TRD PRO sway with lift
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Fugis281, Aug 8, 2022.
  1. Aug 8, 2022 at 1:24 PM
    Fugis281
    Fugis281 [OP] New Member
    Rufio
    CA
    2021 TRD Sport/PRO
    Suspension: TRD PRO Suspension, Wescott Lift, Coachbuilder +3 Shackles and Tierods, Element UCS's, Wheels/Tires: Method Race Wheels MR312's, Toyo 35" Open Country RT's Engine: Stillen CAI, Pedal Commander, D3 Performance Tune, TRD PRO Dual exhaust.
    Hello everyone, I recently (2months ago) installed TRD PRO suspension along with Wescott Designs TRD pro lift and Coach Builder +3 shackles. My question is I feel a little bit of a sway coming form the front end while driving, is this normal? Im also running 35's in the front. It almost feels like it wanders slightly from left to right.
    Alignment is all correct, had it done twice and still the same. Is it the Tie Rods? Any feedback is welcomed.
  2. Aug 8, 2022 at 1:45 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Are you running a front sway bar?
  3. Aug 8, 2022 at 1:49 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Sway bar, tire pressure?
  4. Aug 8, 2022 at 2:12 PM
    Fugis281
    Rufio
    CA
    2021 TRD Sport/PRO
    Yes I have TRD sway bars that came with the truck originally.
    IsaiahCanada likes this.
  5. Aug 8, 2022 at 2:14 PM
    Fugis281
    Rufio
    CA
    2021 TRD Sport/PRO
    Tire pressure is set to 36 psi on Toyo Open Country RT's, and I have both front and rear TRD Sway bars.
  6. Aug 8, 2022 at 4:33 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    should be straight as an arrow, I'd take the truck to another alignment place and get it checked.
  7. Aug 8, 2022 at 6:26 PM
    Cthulhu
    OP looks like you have two threads on this subject; try and delete the other.
    You mentioned tie rods…I’m not sure if this would help, but my set-up is almost identical to yours (I went with CB shims as opposed to Wescott collars), but I also have the CB tie rods included in the CB TRD Pro lift kit (you can buy them separately from the kit), and when I’m driving down a washboard road, the steering wheel barely has any play at all, drives nice and straight. I can tell you that after I installed the tie rods, on the way to the alignment shop, the steering was very squirrelly…fixed when aligned.
  8. Aug 8, 2022 at 6:51 PM
    Fugis281
    Rufio
    CA
    2021 TRD Sport/PRO
    Ill check the alignment again and tie rods from CB have been ordered. Truck drives straight it just wanders slighlty, enough for me to notice.
  9. Aug 8, 2022 at 6:55 PM
    Cthulhu
    Wandering…perfect way to describe what my truck was doing before the alignment. Good luck.
  10. Aug 9, 2022 at 11:59 AM
    Fugis281
    Rufio
    CA
    2021 TRD Sport/PRO
    Thanks dude, Ill get it re-aligned once the CB tie Rods come in and installed
  11. Aug 9, 2022 at 1:01 PM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Keep us posted.
