TRD Pro Squatting
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by alpinepro4, Apr 25, 2018.
  1. Apr 25, 2018 at 4:12 PM
    alpinepro4
    alpinepro4 [OP] What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    I noticed when fully loaded with my ARE cap and two mountain bikes on my Thule T2 hitch rack my rear end squats. I driving on rough dirt roads the suspension does great, but I can't get over the squat.
    Buddy of mine told me to use air bags, thoughts on air bags? At what brand should I look at? Or should I add a leaf. Would like to keep the rear end and plush as possible, love to mash on it when off road!
    dcsleeper408 likes this.
  2. Apr 25, 2018 at 4:17 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Airbags are nice because you can add and remove air depending on the load you have in there. Add a leaf may be better for you since you have a constant load with the cap. I've had both and liked the airbags but I've never had a cap. There's ups and downs to both.
    NHPig likes this.
  3. Apr 25, 2018 at 4:22 PM
    alpinepro4
    Pat
    Cap doesn't weigh that much only 200 lbs. I like the sound of air bags since it may not affect the way the truck rides. Seems to me if I add a leaf it will make a stiffer ride, or am I wrong?
    Rica25 and Pudge like this.
  4. Apr 25, 2018 at 4:31 PM
    Pudge
    CT
    You're not wrong at all.
    Bags need some air at all times, I believe firestone says 5psi, which isn't too stiff. I had one that leaked a little and it drove me nuts. But I loved i could pump them up to 50psi and carry a shit load of weight.
    If you get bags. Get some cradles so they are only attached to frame and free floating from axle. Daystar makes cradles.
  5. Apr 25, 2018 at 6:16 PM
    alpinepro4
    Pat
    Awesome sounds like airbags are the way to go. Sean do you have an onboard compressor, and did you install them yourself?
    Pudge likes this.
  6. Apr 25, 2018 at 6:51 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Airbags are good for loads that vary in weight. I thought about using on Tacoma Baja due to same problem. Levelled trucks will squat with any kind of load. I went with Helwig helpers. No change in ride and no squatting with boat hooked up. I did not want to have deal with inflating or deflating bags.
  7. Apr 25, 2018 at 7:14 PM
    alpinepro4
    Pat
    That's where the onboard compressor comes into play.
  8. Apr 25, 2018 at 7:24 PM
    Pudge
    CT
    I did not have an onboard compressor. Just a bike tire pump. Would take 5-10 pumps to add 5-10 psi. So couldn't justify the money since it was so quick and easy to pump them up and down. One thing to be sure of is to keep the left and right bag independent, do not put a T fitting in the air lines. The loads shifts and so does the air.
    The helwig helpers are a good idea too.
    A full new leaf pack would be your best option. Idk what I'd do if I needed something in my tundra. I don't think I'd ever do an add a leaf again though. The ride was brutal unless I had a few hundred lbs in the bed. But the bags also add stiffness but at least you can adjust the stiffness. 5psi may be enough to level you out, and a few lbs here and there to keep it level.
    MTRock likes this.
  9. Apr 25, 2018 at 7:27 PM
    Pudge
    CT
    I kinda shocked Toyota didn't address this on the Pro's. They lifted the front 2" i think? But left the rear alone, so it sits about level, any load and you're nose high. No forethought there at all.
    gjcarving and Krezz like this.
  10. Apr 25, 2018 at 7:31 PM
    alpinepro4
    Pat
    Yeah it really bums me out. Another mod I have to explain to the wife.
    Airbags sound like the best solution or a deaver leaf pack at $1,300. Not sure if the deaver pack will cause a harsh ride. Anyone have insight on this?
    Pudge likes this.
  11. Apr 25, 2018 at 7:34 PM
    Pudge
    CT
    Cant help on the leaf pack question. But I do know your predicament would drive me nuts. I went to the outter banks one year, 4 people in truck, plus luggage in the bed and I would bottom out on bumpstops on ever bump, it was horrible. Added air bags when I got home. The leafs on the tacos sucked. I'd bottom out with 200lbs in the bed.
