TRD rear sway bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mamba, Oct 11, 2019.
  1. Oct 11, 2019 at 3:04 AM
    Mamba
    Mamba [OP] New Member
    Manny
    2020 Tundra Limited 4x4
    None
    Good Morning all,
    My last tundra was a 2008 XSP which I sadly had to sell in 2012. With the new 1794 I have a quick question is the sway bar a good mod? Does it make the truck handle better curbs mountains? I use this truck mostly for long family trips to TN
  2. Oct 11, 2019 at 3:06 AM
    Yes the sway bar is a great addition. It is one I wished I had done a long time ago.
  3. Oct 11, 2019 at 3:11 AM
    timsp8
    NY
    I think it makes it handle better.
    Tundyfundy and Tundra234 like this.
  4. Oct 11, 2019 at 4:15 AM
    mundra
    mundra New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    Keeps it flatter for sure in the curves. Every little bit helps but it’s still truck. Yet... I did put one on my platinum.!
    Tundyfundy likes this.
  5. Oct 11, 2019 at 4:24 AM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    I think it's a worthy addition, but definitely temper your expectations a little. It makes it a little more controlled feeling in corners, but it's not a night/day type difference, either. You're not going to put the sway bar on and think to yourself "wow, this is like a totally new truck!".
    BravoDeltaRomeo and jtwags like this.
  6. Oct 11, 2019 at 4:33 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Yes...reduces body roll significantly...I did the front one too. Great mod. Some guys bitch about it and say it “stiffens” the ride...I have done sways on several different applications and have never felt it stiffened the ride on any of them.
  7. Oct 11, 2019 at 4:38 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    For me it is mod #1. You will not be disappointed. Easy to do yourself. Be 1000% sure you get all of the bolt torque specs in advance. There's one connection that the factory has at just over 100 lb-ft.
  8. Oct 11, 2019 at 4:39 AM
    I agree with @Crunch527......I felt no stiffening either, and I run both as well. The handling improvement is noticeable especially if you have to do a quick lane change at 80 MPH. :yes:
    Tundyfundy and jtwags like this.
  9. Oct 11, 2019 at 4:45 AM
    Here is the installation for the rear. I'm still looking for the front.
  10. Oct 11, 2019 at 4:59 AM
    georgie
    georgie New Member
    Get it you will love for your kind off driving!!!! Hard core off road no.
  11. Oct 11, 2019 at 5:06 AM
    georgie
    georgie New Member
    oh get the solid trd front sway replace the hollow factory one.
  12. Oct 11, 2019 at 5:53 AM
    hogpiolet
    hogpiolet New Member
    Jimmie
    2018 tundra Platnium
    none
    I think it was a great add
  13. Oct 11, 2019 at 6:48 AM
    Pete1794
    Pete1794 New Member
    SC
    2019Tundra1794
    All stock
    I installed a rear sway bar and noticed a great improvement in handling corners/curves. No off-roads use.
  14. Oct 11, 2019 at 7:29 AM
    sundance
    sundance New Member
    I disagree completely. Add the sway bar. Run some E's and you can corner with the best of them. I leave people following me too close all the time in the curves. Add it all and drive her in deep....... :)
    Just be careful, when it turns loose, it turns all the way loose.
    The one thing the sway bar does that most people do not like is the bar will make your truck a little "jittery" over uneven roads. Its the sway bar limiting the travel of the rearend. You get uneven roads and it feels a little weird. Since I've added my Monomaxs.... Its almost gone completely... but it is definitely worth it.
    Tundra234 and HulkSmurf14 like this.
  15. Oct 11, 2019 at 1:13 PM
    Mamba
    Manny
    None
    Thank all for your feedback
  16. Oct 11, 2019 at 1:52 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Looks like a Rear TRD sway bar will be first major addition. I'll ask my dealer about cost. If it's more than Amazon.ca, I'll get them to match and install with my free service credit to use that up.
