TRD PRO Skid plate creak
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Over the LINE, Jun 11, 2018.
  1. Jun 11, 2018 at 7:52 AM
    Over the LINE
    Over the LINE [OP] New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    So, I have the TRD Pro skid plate and like the title says it creaks. I removed it to make sure nothing else was making noise and it looks like the skid plate is the only culprit.
    Now my problem: I have an aftermarket bumper that mounts to the tow hook bolts. Since the skid plate mounts on top of the bumper mount, this means that the skid plate essentially has a 3/16" spacer at that mounting point only. If I do the rubber and nylon repair to stop the creaking, is it going to work with this setup? My other options are to add spacers to all the other mounting points or buy another skid plate (like RCI) and sell this one. Anyone have experience with this problem?
  2. Jun 11, 2018 at 7:57 AM
  3. Jun 12, 2018 at 6:49 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    Im waiting to install my nylon washers when I do the bumper. Let you know when I do it.
  4. Jun 13, 2018 at 6:23 AM
    Over the LINE
    New Orleans
    Since it did not seem like anyone had an answer for me, I decided to just reinstall my PRO skid plate. I cleaned all the mating surfaces, touched up worn spots on skid plate with spray bed liner, used flexseal rubber tape and rubber washers (could not find nylon) to separate mating surfaces. I also decided to grease all contact spots and I tightened the bolts from the inside out doing the rear and tow hook bolts last. FYI I removed my tow hooks because with the bumper, skid plate and tow hooks all stacked up, the bolts are a little short.
  5. Jun 15, 2018 at 2:13 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    About 18 months ago I added nylon washers from Ace Hardware under all of my fasteners. That solve the problem for me completely.
    14burrito and Sunnier like this.
  6. Apr 4, 2019 at 6:26 PM
    Blade16
    Blade16 New Member
    Mitch
    2016 SR5 DC 4x4
    Blistein level. Front/Rear swaybar
  7. Apr 4, 2019 at 6:29 PM
    Blade16
    Blade16 New Member
    Mitch
    2016 SR5 DC 4x4
  8. Apr 5, 2019 at 7:07 PM
    Over the LINE
    New Orleans
  9. Apr 5, 2019 at 7:36 PM
    veg hed
    veg hed Thug
    Utah
    2016 Ta-Tundra Barcelona Red
    JH5370 likes this.
  10. Apr 7, 2019 at 12:06 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Anyone have a list of the nylon washers needed? Number and size?
    Installing the new skid today and want to do it right the first time.
    Thanks!
