TRD Pro shock leaking?
Discussion in 'Suspension' started by veg hed, Aug 11, 2016.
  1. Aug 11, 2016 at 6:14 PM
    veg hed
    veg hed [OP] Thug
    Utah
    2016 Ta-Tundra Barcelona Red
    I bought these a few weeks ago and haven't had the time to put them on because I've been working a lot so they have just been sitting around. I didn't notice at first but when I pick them up the other day some fluid seem to drip out of the plastic shock cover. The guy I bought them off of said they only had a few thousand miles on them and they look practically new. They also seem to compress and recoil well. Is this normal? Should I be worried?image.jpg image.jpg
  2. Aug 11, 2016 at 6:43 PM
    Aren't you glad they are rebuildable?
    Black Wolf likes this.
  3. Aug 11, 2016 at 7:43 PM
    Veg hed is in WY. Not too far from CO Springs. Nice trip at worst. Maybe you can give Veggie and some of us local CO guys a lesson on shock rebuild. (Sorry, Chris, but you opened that door wide open....heh...heh) :bananadance:
    veg hed[OP] likes this.
  4. Aug 11, 2016 at 8:21 PM
    veg hed
    veg hed [OP] Thug
    Utah
    Does that mean they need rebuilt?
  5. Aug 11, 2016 at 8:47 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Generally speaking when shocks leak there is a problem. Is this a cause of leaking oil or just some liquid that was stuck inside the boot from cleaning by the previous owner?
    With that being said I'm not a suspension guru, but some of the guys on here are, hopefully they chime in.
    Maybe some more pictures of exactly where it looks like the oil is coming from would help.
    Shit happens but I find it hard to believe they would be leaking unless he was really beating his truck up.
  6. Aug 11, 2016 at 8:48 PM
    @jberry813 and @ColoradoTJ are the guys to answer that. I'm not even a novice when it comes to rebuilding shocks like yours.
    MotoTundra likes this.
  7. Aug 11, 2016 at 8:52 PM
    The "leaking" thing bothers me some what too. Maybe a pic with the boots off ?
    MotoTundra[QUOTED] likes this.
  8. Aug 11, 2016 at 8:55 PM
    Vizsla
    Vizsla pretend2send
    They may be ok, look at Bilsteins site for warranty requirements. There is a certain amount of oil deemed normal to leak, and having owned quite a few, about 1/4 had leaked oil in the box on shipping. They all performed fine.
  9. Aug 12, 2016 at 7:02 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Good to know. I always thought once a leak always a leak with suspension, if a seal is bad it is bad until it is replaced.
    ColoradoTJ likes this.
  10. Aug 12, 2016 at 7:25 AM
    I wouldn't worry about a little oil. Shock will weep a little.
    If they continue to leak, then be concerned.
  11. Aug 12, 2016 at 8:00 AM
    This is my King shock. The shaft is a little wet and weeps a little.
  12. Aug 12, 2016 at 1:23 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Nice setup!
  13. Aug 12, 2016 at 1:47 PM
    5.75 up travel and 8.25 down travel. It is set up light for the rocks.
    I try to stay into the upper spring (tender) for the first 3" of travel to keep it soft before the primary takes over.
  14. Aug 12, 2016 at 7:56 PM
    veg hed
    veg hed [OP] Thug
    Utah
    Thanks for all the input guys. All I have been thinkin about is how badass my truck is going to look when I get the lift on and now this. I'm on another wildfire in Wyoming for the next 2 weeks so maybe when I get back I can finally get the lift and Pro rims on. I am going to try to contact Bilstein direct to see what they say. I'll keep you all posted.
    MotoTundra and ColoradoTJ like this.