  12. Apr 25, 2018 at 7:48 PM
    alpinepro4
    Pat
    Well the TRD Pro suspension is keeping me from bottoming out. Just looks terrible when fully loaded. Did you find once you installed the airbags your bottoming out was solved? I noticed it before this trip but thought it was uneven ground. Turns out the cap caused the bed to squat a bit.
    Pudge[QUOTED] likes this.
  13. Apr 25, 2018 at 8:03 PM
    Pudge
    CT
    Yes the air bags solved the bottoming out issue for sure. I have never bottomed out in my tundra, before bags I would bottom out when i had some weight in truck, didn't take much weight, and I went over a bump And I agree, being nose high is a bad look.
  14. Apr 25, 2018 at 8:12 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    I added firestone ride right kit and daystar cradles to my 2012 Tacoma and it changes the way it rides. I'm not really a fan of them, I added them to help with the weight of the cap. I'm going to switch to a better leaf pack, the airbags kind of bounce you back after you go over a bump even with low psi in them.
    Black Wolf, ColoradoTJ and Pudge like this.
  15. Apr 25, 2018 at 8:28 PM
    alpinepro4
    Pat
    That is good to know, I was afraid that could be an issue. I live on a dirt road with lots of holes. Getting bounced back not a option I want to deal with.
  16. Apr 25, 2018 at 8:36 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
  17. Apr 25, 2018 at 8:40 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Yeah I wouldn't want to deal with it in your situation, they just give so much extra rebound. I bought the Trd pro kit for my Tacoma and switching to wheelers off-road 5 leaf hd pack and ditching the airbags.
    JoshuaA likes this.
  18. Apr 25, 2018 at 8:42 PM
    Pudge
    CT
    Rough dirt road sound like it'll rule out airbags too.
    I can't believe I didn't think of shackles. That's a good option. Much better option than blocks. I still think leaf pack is best, but also the most expensive option.
    JoshuaA likes this.
  19. Apr 25, 2018 at 8:59 PM
    alpinepro4
    Pat
    Ron did you add shackles to your stock leaf pack? I am looking into a Alcan leaf pack.
    Toytonka and ColoradoTJ like this.
  20. Apr 25, 2018 at 9:03 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Coachbuilder or Toytec shackles will raise the back 1.75" or 1.5" max respectively.
    At a 2" front increase over base on a stock Pro, your truck will sit raked without cap and bed empty using one of those full length shackles (I'm at 2.5" front, 1.5" back and I still have a some rake).
    trd.james and Pudge like this.
  21. Apr 25, 2018 at 9:10 PM
    alpinepro4
    Pat
    The cap stays on the rig all the time. Seems to me a custom leaf pack will give me a bit of rake also.
    ColoradoTJ likes this.
  22. Apr 25, 2018 at 9:16 PM
    This...so much ^^^^
  23. Apr 25, 2018 at 9:23 PM
    This is another great option that is relatively cheap OP.
    Rica25 and (deleted member) like this.
  24. Apr 26, 2018 at 7:45 AM
    alpinepro4
    Pat
    Hard to see but took a photo of the truck and springs.
    Sandbox, Juddrussell, JH5370 and 3 others like this.
  25. Apr 26, 2018 at 7:48 AM
    ToyTec shackles are only $140. A steal......
    Watt maker and dcsleeper408 like this.
  26. Apr 26, 2018 at 7:58 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    or steel??
    08TXTundra, Y0TA PR0, Krezz and 2 others like this.
  27. Apr 26, 2018 at 8:07 AM
    alpinepro4
    Pat
    Inquiring on steel.
    dcsleeper408 and ColoradoTJ like this.
  28. Apr 26, 2018 at 8:33 AM
    Don’t forget the Tundras.com discount.
    Watt maker, dcsleeper408 and Pudge like this.
  29. Apr 26, 2018 at 9:02 AM
    alpinepro4
    Pat
    Who is the discount for Aclane or Dever?
  30. Apr 26, 2018 at 2:12 PM
    Steel. Solid welded..zinc plated.
    dcsleeper408[QUOTED] likes this.
