodiE, Sapper406 and 2 others like this.
  26. Dec 26, 2020 at 1:21 PM
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    Just can't help yourself
    Sapper406 and Rex Kramer like this.
  27. Dec 26, 2020 at 1:22 PM
    Toolaholic
    David
    TRD rear sway bar
    With a cordless ratchet sway bar would come off really quick .
  28. Dec 26, 2020 at 2:40 PM
    Zero One Actual
    Under five min.
    BravoDeltaRomeo likes this.
  29. Dec 26, 2020 at 2:45 PM
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    What air bags are those on your truck.
  30. Dec 26, 2020 at 2:45 PM
    Rex Kramer
    Georgia
    Great set-up!
    Could you post a picture of how the end link interfaces with the frame?
    Thanks.
