Trd pro 2” factory front lift
Discussion in 'Suspension' started by Tundramoney, Apr 4, 2018.
  1. Apr 4, 2018 at 8:35 AM
    Tundramoney
    Tundramoney [OP] Old school
    Earth
    If trd pros come with a 2”front lift shouldn’t it be safe and within factory specs to lift a new tundra 2” in front without worrying about strain on suspension and front drivetrain parts?
  2. Apr 4, 2018 at 8:44 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
  3. Apr 4, 2018 at 8:45 AM
    Tundramoney
    Earth
  4. Apr 4, 2018 at 8:45 AM
    Rica25
    Ricardo
    Tulare
    The shocks I believe is what does the lift on the pros but nothing else should have to be changed
    gosolo likes this.
  5. Apr 4, 2018 at 9:14 AM
    Tundramoney
    Earth
    Thanx I put some new 2” lift struts on and someone was telling me it would mess up the front end so I looked at a trd pro in the parking lot at Walmart and all the angles looked the same as mine after my strut install
  6. Apr 4, 2018 at 9:15 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yep, it’s just the CO and shock assembly. Upper and lower control arms are not different
    Tundramoney[OP] likes this.
  7. Apr 4, 2018 at 9:16 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    What struts did you install?
    NewImprovedRon likes this.
  8. Apr 4, 2018 at 9:16 AM
    Tundramoney
    Earth
    Great that’s what I thought
  9. Apr 4, 2018 at 9:17 AM
    Tundramoney
    Earth
    Rancho 7000s part# rs7759
  10. Apr 4, 2018 at 9:18 AM
    Rica25
    Ricardo
    Tulare
    As long as you aligned it after front shock install you should be fine
  11. Apr 4, 2018 at 9:21 AM
    Tundramoney
    Earth
    Trd pro had a red sway bar is it longer for the additional 2” lift
  12. Apr 4, 2018 at 9:29 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    They are coilovers not struts for 1.
    2 you will have no issues with a 2" lift. Not much is really needed beyond the front coilovers.
    You could consider front differential drop spacers and UCAs but with only 2" lift they are not needed. Recommended for 3" +
  13. Apr 4, 2018 at 9:32 AM
    Tundramoney
    Earth
    2BCC70E4-7CD8-4FF8-95D3-B332BAE8658D.jpg what it looks like
  14. Apr 4, 2018 at 9:32 AM
  15. Apr 4, 2018 at 9:37 AM
    Tundramoney
    Earth
    Over and out thanx for the replies!
    Black Wolf likes this.
  16. Apr 4, 2018 at 9:43 AM
    Tundramoney
    Earth
    No need to mess with sway bar?
  17. Apr 4, 2018 at 9:50 AM
    csuviper
    Broomfield, CO
    Nope
  18. Apr 4, 2018 at 9:54 AM
    Tundramoney
    Earth
    Ok thanx I feel better already
  19. Apr 4, 2018 at 12:25 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yep, curious also what the op would come up with. Good thing that there’s lots of help setting me straight, that there job has been wearing out my blushing bride!
  20. Apr 4, 2018 at 12:31 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yep, kinda just like I said in post #6 above?
  21. Apr 5, 2018 at 9:37 AM
    Tundramoney
    Earth
    Why do you call
    these coilovers when Rancho and everyone that sells them has them listed as struts? It even said struts on the box they came in. Is it like when you take the coil spring off the old strut and put it on the new strut it becomes a coilover?
    http://www.gorancho.com/products/le...ng-system/rancho-quicklift-7000mt-rs7759.html
  22. Apr 5, 2018 at 10:22 AM
    csuviper
    Broomfield, CO
  23. Apr 5, 2018 at 10:27 AM
    Tundramoney
    Earth
  24. Apr 5, 2018 at 2:14 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Wonder how this shock compares to a 5100? This is the first time I've seen or heard of it.
  25. Apr 5, 2018 at 2:45 PM
    15whtrd
    15whtrd Mr. Blonde
    Strut
    TXRailRoadBandit73 likes this.
  26. Apr 5, 2018 at 2:53 PM
    Tundramoney
    Earth
    I don’t know about the 5100s but I was not a fan of that adjustable clip. I had ranchos on a lifted blazer back in the 70’s. So after a lot of research I figured what the heck and bought them they gave me a solid 2” front lift I also bought a pair of 7000s for the rear so I Have them in all 4 corners. I would buy them again no problem. I like the ride big improvement over stockers great warranty also.
  27. Apr 5, 2018 at 2:58 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @Tundramoney
    You can call em magazines or clips, call em struts or coil overs, call it a crick or a creek, call it a tomato or a tomato and I’ll still call you my Tundra bro!
    Keep on trucking...
  28. Apr 5, 2018 at 6:49 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    It may be the lighting in the pic, but the lower part of the shock looks like it’s hitting the lower control arm.
  29. Apr 6, 2018 at 3:32 AM
    Tundramoney
    Earth
    No it’s not hitting there is pleanty of room !
  30. Apr 6, 2018 at 4:53 AM
    Tundramoney
    Earth
    Great video just got around to watching it!
