TRD pro grille insert
Discussion in '2.5 Gen Tundras (2014-2021)' started by mech_engineer09, Feb 16, 2021.
  1. Feb 16, 2021 at 10:15 AM
    mech_engineer09
    mech_engineer09 [OP] Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    anyone have any experience buying this trd pro grille insert?
    https://mcautoparts.com/products/18-20-tundra-grill?variant=32438012444734
    Looks fairly easy to install and seems like the best option for me as my grille surround is ppf wrapped and ceramic coated and don't really want to have that done again because even small areas aren't cheap to do. Just curious about quality vs oem because this is a 3rd party part.
  2. Feb 16, 2021 at 11:15 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    I know @CorsoTundra and a few others have. The only negative complaint I've heard is some people have a slight 'splatter' in the sensor insert that is visually unappealing but doesn't affect fit, form, or function.
    Vang530 and mech_engineer09[OP] like this.
  3. Feb 16, 2021 at 11:23 AM
    shaggysanchez
    shaggysanchez New Member
    Kentucky
    I have this insert and have no complaints. I didn't have the issue that a couple had with the sensor garnish and after about 2K miles with it on I have had no issues with the sensor. PXL_20201126_182554139.jpg
  4. Feb 16, 2021 at 11:26 AM
    java230
    java230 New Member
    This is just an insert for the factory surround correct? Any install threads?
    mech_engineer09[OP] likes this.
  5. Feb 16, 2021 at 11:28 AM
    shaggysanchez
    Kentucky
    Correct it was just the insert, they sell a version with the surround as well.
    I would imagine there is one somewhere but it was pretty straightforward.
  6. Feb 16, 2021 at 11:30 AM
    java230
    java230 New Member
    Cool thanks, I just need the insert so I can relocate my TSS sensor.... May be the perfect solution. not wanting to sped a boat load to get rid of the chrome surround.
    I just didn't see any install pics etc so wasn't quite sure how it all went together.
  7. Feb 16, 2021 at 12:17 PM
    No issues here.
  8. Feb 16, 2021 at 1:33 PM
    I_Am_Thee_Walrus
    I_Am_Thee_Walrus New Member
    ‘21 Tundra TRD Off-Road
    The only issue is getting the original grill out without breaking tabs :annoyed:
    BravoDeltaRomeo and CorsoTundra like this.
  9. Feb 16, 2021 at 4:15 PM
    hillbillytoyo
    hillbillytoyo Just a country boy
    Daniel
    WV
    21 Limited Cement CM TRD OF
  10. Feb 17, 2021 at 6:41 AM
    mech_engineer09
    Ohio/Pennsylvania
    2020 MGM Platinum
    looks awesome man! whered you get the colored letters?
  11. Feb 17, 2021 at 6:41 AM
    mech_engineer09
    Ohio/Pennsylvania
    2020 MGM Platinum
    I found a video on youtube for the install. guy does it in about 5 minutes. I'll find the video later and post it here.
  12. Feb 17, 2021 at 6:53 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    https://www.youtube.com/watch?v=yTDwVSsAG_w
    Check this video out; very detailed.
    Make sure when you pop out your OE grille, don't break the clips that hold the grille onto the trim piece under the headlight. Push down and pull out.
    I heard that the MC Auto Parts one is good, but the garnish may be slightly scratched (there was another member that posted the MC auto parts grille review).
    I ended up buying the OEM grille and acrylic plate through a local dealership (don't forget the push washers for the acrylic plate). Total was roughly $550.
    One thing to note is that if you have the TSS, buying the OE version, there's a slot to clip the wire harness behind the first "T" in Toyota. Not sure about the 3P options.
  13. Feb 17, 2021 at 7:23 AM
    java230
    java230 New Member
    Thanks, I will take a look. I bought a full one from Empyre off-road as it was cheaper and in stock. I only need the insert, but whatever. I have taken my OW grill in and out a few times, so I think this should be not bad.
  14. Feb 17, 2021 at 8:14 AM
    mech_engineer09
    Ohio/Pennsylvania
    2020 MGM Platinum
    Were you able to buy the OEM grille without the surround (just the insert) from your dealer? If so I'd probably just go that route if possible from my dealer
  15. Feb 17, 2021 at 8:33 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Unfortunately, I don't think you can. You'd have to buy the whole assembly. Here's your part number: 531010c070b0
  16. Feb 17, 2021 at 6:48 PM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    C'mon man...
    Will this fit a 2014 tundra
    Unfortunately, it will only fit all Tundra models in the years 2015-2021.
  17. Feb 17, 2021 at 7:08 PM
    Jmor6766
    Jmor6766 New Member
    Jon
    SW Colorado
    2014 White Tundra TRD SR5 4.6L
  18. Feb 17, 2021 at 8:29 PM
    ZPMAN
    Minnesota
    I found that if you push down and gently pull out on thease two tabs (eachside)with a long screwdriver it will make pulling the grill easier. Then as i remember its just four button clips at the base of the grill.
  19. Feb 17, 2021 at 8:32 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Definitely great tip!
    TelemarkTumalo likes this.
  20. Feb 18, 2021 at 7:35 PM
    Tundra14Platinum
  21. Feb 19, 2021 at 7:36 AM
    Jmor6766
    Jmor6766 New Member
    Jon
    SW Colorado
    I do not have that one but I think plenty of folks do on the forum and mounting is the same from 14 to at least 19. The only thing is that’s aftermarket so fit might not be perfect like factory although people seem to be happy with them.
  22. Feb 19, 2021 at 7:56 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    This. Makes it less scary and doesn't sound like you are snapping anyting.
    I believe you can reach down with a skinny enough arm too. I have done mine a few times and don't recall having to use a tool, but I have Grade 6 boy arms. :(
  23. Feb 19, 2021 at 9:35 AM
    Landrun
    Landrun New Member
    Yippee Ki Yay
    Anyone have a pic with the chrome surround?
  24. Feb 19, 2021 at 10:33 AM
    @Fotnot
    Landrun[QUOTED] likes this.
  25. Feb 19, 2021 at 10:36 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    here's a couple i have....
    Landrun and java230 like this.
  26. Feb 19, 2021 at 10:46 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I found this install to be extremely easy (sorry @Swfltoyomafia :D) and took me under 30 mins start to finish to do on my 2017. i was expecting worse since i had talked to 3 others that told me it took them from a lil under 2 hours to split up over 2 days. i took my time using a small flat head screwdriver to pry the clips. i also dont' have all the sensors to worry about since i have a 2017:yes:
    ToyoMafia likes this.
  27. Feb 19, 2021 at 10:50 AM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Show off!
    Fotnot[QUOTED] likes this.
  28. Feb 20, 2021 at 4:00 AM
    Landrun
    Landrun New Member
    Yippee Ki Yay
    Well that looks great. Guess I'll pull the trigger on that asap. Thanks!
  29. Feb 23, 2021 at 8:25 AM
    java230
    java230 New Member
    Here is mine from Empyre offroad. Garnish trim is ugly, but it fit fine. Quality isnt quite OE, but its not where near the cost either.
    blackoutt likes this.
  30. Mar 7, 2021 at 4:18 PM
    JMB711
    JMB711 New Member
    2020 Trunda SR5 Crewmax TDR offroad
    Running boards. Shaved vehicle emblems. TruXcedo low profile tonneau cover. LED interior lights along with cargo bay and reverse lights.
    I bought the full grill with the black surround..The fit is perfect the sensor cover is clear. I will be repainting the lower and my new used upper surround quicksand in a week or so.
