TRD pro skid plate.
Discussion in '2.5 Gen Tundras (2014-2021)' started by xtyfighterx, Dec 8, 2020.
  1. Dec 8, 2020 at 8:18 PM
    xtyfighterx
    xtyfighterx [OP] New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I’m looking to buy a new pro skid plate is this the correct part number for the one with red letters? I know there’s two different skids one with letters one without.
    (PTR60-34190).
    And who has the best deal right now?
    Thanks everyone
    TelemarkTumalo likes this.
  2. Dec 8, 2020 at 8:39 PM
    RobertD
    Robert
    DFW, Texas
    Per @Roman they all come with the red letters now. Its posted about in the ultimate parts thread. Unsure who has the best deal
    Roman and xtyfighterx[OP] like this.
  3. Dec 8, 2020 at 8:41 PM
    xtyfighterx
    Ty
    North Idaho
    Nice didn’t know that! Thank you
    RobertD[QUOTED] likes this.
  4. Dec 9, 2020 at 3:59 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
  5. Dec 9, 2020 at 4:01 AM
    Pkahir12
    Pkahir12 New Member
    Pratik
    2017 Toyota Tundra Platinum
    Make sure you have a helper with you. I know it was a pain to install.
    xtyfighterx[OP] likes this.
  6. Dec 10, 2020 at 9:48 AM
    7undr4
    7undr4 New Member
    i will also recommend adding some rubber washers in every bolt. i learned the hard way it kept rubbing metal to metal and i makes a concerning sound. i install the skid plate around the same time my lift and i thought it was something to do with the lift and the mechanic had to take apart the lift kit to check and that’s when we realize it was the skid plate.
    itsmerh85, 14burrito and Pkahir12 like this.
  7. Dec 10, 2020 at 11:55 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Why spend so much on the factory plate when pretty much all the aftermarket plates are cheaper and better?
  8. Dec 10, 2020 at 10:36 PM
    jwctundra
    jwctundra New Member
    2020 Tundra 1794
    100% agree with this! I took mine off to install the front sway bar. The skid-plate was factory installed on my car. When I put the plate back on my car it made a horrible sound whenever I made a turn that took me awhile to diagnose which I finally read about on this site. I reinstalled with rubber washers all over and now it's quiet as it was originally. At first I thought to replace the hardware but they want almost $90 for it!
  9. Dec 11, 2020 at 12:50 AM
    TXTundra2722
    2015 Black Tundra
    I agree with the earlier comment. You can spend about the same amount and get a much more protective/covered skid from aftermarket such as RCI, Victory4x4, etc...AND it will have a door for oil changes.... which the factory skid will not have
  10. Dec 11, 2020 at 12:52 AM
    The TRD Pro skid does have the door.
    g6t9ed and hagrid like this.
  11. Dec 11, 2020 at 12:57 AM
    TXTundra2722
    2015 Black Tundra
    I stand corrected then.... still mild compared to how beefy the aftermarket skids are.... it's like comparing a grocery bag to an actual gym bag!
    :smokertransformer:
    Black Wolf likes this.
  12. Dec 11, 2020 at 4:07 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    I have a TRD Sport so the OEM TRD products was the path I chose. I use my truck to pull a boat on weekend. If I was hardcore off roading and really needed rock sliders and skid plates I might have gone the route of miscellaneous vendor product all of which appear to be great products.
    The Mods you choose should be guided by usage and preference. If I were going to do hardcore off roading or towing heavy loads I would have chosen a more capable platform. My 2 cents.
  13. Dec 11, 2020 at 4:15 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    :confused::confused::confused::confused::confused::confused::confused:
    hagrid likes this.
  14. Dec 11, 2020 at 5:16 AM
    Black
    Makes sense.
    Sadly, budget is the number 1 guide in my build. So I generally buy the least expensive that will fill my needs and are of quality.
    RCI happen to be cheaper and stronger than the TRD plate so I went that route.
  15. Dec 11, 2020 at 6:35 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    ^^^This is a rock crawling truck!
    TXTundra2722[QUOTED] likes this.
  16. Dec 11, 2020 at 7:08 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Aluminum Pro skid also hangs due to being porous.
    The steel skids will slide over shit better.
    GODZILLA likes this.
  17. Dec 11, 2020 at 8:14 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    And I'll add that by "Platform" I meant not a highway loaded TRD Sport with all the safety shit. I'd build up an SR5 all day long. :cheers:
  18. Dec 11, 2020 at 8:39 AM
    He might be a CDL driver. When you're in a Semi, everything else is just a car. :p
  19. Feb 15, 2022 at 10:21 PM
    Wakekid686
    Wakekid686 New Member
    Do you know if the TRD skid plate
    Do you know if the TRD skid plate still fits with the TRD front sway bars installed? Or is there anything that will hinder installment of the TRD skid plate?
  20. Feb 16, 2022 at 12:21 AM
    jwctundra
    2020 Tundra 1794
    Yes 100%. The TRD skid plates still fits fine with the TRD front sway bars installed. You should not have any issues with the installment of the TRD skid plate.
    bulldog93 and Wakekid686[QUOTED] like this.
  21. Feb 16, 2022 at 3:07 AM
    jomikepa
    jomikepa New Member
    O-H-I-O
    21 black truck
  22. Feb 16, 2022 at 5:11 AM
    nakota
    nakota New Member
    Phoenix
    Where do you recommend putting the rubber washers?
  23. Feb 16, 2022 at 8:22 AM
    itsmerh85
    itsmerh85 New Member
    Gilbert, AZ
    2020 Black TRDPro
    through the back two bolts that bolt through the frame. you can either use rubber washers, or strips of rubber compound if you have some lying around (weatherstripping, old bike tire, etc.) between the skid and frame before you bolt it back up. If you go the second route, just loosen the bolts enough to slide the rubber in and tighten back up. Took maybe 30 minutes total to loosen, cut the rubber to length, and tighten back
    nakota[QUOTED] likes this.
  24. Feb 16, 2022 at 9:29 AM
    nakota
    nakota New Member
    Phoenix
    Super smart. Thank you
  25. Feb 16, 2022 at 12:25 PM
    nakota
    nakota New Member
    Phoenix
