TRD Pro Upgrades
Discussion in 'Dirty Deeds Industries' started by McReef, Mar 6, 2017.
  1. Mar 6, 2017 at 7:51 AM
    McReef
    McReef [OP] '17 Tundra TRD Pro Crewmax
    Eastern MA
    Hi Keith,
    You are apparently the man to talk to when it comes to performance upgrades around here, especially exhaust work. So here is my question...
    What is the biggest bang-for-my-buck performance upgrade to my 2017 TRD Pro? I have seen several mentions of long-tube headers as a potential candidate, would this be a good choice for me? What else needs to be swapped at a minimum to run these? What sort of improvements could I expect to see? Can I even run these (legally) where I live (MA)?
    I'd appreciate any input you might have for me,
    -Dave
  2. Mar 6, 2017 at 8:16 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Hi Dave, I'm not sure about local laws, but most states only require that you run catalytic converters. As far as I know CA is the only state that cares which headers you run,
    at a minimum you would also have to run a set of mid pipes to connect the headers to your existing catback. But if you ran our catback also, you would gain a little extra low end torque.
    There's a ton to consider, Give a call when you have a chance.
    Keith 760-877-4234
    trdprobped17 and McReef[OP] like this.
  3. Mar 6, 2017 at 8:21 AM
    McReef
    Eastern MA
    Thanks Keith,
    When I get somewhere I can get on the phone I'll give you a ring.
    Dave
  4. Mar 6, 2017 at 11:13 PM
    dirtydeeds
    Keith
    USA
    sounds good, Thanks Dave!!
  5. Mar 5, 2018 at 1:34 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Do you make dumps for the factory trd pro exhaust? I saw you have the flanges but couldn’t find premade dumps on your site.
  6. Mar 5, 2018 at 5:18 PM
    dirtydeeds
    Keith
    USA
    Yessir we make them. $100 aluminized steel. $150 stainless steel. They’re not listed yet. Call to order. 760-877-4234
  7. Aug 4, 2018 at 7:02 AM
    Topper
    Topper New Member
    Ed
    2015 Trd limited 2xwh tundra
    Interior floor light
    What's a dump I have a trd dual exhaust. It sounds good but that's it
    Thanks
  8. Aug 4, 2018 at 8:52 AM
    dirtydeeds
    Keith
    USA
    We have bolt on turn downs. They allow you to unbolt and remove your trd tailpipes and bolt on our turn downs. Often referred to as dumps.
  9. Aug 4, 2018 at 6:21 PM
    Topper
    Topper New Member
    Ed
    Thank you,still thinking
