TRD Pro headlights on an SR5?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Busta0978, Apr 22, 2020.
  1. Apr 22, 2020 at 3:37 PM
    Busta0978
    Busta0978 [OP] New Member
    Frankie
    I am looking for a led black housing headlight but when I go to Coolspring website. It says the trd pro Headlights wont fit..is this true? I drive a 2015 CM SR5..help me plz. . . Lol
  2. Apr 22, 2020 at 3:45 PM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    It will fit. You need a harness like the one from iHacker to make drl work. I just ordered this setup for my 2015
    Buildn likes this.
  3. Apr 22, 2020 at 3:46 PM
    Busta0978
    Frankie
    You wouldn't happen to know the part number...would ya?
  4. Apr 22, 2020 at 3:53 PM
    Luckydog
    Luckydog New Member
    Dominic
  5. Apr 22, 2020 at 4:01 PM
    Luckydog
    Luckydog New Member
    Dominic
    This is from Roman original post. It explains everything.
    These are the OEM LED Tundra headlights that are on the 2018+ models. They're quite popular, and for good reason. Just look at them! There is some information you need to know before placing your order, though.
    They are not plug and play with your 2014-17 Tundra. Don't cheap out on the harness you buy either. You wantyour brand new headlights to work properly. Order from @iHacker using this thread:
    https://www.tundras.com/threads/201...ls-no-motocontrol-required.24416/#post-592632
    All headlights come with the leveling motors. All headlights come with all bulbs. The high and low beam is an integrated LED within the housing and is not replaceable. Make sure to acquire your harness from a reputable vendor. If the high/low beam goes out, you must replace the entire headlight.
    They come in three flavors. Right above and below the yellow reflector on the outside edge is where the difference is. As seen in this picture, it is black:
  6. Apr 22, 2020 at 4:04 PM
    Luckydog
    Luckydog New Member
    Dominic
  7. Apr 22, 2020 at 4:15 PM
    Busta0978
    Frankie
    Thank you for all the info!
  8. Apr 22, 2020 at 5:04 PM
    @Busta0978
    @Luckydog
    I have the 2020 TRD PRO headlights I got the kit from Headlight Revolution with the harness they sell, on the how to video though I believe that was a 1794 Edition, I'm an SR5 and I had to depin and switch over pins, iHacker helped me with this
    Luckydog likes this.
  9. Sep 14, 2020 at 12:12 PM
    Tundra5767
    Tundra5767 New Member
    Karen
    2015 SR5
    Lifted, aftermarket lights
    I installed on my 2015 crew cab SR5 and my harness was from the retrofitsource. No issues with the install, connections etc, and I did switch the 2 wire pins in each signal connector. However I just noticed, during the day with headlights off, my climate control lights and some other dash lights are lit and flash with turn signal. With parking lights or headlights on, all is normal. No flashing. I kept the amber DRL's. I read somewhere that the purple wire does NOT need to be re-pinned if you have the amber DRL's, I re-pinned both. Is this my issue? I would prefer not to do the amber DRL delete.
  10. Sep 14, 2020 at 1:02 PM
    I got with iHacker and he walked me through the de-pinning of the purple wire, I just wanted the upper and lower led lights no Amber's, I had to switch them over, and no issues with other lights, '14 CM SR5
    I'm out of town I'll have to look but if I remember, yeas the purple wire is de pinned and I covered with electrical tape
  11. Sep 14, 2020 at 2:43 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Nothing should be flashing. One of the reasons a lot of us chose @iHacker harness as it’s top notch. His customer services is beyond words can explain. He helps every one out even tho it’s not his harness(something personally wouldn’t do) if you chose to save a couple dollars or what ever reasons you didn’t go with his harness. Then start calling the company you got it from.
    Luckydog and glowblue like this.
