TRD Pro wheel fitment on Platinum
Discussion in 'Wheels & Tires' started by RickC, Dec 16, 2022.
  1. Dec 16, 2022 at 10:31 AM
    RickC
    RickC [OP] NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    Hi,
    I am interested in going with the TRD PRO Wheel on a 2017 Tundra Platinum. When I enter the part number on sites however, it says that wheel doesn't fit the Platinum.
    Can anyone confirm or deny this? I am not sure I will go this route because currently, that wheel is out of sight, price wise, but I want to be prepared should a good used set come available. This is the wheel I am referring to (picture copied from the web)
    The part number is PT960-34190-02 - Gloss/Semi Gloss Black with PRO and BBS-Forged Embossed in Brushed Aluminum. At least I think this is the part number because using that part number sometimes pulls up the matte black, but I want the gloss version.
  2. Dec 16, 2022 at 10:36 AM
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    The TRD Pro BBS wheels will fit any 07-21 Tundra, as the lug pattern has not changed. As far as the semi gloss finish, if you're really wanting them in gloss black, you may want to have them painted (since it's not good to powdercoat forged wheels).
  3. Dec 16, 2022 at 10:56 AM
    RickC
    Rick
    Knoxville TN
    Yeah, I did know the bolt pattern was the same which is what confused me when they said it doesn't fit the Platinum. I thought maybe the calipers or rotors were different, but I am running an 18" wheel now albeit a different offset. Thanks for the reply!
  4. Dec 16, 2022 at 11:16 AM
    RickC
    Rick
    Knoxville TN
    Sweet! That's even my truck color. Are those the matte black?
  5. Dec 16, 2022 at 11:50 AM
    RickC
    Rick
    Knoxville TN
  6. Dec 16, 2022 at 11:57 AM
    RickC
    Rick
    Knoxville TN
    The description says it's matte black and then just below it, lists the part numbers where that part number is called Gloss/Semi Gloss Black.
  7. Dec 16, 2022 at 12:04 PM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    So did the PRO's ever come with the Gloss/Semi Gloss Wheels or only the Matte? This style wheel was only on the 19-21 PRO's, correct?
  8. Dec 16, 2022 at 12:06 PM
    RickC
    Rick
    Knoxville TN
    Amazon has it wrong also:
    I have not seen the ebay ad.
  9. Dec 16, 2022 at 12:11 PM
    Bergy24
    Bergy24 New Member
    That makes sense since I bought PRO wheels from a 2019 and I thought they always had more sheen than Matte.
    RickC[OP] and ryanwgregg like this.
  10. May 5, 2023 at 3:27 PM
    TundraLLama
    TundraLLama New Member
    Massachusetts
    2015 Black Platinum Tundra
    Color matched mirror caps and door handles TRD dual exhaust TRD shift knob TRD Pro FOX shocks Spray in LINEX bed liner TRD 18” wheels FOX TRD Pro suspension Michelin 275/65r18 LTX AT2 Soft top Roll up bed cover Go Rhino RB10 running boards TRD Pro LED blackout headlights TRD Pro LED blackout fog lights TRD Pro grille AJT DESIGN blackout vent/shift/cup holder Wireless charging tray Remote starter Upgraded alpine speakers, amp, dual sub box. Rear underseat storage.
    With the help of this thread, and talking to the people at Sparks Parts, I finally found the right part numbers for the matte black items including center caps. The lugs are the chrome ones. There is a difference between the semi gloss and matte black. Just an FYI you can buy them much cheaper from that place than on eBay. Hope this helps somebody thanks again.IMG_4016.jpg
    Bergy24 likes this.
  11. May 9, 2023 at 3:58 AM
    TundraLLama
    Massachusetts
    Had them put on yesterday. The truck feels lighter — getting slightly better mpg’s. Love the look. IMG_4075.jpgIMG_4071.jpg
