TRD Pro suspension vs. Toytec 3-1
Discussion in 'Suspension' started by veg hed, May 26, 2016.
  1. May 26, 2016 at 2:13 PM
    veg hed
    veg hed [OP] Thug
    Utah
    2016 Ta-Tundra Barcelona Red
    Obviously there is a price difference and I understand that. However, my main question is if I do get the pro suspension will my 2016 Tundra then be level? I also understand that the pro suspension will only lift it 2 inches. And I'm fine with that.
    Would I need shims in the front to level if I went with the pro suspension? And if so how many? And who sells them? Coachbuilder?
    I have been looking at a lot of the Toytec suspensions and they look nice. However, I'm really Diggin the pro set up as well.
    Basically I'm looking for 2 to 3 inches of lift and I want the truck to be level so I know I have some options.
    I'm also hoping someone with a fox lift will chime in as well.
    Here's how it looks now.
  2. May 26, 2016 at 2:27 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Pro suspension is supposedly a 1.5" to 2" front lift from stock. You can fit 35s with cab mount chop and plastic trimming.
    @coachbuilder has shims he recommends to add additional lift to the pro suspension. Not sure what height and rear combo to make level. I'm sure he can help out.
    You could go with a Toytec or Fox 3/1 setup for cheaper that would be 3" front and 1" rear lift. The rear would be block, aal or shackle.
    I have the Toytec Boss lift kit 3.25/1.5. Love the feel and a little smoother than the Bilstein 5100s.
  3. May 26, 2016 at 3:44 PM
    I have the 3/1.25 Toytec boss setup. No issues or regrets here
    happyjack87 and Justin0131 like this.
  4. May 26, 2016 at 6:58 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Pro suspension is only a leveling kit. It does not add any height in the rear. Common misconception
  5. May 26, 2016 at 10:14 PM
    veg hed
    veg hed [OP] Thug
    Utah
    Is this for real?
  6. May 27, 2016 at 5:21 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Yep. Only levels the front.
  7. May 27, 2016 at 7:07 AM
    veg hed
    veg hed [OP] Thug
    Utah
    So if I wanted to do something along the lines of 3-1 using Trd pro suspension I'd have to put a 1" shim in the front and a shackle in the back?
  8. May 27, 2016 at 7:14 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    I thought about pro suspension but for the money I'd get a stage two icon kit and still pay less. Probably go plus 1 in front end for extra inch of ground clearance. Plus Pro suspension lowers your tow capacity and makes you squat real bad from what I've heard. Icon will not. (Supposedly)
  9. May 27, 2016 at 7:17 AM
    mdavis
    Michael
    Rock Hill, SC
    Yep.
  10. May 27, 2016 at 8:16 AM
    Pro suspension is only ~2" up front so yep
  11. May 27, 2016 at 8:33 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    how much is the trd pro suspension in the USA?
  12. May 27, 2016 at 8:45 AM
    pinoyflayv
    pinoyflayv New Member
    2016 Tundra 1794
    TRD Pro Grill & Hood Bulge - TRD Pro Front Skid Plate - TRD Rear Sway Bar - TRD Dual Exhaust - TRD Pro Suspension - Fuel Krank 18x9 +20 Offset 5.75"BS - Toyo Open Country 35x12.50R18
    TRD Pro Suspension = $2599 I got mine installed from the Dealership, paid $3800 that includes the alignment. Loving my setup so far.
    Noodle and T-Rex266 like this.
  13. May 27, 2016 at 9:04 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Here in Alberta, Canada I called my dealer and its $3300cad for the suspension and $400cad installation and that includes alignment. So around $3700cad = $2845usd, with the dollar exchange right now.
  14. May 27, 2016 at 9:17 AM
    gary
    gary New Member
    2016 tundra
    trd exhaust, bilstein shocks, grill and painted handles
    list price is $2599.00cost $2288.00
  15. May 27, 2016 at 9:28 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Cool that's around $3000cad right now. Not bad. I'm just saving for the suspension can't wait till I have enough :)
  16. May 30, 2016 at 7:45 PM
    veg hed
    veg hed [OP] Thug
    Utah
    Anybody have a Fox set up? And if so which ones?
  17. May 31, 2016 at 2:02 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    @NUMB LOCK does, he has them on a 3in lift. I believe he likes them.
  18. May 31, 2016 at 10:25 AM
    happyjack87
    happyjack87 New Member
    Anyone have a picture of the 3-1?
  19. May 31, 2016 at 10:28 AM
    mdavis
    Michael
    Rock Hill, SC
    Tons of pictures on this site. Take a look around and you'll find everything you want to know.
    Welcome by the way!
  20. May 31, 2016 at 10:53 AM
    csuviper
    Broomfield, CO
    veg hed[OP] and T-Rex266 like this.
  21. May 31, 2016 at 11:43 AM
    veg hed
    veg hed [OP] Thug
    Utah
    I'd like to see some pics as well and part numbers and links always help.
  22. May 31, 2016 at 2:18 PM
    csuviper
    Broomfield, CO
  23. May 31, 2016 at 2:36 PM
    veg hed
    veg hed [OP] Thug
    Utah
  24. May 31, 2016 at 2:48 PM
    csuviper
    Broomfield, CO
  25. May 31, 2016 at 2:54 PM
    veg hed
    veg hed [OP] Thug
    Utah
    Now we're talking!
  26. May 31, 2016 at 9:40 PM
    NUMB LOCK
    NUMB LOCK Perpetual Member
    Northern VA
    2016 MGM TRD Pro
    Fox 3" lift, Methods, 35" A/T Baja Boss, Retrax Pro XR, Baja Designs light bar, Warn winch, Chaos Fab Shop tire carrier
    Here's a snapshot of the fox set up...
  27. May 31, 2016 at 9:41 PM
    veg hed
    veg hed [OP] Thug
    Utah
    Yeah, that looks sharp. Did it raise it a fell 3"? And is it level?
  28. May 31, 2016 at 9:43 PM
    NUMB LOCK
    Northern VA
    2016 MGM TRD Pro
    Yeah its definitely a full 3" but looks much higher with the 33" wheels. And it is level.
    If I get a new bumper, I'll increase the tire size.
  29. May 31, 2016 at 9:46 PM
    csuviper
    Broomfield, CO
  30. Jun 1, 2016 at 2:47 PM
    chphilo
    chphilo Tundra addict
    Western PA
    If you want the system that's fully tuned for Tundras right out of the box, Pro suspension is the way to go. If you want to fiddle around with adjustment, Fox/King/Icon, etc., will serve you well. Pro and OME are more of an install-it-and-forget-it type of kits. I haven't heard too many bad things about the Pro suspension (except the price).
    What I would really like to get is OME BP-51, but unfortunately, they are not available for Tundras. At this point, I am thinking that they are not interested in developing them for Tundras.
    https://www.youtube.com/watch?v=DxfOlbRNpbM
