Trd pro access to battery.
Discussion in '3rd Gen Tundras (2022+)' started by Efreet6669, Mar 10, 2023.
  1. Mar 10, 2023 at 12:41 PM
    Efreet6669
    Efreet6669 [OP] New Member
    '07 Limited Red Salsa Pearl,'23 TRD Pro Solar Octane
    Has anyone found a access to the battery from the back of the cab?
  2. Mar 10, 2023 at 12:57 PM
    wedemmoez
    wedemmoez New Member
    2022 Black Tundra TRD Pro
    The 12v battery is under the rear seat on the drivers side. Lift up the rear seat and there is a panel covering it that unclips and gives you access to the battery. There are images and detailed instructions in your owners manual.
  3. Mar 10, 2023 at 1:56 PM
    Efreet6669
    Thank you, I found the battery trying to find away to tap the battery for my power management system. Unable to find a way to run the single positive cable to the battery?
  4. Mar 10, 2023 at 2:42 PM
    wedemmoez
    You don't need to go directly to the battery, there are several +12v access points in the fuse block on the passenger side that you may be able to use depending on your specific application.
  5. Mar 10, 2023 at 2:48 PM
    Efreet6669
    Attempting to power a Spod from Baja designs; so I don’t have to run lines into the cab?
  6. Mar 11, 2023 at 1:35 PM
    wedemmoez
    you can tap them into the fuse box in the engine bay for power and run the switch to the cabin through existing grommets in the firewall near the steering rack.
    Ely010606 likes this.