    It'll be for city drivng and towing a 4k lb trailer in the summer. Seems like it is universally agreed upon as being a Must Do mod.
  17. Oct 11, 2019 at 2:07 PM
    NR-J
    NR-J New Member
    Justin
    2015 white tundra
    How often do you go offroad? If not very often/never and offroad performance isn’t an issue for you go for it. It’ll improve on road handling.
    If you offroad frequently, it’s the last mod I would do. I personally don’t run front or rear swaybars on either of my vehicles and don’t have body roll issues driving mountain passes, even when I’m towing or hauling a bed full of stuff. My Tundra rides a whole lot smoother on road now without the front swaybar as well.
    SiberianTundra likes this.
  18. Oct 11, 2019 at 2:18 PM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    No rear sway bar here either and no issues at all. I am also not racing this truck full speed through turns with a camper shell on. :D
    BravoDeltaRomeo likes this.
  19. Oct 11, 2019 at 2:34 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Like mine immensely. It makes it much better on curves and such like flyovers in Houston.
    I can't stand body roll especially when I'm the passenger.
    YsoSeRiouS! likes this.
  20. Oct 11, 2019 at 2:47 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    I live in Tennessee in a rural area and lots of curves.I put the solid TRD rear sway bar on my 13 SR5 Crewmax and now it handled amazing! Before the sway bar I had a lot of body lean.Now it plants solid in the turns and solid on high speed lane changes on the interstate. You won't be disappointed!!
  21. Oct 11, 2019 at 2:48 PM
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    I have both front and back trd sway bars. So much better handling
  22. Oct 11, 2019 at 2:51 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Did you do the rear before the front? Reason I ask is what was different after changing the front. I'm satisfied with the rear but always need a reason to piss away more money on my truck
  23. Oct 11, 2019 at 2:52 PM
    YsoSeRiouS!
    NorCaL
    I did rear first then my wife made me buy the front. Once I added the front the truck flattened out and turning corners was way more responsive @7.62Tundra
  24. Oct 17, 2019 at 2:13 PM
    Alaska
    Alaska New Member
    2017 Tundra TRD 4x4 ~Quicksand~
    Baja Designs Squadron WC fogs
    Anyone live in an area where the sway bar improved handling in snow/icy conditions? I'll be running studded tires this winter but was wondering if the sway bar would improve traction?
  25. Oct 17, 2019 at 3:27 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    You will whip the tail out more often with the rear sway bar...BUT, as another fellow AK man, your driving will not be hindered...just perfected!
    Alaska likes this.
  26. Oct 17, 2019 at 3:40 PM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    I guess search was broken. This topic gets brought up every couple of weeks.
  27. Oct 18, 2019 at 9:35 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    Getting ready to pull the trigger on a rear sway bar. Two questions, does anyone know of a price break anywhere and has anyone gone with a different model other than the TRD sway bar. If so, why?
  28. Oct 18, 2019 at 10:31 AM
    rds95991
    rds95991 New Member
    2018 Super White Tundra CrewMax SR5 TRD
    When I purchased my rear and front TRD sway bars, the cost of installation was included in the quoted price.
  29. Oct 18, 2019 at 10:54 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Yup, same as here in Canada.
    The Front is listed as $239.98cad and the Rear $502.97cad...including Toyota installation and warranty.
    I'll be adding the Rear in March when we go for our first service and possibly the front too, we'll see. Hopefully my $500 service credit will cover the Rear (and part). If not, I'll have them give me a breakdown of part cost/install price and buy both parts and have them installed them with the credit. Either way, I want to eat up that credit so I can start taking it to my Mechanic after the first few years free service is up.
  30. Oct 18, 2019 at 11:09 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Don’t forget TRD now makes the red TRD front Sway bar that upgrades the factory front one. That way you can look and handle good in reverse as well as in drive, it’s a coming and going thing.
    bvia and BravoDeltaRomeo like this.
