TRD PRO TSS garnish
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by Dave8699, Oct 12, 2024.
  1. Oct 12, 2024 at 6:06 PM
    Dave8699
    Dave8699 [OP] Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Ok forum members I know there has been a couple of guys who have made some 3D printed TSS garnish. I designed one that flows pretty good with the TRD Pro rectangle grille.
    I have multiple different designs that you can choose from. I use ASA filament which is very weather complaint, and print everything with 100% infill so it's nice a heavy and stronger.
    The garnish will work for 2014 - 2017 without the TSS sensor. This is for esthetic purposes Only. Don't have a way to see if it would work with the sensor.
    There is a couple different models which you can see the pictures. All models will come with the necessary hardware to attach it to the grille. One model is designed to be a different swap with oem cover. No drilling or cutting is necessary. Then you have another model which is for the Bravehearted, it will blend in nicely with the grille.
    The garnish was designed using a KOK auto parts grille which is supposedly a copy cat of a OEM.
    Price is $60 which includes mounting hardware and shipping.
    If you like the option with TRD in a different color it is $65.
    Send me a PM and we can discuss which model you would like.
    https://www.kokautoparts.com/produc...tRYITiSGk2BAjs4bp2u0rCA8uPYXJgNRoCUPMQAvD_BwE
    Option 1: Plain no backing direct swap
    Option 2: TRD no backing direct swap
    Option 3: Plain backing top corners direct swap
    Option 4: TRD full backing direct swap
    Option 5: Plain full backing direct swap
    Option 6: Plain no backing you need to cut grille and install brass inserts
    Option 7: TRD no backing you need to cut grille and install brass inserts
    Option 8: TRD no backing two color direct swap
    Option 9: TRD no backing two color you need to cut grille and install brass inserts
    Mounting point for the direct swap
    Plain Direct swap
    Option 6: cutting the grille
  2. Oct 12, 2024 at 6:11 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    PM sent. Put me down for the one without the backing and with the TRD print.
    :spending:
    Dave8699[OP] likes this.
  3. Oct 13, 2024 at 2:51 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I’ll take one vented no backer or logo.
  4. Oct 13, 2024 at 2:55 PM
    Dave8699
    David
    NJ
    Sounds good send me a PM
  5. Oct 13, 2024 at 6:06 PM
    Dave8699
    David
    NJ
    @TacomaTRD4x402 garnish is printed. Hard to see the TRD in the pictures but it's a nice touch.
    TacomaTRD4x402 likes this.
  6. Oct 13, 2024 at 6:39 PM
    TacomaTRD4x402
    Southern California
    :yes:
    reywcms likes this.
  7. Oct 14, 2024 at 4:22 PM
    JrJrOffroad
    JrJrOffroad Somewhere in the west
    Anthony
    Monument, CO // Cave Creek, AZ
    This looks killer!!
  8. Oct 21, 2024 at 10:15 AM
    TacomaTRD4x402
    Southern California
    Just received my garnish from @Dave8699 and must say this is great quality!
    I don't have the newer pro grille yet but I jumped on this chance to get this soon as he made it available.
    Now time to order that grille insert
    Thanks @Dave8699 :cheers:
    Dave8699[OP] and OldGuy03 like this.
  9. Oct 21, 2024 at 12:12 PM
    Dave8699
    David
    NJ
    My pleasure, thank you for the support
  10. Oct 21, 2024 at 12:43 PM
    KingSkii
    KingSkii New Member
    Sent you a DM!
  11. Oct 24, 2024 at 2:40 PM
    Dave8699
    David
    NJ
    How it looks when you cut the grille in-between the garnish.
    KingSkii and reywcms like this.
  12. Oct 24, 2024 at 2:44 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Looks good. Reminds me of the ZL1 chevy bow tie badge. One of their claims more flow lol
  13. Oct 24, 2024 at 2:48 PM
    Dave8699
    David
    NJ
    Funny you say that I have a ZL1 flow tie.
    reywcms[QUOTED] likes this.
  14. Oct 24, 2024 at 2:51 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Hell yes!
  15. Oct 24, 2024 at 3:08 PM
    Dave8699
    David
    NJ
    Also mounting is tricky if you go this route. Snice you grind off material off the grille you have to figure out where to put the inserts.
    reywcms likes this.
  16. Nov 11, 2024 at 5:56 PM
    Dave8699
    David
    NJ
    Another set going out. Thank you to everyone that has ordered.
    TundraCoast, KingSkii and reywcms like this.
  17. Nov 12, 2024 at 2:39 PM
    Dave8699
    David
    NJ
    NJTundra_1 likes this.
  18. Nov 26, 2024 at 1:39 PM
    860_UA7
    860_UA7 New Member
    2015 Tundra SR5 TRD Magnetic Gray Metallic
    Do you have any pictures of these installed on a truck? Definitely interested in a set.
  19. Nov 26, 2024 at 2:21 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I'd share pics if I had mine thrown on yet lol. I actually just sanded mine and painted it.
  20. Nov 26, 2024 at 3:59 PM
    860_UA7
    860_UA7 New Member
    I'd love to see it once you finish. Did you paint it gloss black to match the rest of the grille?
  21. Nov 26, 2024 at 3:59 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yes I did
  22. Nov 26, 2024 at 4:28 PM
    Dave8699
    David
    NJ
    Here are some
    TundraCoast and bulldog93 like this.
  23. Dec 2, 2024 at 7:29 AM
    KingSkii
    KingSkii New Member
    Here is mine with it on, so much better looking then either hole or that plate cover.
  24. Dec 3, 2024 at 3:50 AM
    redrum448
    redrum448 New Member
    and youre still using the TSS sensor?
  25. Dec 4, 2024 at 8:16 AM
    KingSkii
    KingSkii New Member
    Mines a 2014 with a grill swap. Don't have a TSS sensor to worry about thankfully.
  26. Dec 27, 2024 at 12:05 PM
    TundraCoast
    TundraCoast Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    I’ve been looking for this exact piece for quite a while, nice work Dave. pM sent
  27. Mar 30, 2025 at 10:02 AM
    Dave8699
    David
    NJ
    @uteman23 and @BADMOJO_Tundra I have the printer going with your garnish. Time to eliminate that ugly silver garnish.
