TRD Radiator Cap
Discussion in '2nd Gen Tundras (2007-2013)' started by Slim Gym, Feb 6, 2024.
  1. Feb 6, 2024 at 8:22 AM
    Slim Gym
    Slim Gym [OP] New Member
    2013 Tundra DC 4X4
    Question. My stock radiator cap was over 10 years old. Saw a couple posts on them breaking due to age. When I went to order a new one I saw this model. Figured I would get an extra .00001 horsepower out of it.
    Since I have put it on my truck my heat works REALLY well. It gets a lot hotter in the cab.
    I noticed the old cap had 16 psi and this one has 18.5 psi.
    I work think the only way to make it hotter in the cab would be to put a different thermostat that opens at a higher temperature on it.
    Any ideas or is it just my imagination?
  2. Feb 6, 2024 at 8:25 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I didn't notice that when I switched to a TRD cap.
  3. Feb 6, 2024 at 8:29 AM
    Slim Gym
    2013 Tundra DC 4X4
    Must be my imagination. But every time I drive it I have to turn the heat down. Runs me out of the cab on where I used to have the knobs set. Could not understand how higher pressure at the cap would make it run hotter. Thanks.
  4. Feb 6, 2024 at 8:31 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The heater works by blowing air through the heater core which has hot coolant running through it. If your coolant is running at a higher temp (and quicker to get to that temp), I suppose you'd feel it more in the cab...
  5. Feb 6, 2024 at 8:40 AM
    2mchfun
    Higher pressure cap puts a little more stress on the seals, hoses, gasket, and other components. It also increases the boiling point by a few degrees. Could be the higher pressure circulates faster through the heater core giving you more heat because the airflow can't reduce the temperature as fast as before.
  6. Feb 6, 2024 at 10:18 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Should "cool better" as there is now higher flow with the cap's pressure increase. These are recommended on boosted or towing applications. Won't hurt a thing but because water is efficient, it will find leaks if you have any...
