TRD Performance Brake Pads
Discussion in '2.5 Gen Tundras (2014-2021)' started by 737fixer, Nov 13, 2020.
  1. Nov 13, 2020 at 9:24 PM
    737fixer
    737fixer [OP] New Member
    Something odd about the "so called" Performance Pad? Looked at several sites for the standard OEM pad for our trucks or at least the 3rd Gen. and found prices ranging below. Question is if the TRD Performance Pad is supposed to be some upgrade then why is it literally slightly cheaper. What am I missing?
    Front Regular Brake Pads 04465-02440 $99.00 - $121.00
    Rear Regular Brake Pads 04466-02340 $79.00 - $99.00
    Front TRD Performance Brake Pads PTR09-0C111 $82.50 - $95.00
    Rear TRD Performance Brake Pads PTR09-0C110 $82.50 - $95.00
  2. Nov 13, 2020 at 10:12 PM
    Toytonka
    Toytonka New Member
    Glendale AZ
    2020 White TRD OR DC
    Trd Dual Exhaust
    Interesting catch.
    But both are expensive for pads.
    Tundyfundy likes this.
  3. Nov 13, 2020 at 10:26 PM
    MGM2020
    MGM2020 New Member
    Sacramento CA
    2020 MGM Tundra SR5
    6" Rough Country Lift 37" on 22" V2 Monotube Rear L3 Lifted Struts Front
    Whats the difference between those and pads you can buy at Autozone or O'Reilly?
  4. Nov 14, 2020 at 5:51 AM
    1rebmem
    1rebmem New Member
    Jef
    TN
    2018 SR5 4x4 Inherited from my dear dad RIP 4/21/2020
    Two years old and 5200 miles when I took ownership
    $50 per single pad = :annoyed: expensive!
  5. Feb 1, 2021 at 7:06 AM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    Cuz TRD son!
  6. Feb 1, 2021 at 7:35 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Quality control.
    There's various grade of quality control that indicating pricing differences, a factory may make the same brake pads but with 3 levels of quality control, OEM usually demand the best, so they are the most expensive, then you get name brand, may be its for their own brand or another known name brand, second most expensive, then you get generic, which is the ones that you may have to do some shaving in order to fit in the calipers right, those tend to be the cheaper ones.
    Also, for "performance" oriented brake pads tend to be more metallic oriented in construction, the raw material itself is cheaper, hence the pads are cheaper, the downside is usually more dusts, OEM ones tend to be ceramic based that have lot less brake dust, but ceramic organic material costs more.
    stevesgraytundra likes this.
  7. Feb 1, 2021 at 7:50 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I have the TRD pads and love them. As @Downytide said. Lots of brake dust but I noticed a boost in stopping power.
    Tiamat likes this.
  8. Feb 1, 2021 at 8:18 AM
    Tiamat
    Tiamat New Member
    I just purchased front oem rotors and trd brake pads. I Wash my truck regularly so don't care about dust. Stopping power is what im after. Hopefully i worm wsrp the rotors during the 10 rounds of 0-60-5 bedding process.
    Tundyfundy[QUOTED] likes this.
  9. Feb 1, 2021 at 8:41 AM
    Downytide
    GTA
    To physically distort a metal rotor requires A LOT of variance of temperature, you literately have to hit it up to 200c on surface then douse one part with ice cold water to get it distort, or past its operating temperature, not saying its impossible, but on most road vehicles its very rare.
    That wiggle sensation is usually uneven deposit on the brake pads on the rotors, so when you install the new rotors, make sure you clean the hub area properly, you would be surprise by how much your rotor would be off with just tiny bit of material, and follow bed in procedure carefully, do slow braking first, 2-3 times, then higher speed, allow it to cool while driving, then do full braking where you are almost locking up, drive off and let it cool, never stand on the pedal because then you will have hot transfer on one spot.
    15whtrd likes this.
